Go Back   HeliFreak > R/C Electronics Support > EZNOV
EZNOV EZNOV Support Forum
Like Tree23Likes
Old 06-22-2015, 04:53 AM   #1 (permalink)
Default EZnov Neuron
EZnov is very (VERY) proud to annonce its new line of flight controlers 100% made in France (designed and produced in France in our office).
It's composed of two flight stabilizers of the latest generation :
NEURON
Hardware :
  • Latest generation, 9 axis sensor (MPU-9250)
  • Latest generation STM32F4 microcontroler with floating point unit
  • Rock solid power stage (no more sat locks) up to 8.4V
  • Very small : 23.15 x 34.5 x 13.6 mm
  • 6.7g weight
  • External USB connector for more installation flexibility (cable and adapter provided in the box)
  • Unplug the USB adapter and you can plug a Bluetooth module instead (same cable).
  • 3 bottom case colors to customize your unit (time limited offer)
  • Every connector is electrically protected
  • 3M Very High Bond double sided pad provided
Features:
  • Handles (via different firmwares available to everyone without additional cost) all size helicopters, quads and planes with the same level of performance.
  • Built-in RPM governor
  • One built-in sat connector with smart bind (no bind plug nor PC needed to bind)
  • You can connect a second sat via an adapter
  • Handles all serial output receivers (HoTT, SRXL, SBUS/SBUS2, JR XBus Mode B and Mode A, PWM sum of course, plus DSM2 and DSMX sats), one wire per channel receivers are supported through an adapter (e.g. SBUS)
Software:
  • Extreme performance, incredible feeling
  • Setup and tuning as simple as possible
  • FREE setup terminal on PC (USB and BT) and Android (BT), all features availables, including firmware update, load/save configuration (compatible files between PC and Android)
  • iPhone software is work in progress, via a specific Bluetooth Low Energy device available later
  • Receiver auto-configuration, the unit detects the receiver type and configures automatically the channel assignment, throws, neutrals, reverses, etc at each startup.
  • Each firmware type (quad, heli, plane) has its own GUI, software user interface is totally adapted for each model type
  • Upgrading firmware doesn't mean upgrading PC / Android software. You can upgrade one unit's firmware and keep another one on a previous firmware, each one will have the adequate user interface.
  • RPM governor auto-configuration, ne need to set gear ratio, etc. just plug the sensor, setup a flat throttle curve and fly (both nitro and elec)
  • Rescue mode for helis, with pitch management
  • Self level mode for quads and planes
Introductory pricing: 130€ (approx $150)
Available: VERY SOON (production already started!)
AND BIG BROTHER WITH NO OFFICIAL NAME YET
  • ULTRA POWERFUL latest generation microcontroler STM32F4 with floating point unit
  • 10 connectors for a high power installation and plug tons of servos
  • 2 smart bind sats connectors
  • Support for H4 helis, hexacopters, octocopters, planes with multiple servos per function, etc.
  • Built-in barometer (altitude hold)
  • Support for external GPS (position hold)
  • Built-in FLASH memory for complete logging of any flight parameter, and analyse them directly in the software
Available in: a few months
Otatiaro is offline        Reply With Quote Quick reply to this message
Old 06-22-2015, 05:19 AM   #2 (permalink)
Excellent news!
A few questions:
1) how much for the Bluetooth module? Is it proprietary?
2) what will the long term support look like? (What I'm getting at is: are you an owner of this company, or is this a contract job which could lead to a similar situation as with msh?)
3) any flight videos?
4) I assume this won't be possible due to legal issues, but any chance of importing configurations from brain units?
FOR NO FREE APE DIES
Gaui X3/Gaui X5/Goblin 570 KSE/Goblin 630C/Thunder Tiger Raptor 50
Citizen 717
ian.newson is offline        Reply With Quote Quick reply to this message
Old 06-22-2015, 05:25 AM   #3 (permalink)
Hello,
1- CRIUS BT units for Android and PC, nothing proprietary, the Low Energy device has to be specific though (there is no serial port profil like in BT) so we'll manufacture them.
2 - I joined the company on April 2015, but this time it is for a loooong time, and yes I'm co-owner of it. I'm officially R&D director.
3 - Yes, I'll post a few in the coming minutes
4 - Nope, both legally, and because this unit has no common DNA at all with the BRAIN/iKon (not a single line of code).
Thomas.
Old 06-22-2015, 05:33 AM   #4 (permalink)
A few videos :
Nicolas Lorion:
Nicolas Lorion with the goblin 700 (3 min 57 sec)
JÚr˘me Laguionie:
Easy-Heli: Pilot Jerome LAGUIONIE Xnova Motor , Optipower And RotorTech Team (4 min 24 sec)
XNOVA MOTOR DEMO : Pilot Jerome LAGUIONIE motor XTS 2618-1360kv (3 min 24 sec)
KÚvin (quite hard to follow !!!) :
Neuron EZnov - Drone Quad Warthox "Kevin", Hauconcourt le 21/06/2015 (4 min 18 sec)
Tof:
Neuron EZnov Rescue - Goblin 500 "KoRn" - Test 2 (2 min 30 sec)
Neuron EZnov Rescue - Goblin 500 "KoRn" - Test 1 (3 min 45 sec)
Thomas.
