Go Back   HeliFreak > R/C Electronics Support > R/C Related Electronics DIY
R/C Related Electronics DIY DIY R/C Electronics for tinkerers and the budget minded
Old 08-17-2015, 06:34 PM   #1 (permalink)
Default Dell NPS-700AB
I purchased a Dell NPS-700AB to use for my charging station. I followed the write up I found here http://www.tjinguytech.com/my-projects/server-ps. I connected the three pins but when I power the unit I am only getting .0026v from the positive and negative poles. The fan is working and I get the green light showing its plugged in and the yellow light that has a symbol of a triangle with a lightning bolt inside. I am hoping someone else has used this supply before ad may shed some light on this issue and help me get this unit powered properly.
Oxy 3 (6s) MSH Brain -Compass Atom 500 (6) Beastx - Align Trex 450 Pro DFC (3s) GPro - Align Trex 250 DFC 3Gx - Compass Warp 360 (6s) Beastx - Compass Atom 5.5 (6s) Beastx - Compass 550 Ultimate (6s) Tracx FBL
heliphlier is offline        Reply With Quote Quick reply to this message
Old 10-30-2015, 01:58 PM   #2 (permalink)
The yellow LED indicates a fault someplace and the PS has shutdown its output.
It could be a short or something.
First, disconnect the PS-ON and the PS-KILL pins and check to see if the yellow LED is off.
If it is off, then means the fault is in the 12v output side.
If it is on, then the PS may be toast
If it is off, then check you soldering job and make sure you are not bridging pins together.
I'll post a picture of my Dell NPS-750 power supply. They are pretty much all the same
ticedoff8 is online now        Reply With Quote Quick reply to this message
Old 10-30-2015, 02:57 PM   #3 (permalink)
I use the dells as well.
B1&A1 to B6 turn it on. B2 to PB1 slow down the fan.
__________
Goblin 380, 500, 570, Mikado 690SX, 480Xx(Stretched 500) , Protos Mini, Max V2 , Oxy 3, Vbar Control/Neo Vlink (Citizen 758)YouTubeProgress:http://tinyurl.com/oliver1071
oliver1071 is offline        Reply With Quote Quick reply to this message
