Old 07-23-2008, 06:36 PM   #81 (permalink)
Great videos and advice! I am new to this hobby and have just installed the 401 Gyro and DS285MG servo's. I have watched the videos and they were a great help, but I want to get them moving in the right direction and range of movement. I would appreciate it if someone could tell me, on the DX6i Reverse menu which should be reversed and what other settings I should check/adjust to get them all moving in the right direction and full movement?
JamesAg is offline        Reply With Quote Quick reply to this message
Old 07-23-2008, 09:54 PM   #82 (permalink)
for the 285
haveing the aile on the left and pitch on the right
all should be N
except pitc
and swash mix
aile and elev will be -
and pitch shall be +
B400 DS285/3400G/401/-8/40Aesc/sonicCNC/CNCframe
TwinRexx: 6xHS-65/2xGY240/jfg500/TH2
CH-47D/UH-1H Crewchief/ Mechanic
sokal is offline        Reply With Quote Quick reply to this message
Old 07-24-2008, 02:37 AM   #83 (permalink)
Originally Posted by sokal View Post
for the 285
all should be N
except pitch
and swash mix
Thanks Sokal, I am close but something is backward according to the response I should be getting according to how I read manual.
When I move the left stick up the swashplate raises, When I move it down the swashplate lowers (according to the manual it should be the opposite).
I tried switching the two connections for pitch and aile to match what you had above but the movement is not as clean (doesn't really move up and down much). I reviewed your videos again and found that they can be set up either way, so I guess I just need to adjust the settings in the transmitter. Would you be kind enough to tell me how those should be set up? I have listed my current configuration and settings below. Thanks, this part has really got me confused.
Here is my setup:
As you look from the back of the heli,
Rear servo with arm on left side - pitch- connected to AUX
Rear servo with arm on right side - aile -connected to ALE
Front servo with arm on left side - ELEV
In the Reverse Menu
all are N
except pitch
and swash mix menu
aile -75%
elev will be - 75%
and pitch shall be +85% (the percentages on these are the originals I have not adjusted yet)
Old 07-24-2008, 07:31 AM   #84 (permalink)
Here is my setup:
In the Reverse Menu
all are N
except pitch
and swash mix menu
aile -75%
elev will be - 75%
if all is going up when you pushed up and down on the cyclic then all you needto do was rev the elev
since you switched the aile and pitc servo change the R to the aile servo
when you hit up both back servos should go up and down for down
if all goes up when you hit up rev the elev
if swash moves opposit rev all three
work one servo at a time to move in the direction in needs to go
servo arangment
i have my aile servo on the left but that doesnt matter
Old 07-25-2008, 01:52 AM   #85 (permalink)
Default keeping in view
SOKAL"S Blade 400 3d Setup vids
I made these video's to help and share my findings and knowlage ive learned of this RC Helicopter. Im not a pro at video and never will be but iv given it my best attemp.
My videos do not and will not over ride Finless's videos. his videos are very good and full of valuable information. my vids just help relate it to the Blade 400 for the beginer and novice pilots out thier.
Disclaimer. Info provided is based on my experience with the Blade 400
take it as for what its worth but it is at your own risk. ( i promis i will
not lead you wrong, hate to see one not flying).
DX6i
Part 1 , Part 2
Gyro/servo setup
(GY401/3400G) Part 1 , Part 2
BASIC FLIGHT THEORY NEW
HOVER, APPROCHES AND DECELERATIONS , Coordinated Turns, Forward Flight
........more to come tapeing/editing
TAIL SETUP
Part 1(PULLY/BELT); PART 2a; Part 2b; Part 2c (tailrotor)
DUE TO NEW FINDING I WILL HAVE MY VIDS POSTED TO ANOTHER SITE WITCH PROVIDES HIGHIER QUALITY VIDEO
HI-RES VIDEO WITH DOWNLOAD OPTIONS
all downloadable
Old 08-11-2008, 10:45 AM   #86 (permalink)
Hey Sokal, in your Head Setup Vid, you mention that not all radios will be centered as you see it under the Monitor menu. I believe I may have one of those radio for my Throttle as it is way off. When I fly I use about 4-5 clicks on the Trim to off set this...
