Go Back   HeliFreak > R/C Electronics Support > Futaba Radios and Electronics > 2.4G Futaba Radios
2.4G Futaba Radios Futaba 2.4G Radio Help and support forum
Like Tree2Likes
Old 10-17-2017, 10:56 PM   #21 (permalink)
Since this is Futaba and EFG thread, maybe some setup suggestions such as cutoff alarms and such.
For those who didn't know and may be struggling, I had to switch from 12 channel to 14 to get the sensors to show up in sbus 2 port.
Took me a bit of back and forth to recall that detail.
How or why did I wait for this feature..................
Steve
smittylube is offline        Reply With Quote Quick reply to this message
Old 10-18-2017, 09:52 PM   #22 (permalink)
Gained about 2 more minutes + of flight time knowing the mah used.
Also has amps so for the first time I saw what I pull max in a flight.
Steve
Old 10-21-2017, 09:21 AM   #23 (permalink)
You guys have inspired me, I want to start playing with one of these. How big are they, and how much do they weigh?
My only electrics are Oxy2 and Oxy3, everything else is IC with LiFe receiver packs. So, 10A is too small, hope 150A isn’t too big...
I have a 14SG TX, need the smallest RX with telemetry, is that the R70003SB?
How do you make a small fortune in this hobby?
Start with a large one!
HelisRock is offline        Reply With Quote Quick reply to this message
Old 10-24-2017, 12:31 AM   #24 (permalink)
The website lists the 150A “Large” as 42x44mm, but doesn’t list the size of the standard...
Old 10-25-2017, 07:45 AM   #25 (permalink)
Not sure if the small one would work.
Yes 7003sb link in 14 ch mode.
Just put it in my logo 600 stretched. Works excellent. Easiest install and setup yet. 1/2 minute longer flight.
I found the different chargers will charge slightly more or less than recorded mah. Only slightly. Not more or less than 100 ma so far.
This is the ones I bought.
http://shop.tje.dk/catalog/product_i...gdj9h5541j37e4
Steve
Old 10-30-2017, 10:52 PM   #26 (permalink)
Hi Steve,
How big is the 150A? I asked on the website a week ago and never got any response..
Old 10-31-2017, 09:59 PM   #27 (permalink)
I have one I have not installed yet. you can try if you want. I'm in scotts valley 2 miles from Santa Cruz. Close to Silicon Valley.
You can see the size of it. It's about 1/2 the size of the 7003sb.
We can set it up in my shop and even fly them outside. You could just buy one to replace it, or take it off and I'll use it.
I'll show you how to set it up also. Really easy when you've done it a few times.
Steve
Old 11-02-2017, 01:58 PM   #28 (permalink)
I ordered one,
Anyone know shipping time to the states?
Gaui x5, x5 - Ikon, x7, x7 - CGY750, 14SG
FAA Reg # "DRONESSUK"
DanMcN is offline        Reply With Quote Quick reply to this message
Old 11-03-2017, 06:23 AM   #29 (permalink)
Maybe a week. I just got a couple things from him and it was about a week to get them. Thomas is a great guy to work with and makes great stuff too!
My custom charging case build
RCHN #633
Grimmy is offline        Reply With Quote Quick reply to this message
Old 11-03-2017, 07:37 PM   #30 (permalink)
Yeah, it was about a week for me, too.
Team Synergy Field Rep, Rail Blades
Rodney Kirstine is offline        Reply With Quote Quick reply to this message
Old 11-14-2017, 12:37 PM   #31 (permalink)
Electric Fuel-Gauge Presentation and Instructions (10 min 39 sec)
Old 11-16-2017, 08:05 AM   #32 (permalink)
I didn't like soldering 10g wire to the connectors, the board got hot fast. Since my esc wires are short from the connector I installed it on the cross over wire between both packs. It only reads one pack voltage but do not need the info.
Finally muddled through the 14sg slot and telemetry setting up the e-fuel.
Question,
14sg telemetry on the return/home screen, am I limited to two displays? I currently have Ext and RX volts indicated through the reciever. I can change return/home screen to see the e-fuel. I'd to see Ext, RX and MAH. Is there a way to see all three?
Never been a fan of telemetry/interrogation, most of it is kind of like needing to know the extract tire pressure of your auto. Needless back ground noise. But I think I'm going to like this once I figure out the mah numbers.
Old 11-16-2017, 08:10 AM   #33 (permalink)
Check the firmware version on your 14SG. I know the latest allowed you to view up to 4 telemetry, rather than the 2. That's how mine was and then I updated it.
RCHN #633
Old 11-16-2017, 03:33 PM   #34 (permalink)
Thanks!!!
Old 11-21-2017, 11:49 PM   #35 (permalink)
I found it really helps if you want to do a bunch of autos. The timer kicks off yet you still have fuel left so you keep going back up!
Steve
Old 11-27-2017, 03:38 PM   #36 (permalink)
E-fuel was nice enough to solder wires less connectors. So i'll be adding mah to several others heli's. I gained a minute of flight time on my x7 with the alarm set to 3200, land 3300+-. Batteries are around 40% with new 5000 gensace. My older but won't die nanotech 5000 come down at 20% so moved the alarm to 3100.
Human Verification