Old 06-22-2015, 06:57 AM   #5 (permalink)
I have been looking for a newer fbl to replace my brains, ordered some Neo's but haven't got them yet. I think I may just cancel my order and wait for EZnov.
waxman is offline        Reply With Quote Quick reply to this message
Old 06-22-2015, 07:32 AM   #6 (permalink)
Good on you for pursuing the BLE solution on iOS. I wish other companies would do that.
HeliFreak Support
Graupner MZ-32
Old 06-22-2015, 07:34 AM   #7 (permalink)
Congratulations Thomas,
I know its been a while in the works. I am ready for a couple new FBLs and you could not have come at a better time.
Sign me up for a pre-order
I'm in!
OXY3+Qube,4s/OXY MAX 380/OXY 5 MEG 7s
Diabolo 550/600/700BE Triabolo800
MSH-Brain Jeti DS16
OXY rep/Lynx team pilot
ctzn526
crickr1 is offline        Reply With Quote Quick reply to this message
Old 06-22-2015, 11:06 AM   #8 (permalink)
Hello,
I just posted the wiring diagrams for the 3 model types.
https://www.helifreak.com/showthread.php?t=701158
Thomas.
Old 06-24-2015, 07:56 AM   #9 (permalink)
Neuron Test chassis Warthox (6 min 24 sec)
Old 06-25-2015, 12:15 PM   #10 (permalink)
Great to see the progress!
aterren is offline        Reply With Quote Quick reply to this message
Old 06-25-2015, 12:18 PM   #11 (permalink)
Hello,
I'm working on quadcopter firmware instructions.
The goal is to answer any question a beginner could ask.
That's a lot of text to write and translate !!!!
Thomas.
Old 06-25-2015, 02:25 PM   #12 (permalink)
Is it have self level for heli
jangee is offline        Reply With Quote Quick reply to this message
Old 06-25-2015, 03:23 PM   #13 (permalink)
Good to see you back Thomas. Looks like an exciting product.
How much current can the Neuron bus handle? Enough for fast, strong servos on 360 class helis? 500 class? 700 class?
Catalyst Machineworks
Citizen 529
Rotorious is offline        Reply With Quote Quick reply to this message
Old 06-25-2015, 11:00 PM   #14 (permalink)
Do you have any plans for Jeti integration?
markrj is offline        Reply With Quote Quick reply to this message
Old 06-26-2015, 03:41 AM   #15 (permalink)
Hello,
@jangee : heli firmware has rescue mode
@iammenotu : the PCB bus can handle 10A continuous without problem. Servo connectors can handle 3A continuous each (standard for servo connectors). So basically no problem up to a 600 size heli with beefy servos doing hard 3D, then you can use a mini power bus to have 2 power input to the bus and it's ok up to 800 size with any servo, etc.).
@markrj : not yet, but this could be interesting. As you can see on KÚvin's video, Bluetooth is easy to use (auto reconnect, etc.) though.
Thomas.
Old 06-27-2015, 05:24 PM   #16 (permalink)
Is there a web site up yet, Im in the market for a new FBL right now, my only concern it will be the tail holding, I believe that this has the same developer as the MSH brain, which I had 4 of eventually, but the tail was always far to complex compared to the Spartan Vx1e or Bavarian Demon 3sx.
Any sign this will be easier than the Brain / IKON, also do we have some indication or when its available or site to back order please.
Compass 550 ULT, Eznov Neuron | Thunder Tiger e700 Mini Vbar | Thunder Tiger G4 e820 SPARTAN (Committed suicide)| DX8 #286
Stevewashere is offline        Reply With Quote Quick reply to this message
Old 06-29-2015, 08:45 AM   #17 (permalink)
Does the rescue function use accelerometers or programming code?
Lynx Team Pilot
Colonny5 is offline        Reply With Quote Quick reply to this message
Old 06-29-2015, 08:49 AM   #18 (permalink)
Hello,
@Stevewashere: it's coming, will probably take a few more days before eveything is available.
@Colonny5: well, both ... accelerometers are used in conjunction with gyroscope to get the best "feeling" of where the earth is. We designed our very own sensor fusion algorithm.
Thomas.
Old 06-30-2015, 04:04 AM   #19 (permalink)
I think he means that if you are in FFF and use the rescue function, will the Heli still be in FF or will it break?
I think this would be useful when you're using the rescue funktion while youre flying into your position...
Sorry, I don't know if this can be realized with the actual hardware...
freakystylez is offline        Reply With Quote Quick reply to this message
Old 06-30-2015, 04:26 AM   #20 (permalink)
Hello,
Ok. Neuron uses accelerometers for rescue so what it does is to put the heli level (few degrees tolerance) and make it climb to give you enough room.
Stopping the heli requires a GPS, this will be available on the big brother using external GPS.
Thomas.
