Go Back   HeliFreak > R/C Helicopter Support > Scale Helicopters > Power Systems
Power Systems Power Systems Discussion
Old 07-12-2015, 06:31 PM   #1 (permalink)
Default Motor for Trex 500 with 5 blade head
I am starting to get all of my parts to build a scale AH-6 Little Bird out of my Trex 500 ESP. I've seen several builds where people have changed out the motors on their helis to accommodate the lower head speeds of a five blade system. The popular motor seems to be the Scorpion 3026 -1210KV and a 12 tooth pinion. So, I ordered one from gobrushless.com, and received a message saying that there was an inventory error, and they didn't actually have any. Instead, they have offered me 2 Scorpion 3026-1000KV motors for the price I paid ($109) or a full refund. Is this a good deal? Will it run the 5 blade head fine or should go with another motor?
EnstromPilot is offline        Reply With Quote Quick reply to this message
Old 07-14-2015, 03:10 AM   #2 (permalink)
Do your math....
RPM = Kv x Volts x 0.9 x pinion tooth count / main gear tooth count
Thus will give you 100% RPM at the end of the flight...
Depending on the ESC you want to set up around 90%... so count that in the equatuon.
I don't have a 5 blade head but would figure that you want around 1300 RPM (someone please correct me if I'm off here) and go from there...
Gh
goodhunting is offline        Reply With Quote Quick reply to this message
Old 07-14-2015, 04:35 AM   #3 (permalink)
I would think that 1300rpm for a 5 blade 500 size might be a bit low - better for a 5 blade 600 size.
I would suggest around 1600rpm as a starting point for a 5 blade 500, and try to get lower. I run my 2x 465mm UH-1N at 1700rpm, and it flies well.
RPM = 1000 x 22.2 x 0.9 x 12T / 162T = 1480rpm at 100%, so a bit low, but a 14T would give you 1726rpm at 100%, so governing to 1600rpm would be running the ESC at 93%, which is fine.
I would say get the 1000kV motor.
This assumes you have a 500 with a 162T main gear and straight cut Mod 0.6 pinion.
Colin
Vario Long Ranger 700e
Seahawk 600
UH-1N 500
Baumann EC-145 800+ (coming soon )
Andy01 is offline        Reply With Quote Quick reply to this message
Old 07-15-2015, 06:04 PM   #4 (permalink)
Thanks for the formula and the help! This is my first heli in which I haven't used the stock power system, so the calculation is new to me. I went ahead and got the 1000kv and a 14T pinion. Can't wait to get my Little Bird up and flying!
Old 02-04-2016, 09:42 AM   #5 (permalink)
I'm having a hard time finding any of these motors for my Trex 500 scale project. Any body have an "in stock" source for motors in the 1000kv-1210kv range?
-Jon
JonU is offline        Reply With Quote Quick reply to this message
Old 02-05-2016, 07:32 AM   #6 (permalink)
Default Savox 1200kv motor
This is what I have on my UH-1 project installed on a Trex 500. It seems to be a good motor and does the job just right. Spinning 480mm Zeal blades with a 13T pinion.
http://www.savoxusa.com/Savox_BSM375...m3750p1200.htm
TACO88 is online now        Reply With Quote Quick reply to this message
Old 02-05-2016, 03:44 PM   #7 (permalink)
Thanks Taco88!! Looks like a pretty nice motor and the price isn't as bad as a Scorpion (IF they still made what I'm looking for).
How about the 4050 version below? I can't imagine that for scale, the additional $60 would be worth it.
http://www.savoxusa.com/Savox_BSM405...m4050p1200.htm
Old 02-09-2016, 12:52 PM   #8 (permalink)
Default Savox motor
I checked the specs of both motors and they have similar specs ,continuous 1800 watts, Current 99 amps and 1200kv. The cheaper BSM3750 should do just fine.
