Go Back   HeliFreak > R/C Electronics Support > Mikado V-BAR Control
Mikado V-BAR Control Mikado V-Stabi/V-BAR Control Flybarless System Software and Hardware Support
Like Tree5Likes
Old 03-11-2018, 07:28 PM   #441 (permalink)
Default V-Bar control flight analyzer
Iím having similar issue with no ui logs and tribunus. I have the write logs checked and it appears they are being written but instead of being under the batteries they are under the helicopter folder. I think this may be the problem do I have a setting wrong in the vcontrol.
tshelby73 is offline        Reply With Quote Quick reply to this message
Old 03-12-2018, 10:16 PM   #442 (permalink)
Do I need fixed battery ID if not using the battery ID sensor. I have the batteries in the system and I choose the battery I want to use on bootup. Write log file is checked also in tribunus vcontrol app
Old 03-12-2018, 10:36 PM   #443 (permalink)
Fixed battery ID must be used if you want mAh countdown anyway and the analyzer needs to see a battery to log a flight.
VControl
Old hand at Planks
Peter
Old 03-13-2018, 12:14 AM   #444 (permalink)
Hi Linus, Great software. Any chance of adding a hour counter to the model summary that can be reset ? To be used for service intervals.
PierreJoubert is offline        Reply With Quote Quick reply to this message
Old 03-13-2018, 05:40 AM   #445 (permalink)
Before I had fixed battery ID disabled and had both my batteries in the system and set alarms for both. I would initialize and screen would pop up with the batteries and I would choose one. I would then fly and the radio would count down from 100 to 0 percent which would leave 40% left per my settings. When I unplugged the model it would display a screen with the flights performance like mah used min voltage etc.
When I download the log into vbcanalyzer each flight line would have that end of flight log but no uilog for graphing. Looking at the file structure in vcontrolI I would see a sco file under the model for each flight though so I know itís getting written.
So do I still need to enable fixed battery ID for vbcanalzer to see the ui logs. I just turned it on so I will see if it makes a difference next time I fly.
Thanks for the help. This is the last thing I canít get working.
Old 03-17-2018, 03:54 PM   #446 (permalink)
Ok so I cleared the logs in vcontrol for the model and deleted the batteries and started over with new batteries. I have write log selected on tribunus and itís writing the log under my model with same number as the vbar log and when I open it in excel it shows it trended data. So why wonít the analyzer pull in the ui log. Thanks in advance pictures below.
Old 03-17-2018, 04:50 PM   #447 (permalink)
You need the v5.0 analyzer version, the one you have doesn't support the scorpion logs.
Team Only Fine Helis
smwht is offline        Reply With Quote Quick reply to this message
Old 03-17-2018, 05:08 PM   #448 (permalink)
I thought I had the latest it was from the link in the first post.
Old 03-17-2018, 05:13 PM   #449 (permalink)
i'm getting the latest the link is old I see the newest is in the heli part at bottom of post.
Protos 380 Vbar NEO, HW 60A V4, XNOVA 890KV
Raptor E700 700MX 510KV, Castle 120HV w/Vbar Neo Gov 1960
Working on getting Protos max
Vcontrol
Old 03-17-2018, 05:21 PM   #450 (permalink)
Thank you itís working now 🥓
Old 06-11-2018, 12:45 AM   #451 (permalink)
I haven't see the ui logs, too.
Excel files are in the memory card, but analyzer dont see them.
I had an older version... then tried 5.0 and 5.1 but result is the same...
What do you suggest? I want to see a graph, not some numbers in excel
Rasim Ozturk
[PrŰtos Max V2][PrŰtos 380 Evo][OXY3 GL][Vbar Neo][Vbar Control]
rasheem is offline        Reply With Quote Quick reply to this message
Old 06-11-2018, 02:29 AM   #452 (permalink)
The analyzer needs at least a battery and UI logs to pick up the data from the VBC.
