KDE 600xf 1100 10 pole vs 8 pole, what is difference? - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > KDE Direct Upgrades and Accessories
KDE Direct Upgrades and Accessories KDE Direct Upgrades and Accessories Factory Support Forum
Old 06-04-2015, 02:37 PM   #1 (permalink)
Default KDE 600xf 1100 10 pole vs 8 pole, what is difference?
I seen both.
What are the pros and cons for each.
What is the difference?
KingJoe is offline        Reply With Quote Quick reply to this message
Old 06-04-2015, 10:29 PM   #2 (permalink)
10 pole motor is the new 3rd generation (G3) version and the one you want. Even more powerful and efficient than the older 8 pole versions.
I have a 600XF-1100-G3 in my Logo 550 and it's powerful and efficient. Great flight times when I stay out of the collective and cool running no matter what. 8 flights back to back today and motor never exceeded 132F (219 max amps today on 6S). Air temp was 89F.
Jay - Diligentia, Vis, Celeritas
Lynx / OXY Team Pilot, Zeal Team Pilot
jmackey is offline        Reply With Quote Quick reply to this message
Old 06-09-2015, 06:28 AM   #3 (permalink)
jmackey,
Hello to you, would you mind sharing your setup for the 600XF-1100 G3 as I fly my in a E5 with a Castle 120 ESC and both motor and ESC are "very hot" temps are in the 160 degree range for both. I fly mild 3D fights 3:30 on the timer.
thanks
MA Furion 6, LHS Setup
MA Fury 55: Futaba BLS 251, BLS 451, CGY 750, FGH12, OS 55 HZR, Hatori
Synergy E5S: CGY 750, 14SG, KDE Direct
Forza 450: Xnova, CGY 750, 14SG, MKS
rtnaviman is offline        Reply With Quote Quick reply to this message
Old 06-09-2015, 09:40 PM   #4 (permalink)
I'm using a Kontronik Jive Pro 120 on this heli with timing set to auto, Ri-Comp at 007 to match the motors internal resistance and P-Gain set to 7 now. 12T mod1 pinion and 106T main gear. +-13 degrees collective running 82% throttle @2250 headspeed now. 6S-4400-60C Revolectrix packs.
Is the 160F on your ESC the high temp in your logs? If so, that's not really that bad. I don't get too concerned until I'm pushing over 185 on ESC. 160F on motor isn't excessive either. Patrick may chime in, but I know it's designed for significantly higher temps than that. Maybe you would benefit from cooling holes in canopy?
I just cut a new cooling hole in my Logo 550 tonight as summer is definitely here in the Midwest now.
What is your gearing and headspeed? 6S?
Human Verification
