Jeti and SK720 BE - HeliFreak
Old 04-16-2015, 12:29 PM   #1 (permalink)
Default Jeti and SK720 BE
What are people using with their Jeti Tx-Rx and 720 BE. UDI or PPM?
Bonkievan is offline        Reply With Quote Quick reply to this message
Old 04-16-2015, 01:24 PM   #2 (permalink)
I use UDI. And have been using it since FW 4 beta testing last year.
Previously, I used to use PPM and it works just as well, but you have one less channel available.
One thing to note, is that when using UDI, your logged GPS altitude and GPS speed data will not show up correctly in the SK data viewing software. It's ok with PPM though.
Groucho_ is online now        Reply With Quote Quick reply to this message
Old 04-17-2015, 12:31 AM   #3 (permalink)
Ok, great. Thanks Groucho.
Old 04-17-2015, 12:47 PM   #4 (permalink)
Any other pros and cons between them or anything else I need to be aware of?
I've never used PPM/UDI, or s-bus for that matter. I've always been Spekrtum with my Skookum and othe FBLs.
Old 04-18-2015, 12:44 AM   #5 (permalink)
PPM pos on all five of mine. Works perfect. One single wire from each RX to the Skook and it is done. I have two R9s, R7, and the rest R3s.
Old 04-18-2015, 12:57 AM   #6 (permalink)
Thanks, Luvmyhelis.
We get the R3L Rx's here. EU cert.
I believe the new REX receivers are due out any week now too, which will make things easier if wanting to run Ppm/UDI plus external telemetry sensors on the smaller Rxs, from what I can gather.
Old 04-18-2015, 01:05 AM   #7 (permalink)
Thanks, Luvmyhelis.
The only telemetry I find useful are the voice warning esc amps, servo bus voltage, signal, and running batt kv's myself. The two most valuable voice warnings let me know if I have any low bec dips during hard flying, and basically lets me know if my main packs are getting dips also. I haven't quite mastered flying purely by used kv yet. So I am still on the timer. I also have about four more telemetry values on the screen, but never do watch them during flights. Only the voice prompts get my attention...
Old 04-18-2015, 01:23 AM   #8 (permalink)
I doubt it will be any easier... It's already as simple as it can be.
The currently available receivers are able to handle PPM/UDI and telemetry just fine.
You simply connect the sensor or expander to the appropriate port on the RX.
Old 04-18-2015, 01:32 AM   #9 (permalink)
Yes, but you can only have one or the other on the smaller Rxs like the rsat2 and R3L without an expander, no?
I guess it will all become a lot clearer once my gear arrives.
Old 04-18-2015, 02:40 AM   #10 (permalink)
I have Rsat 2, R3, R6, R7-nano, R9 and R10 receivers.
They all can equally connect using PPM or UDI, and all have one single EXT port for telemetry.
PPM/UDI and telemetry work at the same time on all.
To add more sensors, you would need an expander connected to the EXT port.
Old 04-18-2015, 02:42 AM   #11 (permalink)
Ok, gotcha. Well, that's better than what I understood. Excellent.
Thanks for clarifying
-edit- Which Rx, out of the Rsat2 or R3L, would you recommend for my 550 with SK720?
I have both on order but haven't allocated them to Helis yet.
Old 04-18-2015, 03:09 AM   #12 (permalink)
If you have a GPS or plan to add one, the R3L would be the better choice, simply because it has extra ports that you can use to power the GPS.
The Rsat2 is otherwise all you need.
Do note that the antenna lengths of the R3L will only be 10cm as opposed to the 20cm on the RSat2. This can be an advantage or a disadvantage, depending on how you plan on mounting the unit.
I have an R6 with 10 cm antennas that is perfect for the model it is installed on...
If you want the RX now though, you have no choice. The R3L is not yet available.
Old 04-18-2015, 03:20 AM   #13 (permalink)
Thanks, Groucho. Yeah, I've got my supplier adding it to my order as soon as the R3Ls arrive. I'm not home for 3-4 weeks, as I'm overseas for work, so hopefully they'll be released before I pay and get everything shipped when I get back. If not I'll just get the US R3 version in the mean time.
