Go Back   HeliFreak > R/C Electronics Support > Mikado V-BAR Control
Mikado V-BAR Control Mikado V-Stabi/V-BAR Control Flybarless System Software and Hardware Support
Like Tree2Likes
Old 08-23-2015, 10:34 PM   #1 (permalink)
Question RC Input Packets Lost / RC Failsafe activated
During a routine flight today. My heli just cut off midair. Fortunately I was able to auto down.
Looking at the the logs I have the two entries that stood out to me and explain the cutoff
  • RC Input Packets Lost
  • RC Failsafe activated
What would cause this? What can I check to prevent this in future?
I am using V-Control with NEO on a Trex 700. NEO mounted inside the canopy on trex gyro mount on the nose cone
Has this happen to anyone else besides me? If yes what did you do?
Thanks,
cbrkhan is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 01:07 AM   #2 (permalink)
It sounds like the tx lost connection to the receiver. That's the only real explanation for a failsafe.
Heli's I have:
Goblin 500 (Vbar Neo), Gaui X5(Vbar Neo), X7(Vbar Neo), Innova 600 Night heli (Vbar Neo Vbar Vcontrol
I'm the not so newbheliusr as I have been here a while. But I like this name.
newbheliusr is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 05:29 AM   #3 (permalink)
Any power losses? Can you post all the logs?
MikadoUSA Tech Support
Laughingstill is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 07:54 AM   #4 (permalink)
Default RC Input Packets Lost / RC Failsafe activated
No power loss at all. When I lost power mid flight .... I instinctively hit throttle cut (security) as well and autoed down ... Once on the ground after a brief inspection of the wiring and all heli spooled right back up .... Between the auto ,cut and spool up ... I did not disconnect the batteries or turn off the radio
Now I will need to figure out how to get he logs out of the radio and post here
Old 08-24-2015, 01:35 PM   #5 (permalink)
(1) Connect to the computer
(2) DO NOT open the VControl manager
(3) Wait for the VControl icon to show up on the computer
(4) Click it
(5) Open the "logs" file
(6) Find the file you need
(7) Save it
(8) Post it here..................Ron
Old 08-24-2015, 10:29 PM   #6 (permalink)
Cant seem to figure out how to attach a *.log file ....below are complete flight logs when I experienced mid air cut off.
VBar Start -- Trex 700 -- 23.08.2015 -- 19:26:18
19:26:19;1;Reset Reason: Power On
19:26:23;2;Calibration Finished
19:26:25;1;Battery by Batt ID: 5000
19:27:34;1;Motorswitch Idle Bailout
19:27:35;2;Governor Active
19:27:35;1;Motorswitch Motor On
19:27:46;2;Bank 2 Loaded
19:27:58;4;Extreme Vibration Level
19:28:08;2;Raised Vibration Level
19:28:18;3;High Vibration Level
19:28:28;4;Extreme Vibration Level
19:28:39;3;High Vibration Level
19:28:48;3;High Vibration Level
19:28:58;3;High Vibration Level
19:29:10;2;Raised Vibration Level
19:29:19;2;Raised Vibration Level
19:29:29;3;High Vibration Level
19:29:39;2;Raised Vibration Level
19:29:49;3;High Vibration Level
19:29:59;3;High Vibration Level
19:30:09;3;High Vibration Level
19:30:13;3;RC Input Packets lost
19:30:13;4;RC Failsafe activated
19:30:13;2;Governor Stop
19:30:14;1;Motorswitch Motor Off
19:30:20;4;Extreme Vibration Level
19:30:30;4;Extreme Vibration Level
19:31:33;2;Bank 1 Loaded
19:31:47;1;Motorswitch Idle Bailout
19:31:48;2;Governor Active
19:31:48;1;Motorswitch Motor On
19:31:49;2;Governor Stop
19:31:49;1;Motorswitch Motor Off
VBar Logfile End -- 23.08.2015 -- 19:32:33
Below is a picture of my NEO mounting on Trex 700 and antennas. Range Check was good with the antennas mounted as pictured
Old 08-25-2015, 07:20 AM   #7 (permalink)
Is that the whole log? That is only 5 seconds of entries...
Old 08-25-2015, 07:46 AM   #8 (permalink)
Personally, I wouldn't have the antenna wire sitting on top of the current sensor. Or even that close to motor. There's a lot of electrical interference happening in the immediate area.
