Go Back   HeliFreak > R/C Electronics Support > Mikado V-BAR Control
Mikado V-BAR Control Mikado V-Stabi/V-BAR Control Flybarless System Software and Hardware Support
Like Tree5Likes
Old 08-30-2015, 04:03 PM   #81 (permalink)
Can you check the logfiles manually, it's in the battery folder of the control
Logo 700 | Trex 700X | Logo 600 | Logo 690SX | Gaui R5 | V-Bar Control
V-Bar Control flight analyzer (Win/OSX/Linux) - Latest release v5.0.0 July 5 - 2017
Sleipnir timing system - How fast can you fly?
Only the ground is the limit!
LinusLarsson is offline        Reply With Quote Quick reply to this message
Old 09-02-2015, 07:01 AM   #82 (permalink)
We have a new release of the analyzer, v2.7.0. There are some bugfixes and some new features, the VBLog got some nice changes with both bugfixes and color to easier see problems.
VPlane should be supported now!
There is also a status update when you are importing now, so the program doesn't look like it's stuck.
The new icon is painted by HF member oliver1071, Thanks dude!
As always, the newsets release can always be found here:
https://github.com/Lussarn/vcontrol-...lyzer/releases
The file has changed name to VbcAnalyzer.exe
Peace!
Old 09-03-2015, 03:10 PM   #83 (permalink)
Sorry for my late reaction, work work work.....
I did what you ask, and in this folder it also says 23-07-2015.
I can't understand why. the computer time/date is okay. the transmitter time/date is okay.
if i could make a picture of it i would do that but my uploads are to big...
now i make a connection with vbar control synchroniser and the transmitter will update, and than waiting for my next fly session.
tf-zuid is offline        Reply With Quote Quick reply to this message
Old 09-03-2015, 11:59 PM   #84 (permalink)
@tf-zuid
You got a PM
Old 09-04-2015, 07:55 AM   #85 (permalink)
This tool has been invaluable.
I've been having trouble with my OXY 3 and wouldn't have noticed without your program. Before you made this tool I wasn't monitoring my logs at all really.
I think I've narrowed it down to a servo pulling to much power on initialization. You can't even notice in flight but I'm sure eventually something will fail.
It's so nice to be able to pull all of the logs from the flights and see if the problem is resolved.
__________
Goblin 380, 500, 570, Mikado 690SX, 480Xx(Stretched 500) , Protos Mini, Max V2 , Oxy 3, Vbar Control/Neo Vlink (Citizen 758)YouTubeProgress:http://tinyurl.com/oliver1071
oliver1071 is offline        Reply With Quote Quick reply to this message
Old 09-04-2015, 03:49 PM   #86 (permalink)
Just noticed the colored lines in the vbar log very nice to quickly see the problem areas.
__________
Old 09-04-2015, 03:55 PM   #87 (permalink)
Thanks, It's all about the small things
Old 09-15-2015, 03:18 AM   #88 (permalink)
Hello flight analyzer users!
I have a small release with some minor updates.
The scanning of the USB attached VControl is reworked once again.. Should work better.
The UI Log window will now enlarge/shrink the graph when you enable/disable values to show.
As always, the release can be downloaded here, v2.7.1.
Old 09-15-2015, 09:54 AM   #89 (permalink)
Maybe a silly question, but can this do anything without the current sensor installed? I'd like to get rpm/pwm logging over a flight if that's possible. If not I may have to go order some sensors...
Team Only Fine Helis
smwht is offline        Reply With Quote Quick reply to this message
Old 09-15-2015, 10:00 AM   #90 (permalink)
Not a silly question, but you are going to have to order some sensors The UI sensor is the base of which this program stands on.
It's worth it, once you start to fly by capacity instead of timer there is just no turning back.
If you enjoy have everything automatic and correct by doing nothing also consider the Battery ID, It will not fit small models but 500 and up should be no problem.
Old 09-15-2015, 01:46 PM   #91 (permalink)
My wallet was afraid of that
Secondary motivation was it'd be cool to see rpm logs for my nitros, but I guess that isn't going to work.
Old 09-15-2015, 01:52 PM   #92 (permalink)
well if you had the amp sensor and an rpm sensor wired to the neo wouldn't you get the rpm logs? Just guessing here don't have a nitro but it would make sense since I run a hobbywing sensor for rpm I'm sure the neo doesn't care what's feeding the rpm info.
__________
Old 09-15-2015, 02:00 PM   #93 (permalink)
I'm pretty sure that would work, it just seems a bit of a waste to use a $100 amp sensor to get rpm logs... but who knows. I'll probably throw one on my 700 electric and see if that changes my mind about doing it on the nitros. I was mostly hoping there was a way to log the RPM data I already get on my vcontrol without having the UI sensor installed.
Old 09-15-2015, 02:23 PM   #94 (permalink)
Yeah wasn't thinking about that. That is true kind of a waste it's a shame it doesn't log all of the other bits without the sensor. Guess you could utilize it for voltage and amp draw on your bec or rx lipo to give you some information there.
__________
Old 09-15-2015, 02:30 PM   #95 (permalink)
I amy be wrong but I think it will still do rpm. I will make sure when I get home. I had a few flights without the U/I sensor.
Lynx Team Test Pilot
Heli's :, Gaui X3, Logo 480,
Vbar Control
Lu523 is offline        Reply With Quote Quick reply to this message
Old 09-15-2015, 04:27 PM   #96 (permalink)
I was wrong. It will not show the rpm.
Vbar Control
Old 09-18-2015, 04:55 PM   #97 (permalink)
Small teaser of what will come... Present your models in style!
Don't wait up though. Next big version will be next year...
Old 09-18-2015, 06:24 PM   #98 (permalink)
That's terrific! Just when I thought it couldn't get any better.
__________
Old 09-19-2015, 12:58 AM   #99 (permalink)
CHC Benefactor
Wow. This s/w could make the difference on someone's next Tx purchase. Well done!
Old 09-24-2015, 12:56 AM   #100 (permalink)
i've been flying VBC and I/U on a number of models for a while, but I just tonight got around to using this tool.
Dude. Totally rocks.
Thanks very much for it.
PRTOS 500 Plastic, Logo 550SX/600SX, PRTOS Max2 up and flying!
Team MSH USA, Team Cyclone, Team Xnova
trickybit is offline        Reply With Quote Quick reply to this message