Thanks again.
Old 04-18-2015, 04:18 AM   #14 (permalink)
I've just noticed that you mentioned you wanted this for your 550.
The model I mentioned that uses an R6 is in fact my Align 550 heli.
The RX fits perfectly on the top RX shelf (I use the bottom RX shelf for the SK-unit)
I believe only one shelf is included with the kit, so you'll have to purchase another, but it's a minimal expense if you decide to go this route.
I just add some heatsrhink to the antennas, and heat it up while holding them so as to be perpendicular to one another horizontally. It's perfect.
Old 04-18-2015, 04:41 AM   #15 (permalink)
Ok, great. Thanks for the tip.
My 720 is on the top tray at present but no doubt I'll do some rearranging to find the best solution once I get the Rxs in my hand
Old 05-14-2015, 07:14 AM   #16 (permalink)
Hi again,
My DS-16 has arrived but i'm having a few issues in setup between it and the SK720BE. First of all, I can't get the Talon 90 to register High and Low throttle endpoints.
Secondly, I have jittery stop/start cyclic servo actuation. It seems to be worse around center stick eg. When i move collective from full neg through the range to full pos the cyclic seems to stop momentarily around -10 to +10 pitch?
I have updated my Rsat2 to the latest firmware and set to PPM + and changed to PPM in the SK GUI accordingly.
A new model was created in the DS-16 and i've run through the SK startup wizards with all controls showing correct functioning/values etc, including throttle, in the GUI, and also the Jeti.
I've set a Skookum up before but this is my first rodeo with the Jeti, so I am 99% sure I must be missing something within the Jeti setup which is causing both of my issues.
Apart from channel assignments, is there anything else i need to change in the Jeti, from default, to get things functioning correctly?
Any help would be greatly appreciated
BTW- Ironically enough, I have just had the same endpoint issue between a Spirit FBL (running Ex-bus). I did a model reset in the Jeti and ran through setup again and then the ESC endpoint calibration worked??
Old 05-14-2015, 12:09 PM   #17 (permalink)
I'm not using a Jeti, but I have had issues getting ESC endpoints set in the past.
The solution was to first set the throttle channel endpoints to 150% in the TX, then in the SK software set the high and idle stick positions using those increased endpoints. This way you know max throttle range is being passed through.
Then the ESC would calibrate properly, so once again go back and set high and idle again in the SK software so it attributes 0 and 100% throttle to your newly established upper and lower values
Tony
"The helicopter is the most versatile instrument ever invented by man. It is closer than any other of mankind's ancient dreams of the flying horse or magic carpet" Igor Sikorsky
Xrayted is offline        Reply With Quote Quick reply to this message
Old 05-14-2015, 06:48 PM   #18 (permalink)
Thanks Xrayted,
I'll give that a go.
Old 05-14-2015, 07:49 PM   #19 (permalink)
That worked, Xrayted
My ATV's were already at 125% but redid the Gov/Throttle setup in the SK and bingo.....got the high/low endpoint tones at 88% respectively.
My SK program did freeze for 15s or so, before continuing as normal, during the Throttle/gov setup the first time round. I'm just wondering if the Idle/Max throttle setup steps were not written correctly to the unit, and as a result, caused incorrect calibration?
Also, I received some info on the Jeti forum with regard to my Rx programming. I had UDI Direct set, when apparently it needed to be UDI Computed.
So, it may have been a combination of the two fixes....lol.
Anyway, all looks to be working correctly now. Again, thank you Xrayted.
Old 05-15-2015, 07:27 AM   #20 (permalink)
That is great to hear! I'm surprised you had issues already at 125%. For some unknown to me reason the unit just doesn't put out quite high enough throttle signal for you to hit the max that the ESC needs to calibrate in some cases.
It strange that my latest Edge ESC calibrated just fine with 100% end points, yet my previous I've ESC required the full ATV in order to work.
Tony
Human Verification