KevinB
KevinB is offline        Reply With Quote Quick reply to this message
Old 08-25-2015, 08:54 AM   #9 (permalink)
KevinB
Wire sitting on current sensor - picture does not do a good job with depth perception, they are at least three inches apart
Close to Motor- On a Trex 700 you dont have much of a choice .... there isnt a place in the back of the heli to place a gyro. I have flown with multiple brands of FBL sensors in this location on this very bird and never had any problems
Old 08-25-2015, 08:58 AM   #10 (permalink)
Strange, must be a browser display issue , the file starts at 19:26:18 and ends at 19:32:33 .... that is 6 minutes and change
Managed to attach a *.txt file for you.
Old 08-25-2015, 04:52 PM   #11 (permalink)
firstly you should never cross antenna wires like that and have them resting on each other , it will reduce signal strength.
did you do a proper recommended range check ?
might be worth checking the antenna coax connection's inside the radio to make sure both antenna's are connected , had a friend with one antenna that was not connected
also it would be a very good idea to put a thread up on the Vstabi VBC forum to let them know , they are very active in helping resolve any issues .
Fasster is offline        Reply With Quote Quick reply to this message
Old 08-25-2015, 10:57 PM   #12 (permalink)
Ok. Was just throwing it out there. The pic looked like the antenna was literally laying ON the current sensor. I agree with Fasster about not crossing antenna wires.
As for being close to the motor, did your other FBL installations have the FBL sensor ? or the Receiver/antennas ? mounted right beside the motor? Most other FBL systems have remote RXs that are on a lower tray or stuck to the side of the frames.....further from the motor and high current sources. The only available RX is not mounted to the gyro tray right beside the motor like you are doing with this NEO installation. Even a combo Spektrum RX/BeastX unit still has some remote satellites mounted further from the main unit.
Just some more food for thought
KevinB
Old 08-26-2015, 05:59 AM   #13 (permalink)
Very strange it shows that way on one computer but not another....
As to the antennas, crossing them is not the best way to get the most signal strength. Also keeping them away from other electronics is the best solution. As to the motor, I would open the signal strength indication box and then spool the heli up (no blades) and see if it dimities. then you will know for sure if the motor/placement is the issue...
Old 08-26-2015, 09:36 AM   #14 (permalink)
KevinB
First Unit on the bird was AR7200BX that lasted 3 months or so ... so antennas were exactly where I have them with NEO
Then I graduated to Vbars and Sbus. My Sbus receiver sat right under the gyro mount for over a year . so again, antennas were exactly where I have them with NEO
Never had any problems with either setups. Thanks for the advice though.
Old 08-26-2015, 09:43 AM   #15 (permalink)
Thanks Fasster, KevinB, Laughingstill
The antenna wires have bee moved and they no longer cross over each other.
TODO
  1. Check for antenna wire connection inside the radio
  2. Range test and again with motor on (no blades) to see if the proximity to the motor is a issue
I will keep everyone posted
Old 09-28-2015, 03:12 PM   #16 (permalink)
I just had this same issue and error logged with my brand new Mikado 600SX. Just cut power a few seconds into the flight and I barely managed to get it safely autoed to the ground. Signal strength in TX and RX is strange. The RX stays stable for the most part, but the TX signal drops up and down slowly on either one or the other antennas. Any ideas to help narrow in on the cause would be much appreciated. Thanks guys.
datatools is offline        Reply With Quote Quick reply to this message
Old 09-28-2015, 10:27 PM   #17 (permalink)
For me moving the antennas away from each other and not cross each other did the trick
Old 09-29-2015, 09:58 AM   #18 (permalink)
I had the antenna wires mixed into the mass of servo wires (to keep it out of the way). I noticed my servos were vibrating when on the bench, and when I wiggled the antenna wires it would get worse. So they definitely need to be kept away from everything. I ordered the Mikado antenna wire holder for the tail boom. This should do the trick.
Bryan
Old 10-04-2015, 09:31 PM   #19 (permalink)
I'm still having this issue, but now its worse. With blades off spooling up on the ground, I'm getting this error approx 10 seconds into the spool-up ever time (the model momentarily dies from a lack of power, and restarts the spool-up). I'm reluctant to try flying until I get some feedback on this one. Has any one else had this error? My setup is a Mikado 550SX, with Neo, Vcontrol, Castle 120HV, WR mini BEC at 5v, Torq servos, stock scorpion 1100kv motor, 4400mah 6s lipo.
Old 10-05-2015, 07:32 AM   #20 (permalink)
Do you have the static installed? You verified that it has great continuity?