So I wanted to ask, knowing this, do I put the left stick at 0 when I set up my head? Can something be done to center the throttle? Or is it ok the way it is. Thanks!
T-Rex 600 NSP | YS 50 w/MP5 SB | Futaba GY611 w/BLS251 & BLS451 x4 | Flight Log: 5 gallons! & 1.5 Crash | ROTORTECH QUALITY SUX!
T-Rex 450 SE V2 | Scorpion 2221-8 / 60 AMP ESC V2 | Align GP750/S9257 | HiTEC 65MG @ 6 volts | KBDD Tail Blade | ROTORTECH QUALITY SUX!
T-Rex 250 | DS410 x3 | GP750 Gyro w/ 3500G | 205D CF | DS420SUCKS!!! |
MrCLoWnY is offline        Reply With Quote Quick reply to this message
Old 08-11-2008, 11:15 AM   #87 (permalink)
make sure you remove all subtrim and trim
and your curve at mid is 50%
now look at the monitor menu and center thing up
all but gyro (ch5)
if its off just move the stick as close as you can may be a hair line from the gimbal marks
Old 08-11-2008, 11:20 AM   #88 (permalink)
all but gyro (ch5)
How do I go about centering it? Im still not sure if I should set my left stick at 0 when adjusting. Sorry for the confusion..
Old 08-11-2008, 04:38 PM   #89 (permalink)
position the sticks so that on the screen its centered
in the monitor menu
Old 08-11-2008, 05:01 PM   #90 (permalink)
in the monitor menu
Hi,
I found the best way for me to center the sticks to true mid-stick throttle and pitch is to use the throttle or pitch menu. The vertical line in the graph tells you when it is really center (electronically).
The graph in the monitor menu of my rx is a little bit "off", so I do not really use it.
Best,
Frank
Tail boom is offline        Reply With Quote Quick reply to this message
Old 08-12-2008, 11:12 AM   #91 (permalink)
that sounds like a good way also
thanks
Old 08-14-2008, 06:02 PM   #92 (permalink)
Thank you for the videos!
srhadden is offline        Reply With Quote Quick reply to this message
Old 08-15-2008, 05:30 PM   #93 (permalink)
Default Thankyou!
Sokal, I was getting discouraged after a couple of crashes on my Blade 400. I haven't received quite the help I would expect from my LHS --- but your videos are awesome. I really like the Alan-Key Swashplate leveller trick - and the way you described it was bang on. I was finally able to hover with confidence today - I still have some tweaking to do. Thanks again!!
voodooftw is offline        Reply With Quote Quick reply to this message
Old 08-17-2008, 12:34 PM   #94 (permalink)
Default monthly vid repost 17aug 08
DX6i
Part 1 , Part 2
Gyro/servo setup
TAIL SETUP
all downloadable
Old 08-17-2008, 04:40 PM   #95 (permalink)
Thanks! Downloading the new additions now...
That flycamone vid makes me smile.
killboy is offline        Reply With Quote Quick reply to this message
Old 08-31-2008, 11:22 PM   #96 (permalink)
Sokal Thanks for the high quality vids. I just downloaded most of them. The site I guess only allows for so many downloads a day. So when I get back from vacation i will get the rest. Thanks again and looking forward to it.
Flyhighusa is offline        Reply With Quote Quick reply to this message
Old 11-29-2008, 03:21 PM   #97 (permalink)
Hi Sokal
I have a question does Eflight have there own web site. I need to get a hold of the
manufacture because, on the feathering shaft there was only one bearing with the two
half cages in the blade holder the one with out the bearing had 6 shims. This is bad
and I donít think that the LHS is going to do any thing for me. RTF sure! So who
would be the one to contact?
thanks
lowwing is offline        Reply With Quote Quick reply to this message
Old 11-29-2008, 04:45 PM   #98 (permalink)
Originally Posted by lowwing View Post
Hi Sokal
thanks
www.e-fliterc.com
Old 11-29-2008, 05:09 PM   #99 (permalink)
Hi Sokal
thanks
http://www.horizonhobby.com/ also this place
Old 11-29-2008, 08:08 PM   #100 (permalink)
subscribe
Jasmine2501 is offline        Reply With Quote Quick reply to this message
Tags
read first thread
