Go Back   HeliFreak > R/C Electronics Support > Mikado V-BAR Control
Mikado V-BAR Control Mikado V-Stabi/V-BAR Control Flybarless System Software and Hardware Support
Like Tree1Likes
Old 05-31-2015, 06:33 PM   #1 (permalink)
Default VControl Setup Vids
First ones done....more to follow!
Mikado V BAR CONTROL Upgrading Existing V BAR's From V5 3 6 0 V BAR CONTROL 2 (4 min 16 sec)
Mikado V BAR CONTROL Registering Loading Apps Final Check Before Usage (9 min 2 sec)
MikadoUSA Tech Support
Laughingstill is offline        Reply With Quote Quick reply to this message
Old 05-31-2015, 09:02 PM   #2 (permalink)
THANKS RON!!!!!
That's AWESOME!!!!!
Just in time for my NEO install and setup with VBar Control.
Old 05-31-2015, 09:31 PM   #3 (permalink)
Nicely done!
logo 600sx, 480, vcontrol ..mcpsbl
Dsss is offline        Reply With Quote Quick reply to this message
Old 05-31-2015, 11:13 PM   #4 (permalink)
Save time to read. Gj
GOBLIN 500, 570 : Dt520e v2 : X5 : innova 550 :
VBAR CONTROL : MINI VBARS : Scorpion : JR : MKS : Hobbywing :
ikon is offline        Reply With Quote Quick reply to this message
Old 06-01-2015, 05:29 AM   #5 (permalink)
Make this a sticky.
Screw It, I'm gonna fly.
In search of a 500-600 sized heli.
Preferably rtf with vbar.
povern is offline        Reply With Quote Quick reply to this message
Old 06-09-2015, 06:43 AM   #6 (permalink)
I second that, Sticky please!
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 06-10-2015, 01:50 PM   #7 (permalink)
+3 Sticky
OptiFuel TEAM PILOT
busterboy is offline        Reply With Quote Quick reply to this message
Old 06-10-2015, 03:20 PM   #8 (permalink)
+ 4 for sticky
Great vids.
Team Rail blades,
Team Scorpion motors,
V-Team
ClubCRASH is offline        Reply With Quote Quick reply to this message
Old 06-13-2015, 03:39 AM   #9 (permalink)
Thank you, these have been very handy yesterday, I just got my VControl.
Kontronik Jive setup tip. On the second step of wizard, pull the jumper from the ESC immediately after hearing 3 beeps after powering heli up. If you wait for the wizard message screen to show up it will be too late and Jive will not enter programming mode.
I got caught by this (and a couple of other people too).
Basically, second step of ESC wizard just sets a 0-100 throttle curve, so Jive can be programmed.
TDR/VBar
Logo 600SX 12s VBar
MSH MINI PROTOS/CGY750
AcidDrink is offline        Reply With Quote Quick reply to this message
Old 06-13-2015, 07:17 AM   #10 (permalink)
Thank you for the video's they were very helpful as a new Vcontrol owner
Still trying to figure out the Castle Creations esc setup. I typically lower the endpoints then increase them until it beeps then two clicks more. Seems like when I select other esc wizard it just does the high and low stick there's no radio endpoint adjustment.
I'm not sure if the process is working correctly because after it completes it kicks the vbar into external governor mode and I have to select vgov again.
Maybe I'm over thinking it and just need to turn on the esc at high stick and then lower it for the low stick adjustment.
__________
Goblin 380, 500, 570, Mikado 690SX, 480Xx(Stretched 500) , Protos Mini, Max V2 , Oxy 3, Vbar Control/Neo Vlink (Citizen 758)YouTubeProgress:http://tinyurl.com/oliver1071
oliver1071 is offline        Reply With Quote Quick reply to this message
Old 06-13-2015, 09:17 AM   #11 (permalink)
Never mind if I'm reading the Vstabi site correctly no end point calibration is required when using Castle ESC's. That's good because there's no way to accomplish this with the VControl that I can find.
__________
Old 06-13-2015, 07:51 PM   #12 (permalink)
Actually there is an esc endpoint calibration tool under setup/gov setup. Puts a linear throttle curve on the collective stick and gives you endpoint adjustment. While it may not be required with Castle radios I used this tool to fine tune mine.
Old 06-14-2015, 04:18 PM   #13 (permalink)
I have a quick Vbar satellite question. I'm not home, so I can check tomorrow, but I thought I'd just ask first. Can I simply swap a satellite back and forth between vbars without any binding or programming? Basically in theory could I bring 2 planes and a Heli to the field and simply plug in the satellite in the airframe I want to fly? I'm kind of thinking I can, and that all the pertinent information is just stored in the Vbar itself!
Got a pm reply, yes you can, sorry for posting in a sticky, it was an accident, I can remove this post if desired.
jakeg1999 is offline        Reply With Quote Quick reply to this message
Old 06-21-2015, 12:47 AM   #14 (permalink)
Thanks Ron! For this VBar Control newbie, SO much easier than trying to discipher the manual! This was great!
SurfCity is offline        Reply With Quote Quick reply to this message
Old 08-29-2015, 05:12 AM   #15 (permalink)
Fantastic, lot of effort gone into these vids.
George
George J is offline        Reply With Quote Quick reply to this message
Old 08-29-2015, 11:39 AM   #16 (permalink)
Castle setup is to come soon, then nitro
Old 09-01-2015, 06:47 AM   #17 (permalink)
Castle vis added! Video done by our Mikado USA Team Pilot Norman Ross:
Castle Edge ESC Vbar Setup (6 min 51 sec)
Old 12-25-2015, 02:59 PM   #18 (permalink)
Nitro YES will be setup the radio up next week
Great Job Ron
Following Jesus !!!!! My Lord, He Never changes!
1#SAB RAW Scorpion Tribunus V2 200A ,
NEO-Vcontrol Touch,The only Way to Fly!
2#SAB RAW Scorpion Tribunus V2 200 A
Helicrazy2 is offline        Reply With Quote Quick reply to this message
Old 12-31-2015, 11:36 PM   #19 (permalink)
Ron, been watching your videos over and over, getting ready for 1 now! Now that i have my 690 all setup neo is bound with dx9, if ever do i need to get my servo horns out again for setup with the vbar... Like a fresh start setup using the same neo..? Thanks and pardon my stufydity...
doubletap is offline        Reply With Quote Quick reply to this message
Old 01-02-2016, 05:40 PM   #20 (permalink)
If you have the servos set geometrically correct, no need to redo them. Just go through the setup and all will be good