VControl
Old hand at Planks
Peter
Old 06-12-2018, 01:33 AM   #453 (permalink)
They are saved in vbc. I can see csv files in the memory of transmitter.
All my batteries are defined, and i select the correct one when i plug it.
Analyzer had displayed ui log graphs before. Same batteries, same everything...
In VBC, write logfile "ON"...
It's definetely a version issue. But i don't know what happened to analyzer lately.
@tshelby73 how did you solve the problem? Mine is same issue with yours.
Rasim Ozturk
Old 06-12-2018, 05:48 AM   #454 (permalink)
My issue was I had the old version of software. The links are old in the first post I had to click on the link in his signature and that took me to the latest. The older version didnít support tribunus logs.
Old 06-26-2018, 06:06 PM   #455 (permalink)
Got a new laptop and installed the latest VBCAnalyzer 5.1. Iím trying to import logs from Vcontrol but get this forever. It stops importing at 11%.
Anybody know how to resolve this?
Heli$ is offline        Reply With Quote Quick reply to this message
Old 07-04-2018, 11:44 PM   #456 (permalink)
Just wondering if the V-Bar control flight analyzer works with VControl Touch?
Wizza likes this.
MarcoSc is offline        Reply With Quote Quick reply to this message
Old 08-20-2018, 05:21 PM   #457 (permalink)
Somehow something is weird with the calculations for flights per week.
If say in week 1 I made 10 flights it counts 11
If say in week 2 I made 9 flights it counts 8
So the total flights is correct, but one flight from the "next" week is added to the previous week.
Sorry I am little OCD to that but I noticed.
Other thing I cannot get working is the csv files logged by the tribunus in the VBC are not available in the UILog column. I use version 5.1.0
I looked into the code but I am too noob to be able to see where things go wrong.
I did manage to consolidate batteries in the sqlite db though. (VBC was formatted and I named batteries different after that although they where the same packs).
Great app. Looks very PRO!
Edit: It seems I have spoken too quickly. Today I imported the flight logs from the VBC and now the UI stats from the tribunus came over. I think I imported first the flight logs with older version of the VBanalyzer and then expected when reimporting with the newer version the UI logs would come over.
Suppose the logic is : get vbar logs, if any new > import, check if there is a UI log with that imported file. So already imported files do not get the UI log... logically..
For the flights per week I still see the thing happen I mentioned before :
Flew today 8 flights and yesterday 10 flights. Should be 18 in this week.
The week bars show 17.
I think nothing to do with monday or sunday start of the week.
tjarde is offline        Reply With Quote Quick reply to this message
Old 08-21-2018, 12:48 AM   #458 (permalink)
Tribunus logs as well as other telemetry logs are dependant on batteries being named and used. Flights perweek depends if your PC is using Monday or Sunday as first day of the week.
VControl
Old hand at Planks
Peter
Old 08-21-2018, 01:52 AM   #459 (permalink)
Did anyone get round to testing if Flight Analyzer works with the new VControl Touch radios?
Mark R
Regards, Mark R (#248)
TRex 700E V-Bar NEO, BLS251, DS8915's, HJive120, JLog, VControl Carbon
TDR 710 CYs, V-Bar NEO, MPH83s, Jive 120, JLog, R2 Buffer, VControl Carbon
Logo600SX 600 CYs, V-Bar NEO, 8715s, Jive120, JLog, R2 Buffer, VControl Carbon
Wizza is offline        Reply With Quote Quick reply to this message
Old 08-24-2018, 07:20 AM   #460 (permalink)
Well I updated the drivers and windows on the new laptop running Win10. I also Reinstalled vbcanayzer several times, and voila it started working great for about a month.
But then all of a sudden it stopped working about 2 weeks ago. The import stalls out at 4% and hangs there. Tried updating laptop and reinstalling VBCAnalyzer along with different USB Cord with no luck.
I love this program and miss it especially with my speed Heli.
Thanks for any help.
