Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 230S
Blade 230S Blade 230S Helicopters Information and Help
Like Tree6Likes
Old 01-02-2016, 04:28 PM   #261 (permalink)
Check out your local HobbyTown to see if there are several in stock already...I think they are pricey sadly
Stretched Blade 270CFX w/Custom Scorpion+3Digi
MSH Stretch Carbon Protos 500+Custom 770kv Scorpion 4015+80A YEP+BrainV1
https://www.youtube.com/c/RCBound#699RCHN
RCBound is offline        Reply With Quote Quick reply to this message
Old 01-03-2016, 06:43 PM   #262 (permalink)
Default 230 SR
Had it, so tried it out. Kind of retro, my SR never flew this good.
Name:	Blade 230 SR1.jpg
Name:	Blade 230 SR2.jpg
John
Blade 450 3D, mSRX, 230S, DX6
jrtubb is offline        Reply With Quote Quick reply to this message
Old 01-10-2016, 10:43 PM   #263 (permalink)
Default Angry Bird Phoenix
Seems like every time I crash my heli I tend to upgrade it. Mods are fiberglass canopy, homemade carbon fiber tail boom, carbon fiber tail skid, and Zeal neon orange carbon fiber blades which are possibly the best investment into the heli. They fly super smooth in forward flight. Could notice a little less of a bite.
ID:	629266   Click image for larger version
NoCapeHero is offline        Reply With Quote Quick reply to this message
Old 01-13-2016, 01:37 PM   #264 (permalink)
Blade 230 S: HAWK WARNING! (3 min 12 sec)
Old 01-17-2016, 08:42 AM   #265 (permalink)
If you're familiar with the HobbyTown franchise and the IFT helis that are sold/phasing out of the market l, then you'll recognize this as the Evolve 300CX fuse. It should fit the 230 alright with some modifications. The tail motor will require cutting a chunk out of the tail but I'll make it as clean as possible. Will probably make it easily removed because I will not be flying 3D with it.
Old 01-17-2016, 03:03 PM   #266 (permalink)
Please post pictures during construction. Love this stuff. Maybe cut the tail clean off and mount the tail blade upside down to replicate the scale model fin.
crsorrell0653 is offline        Reply With Quote Quick reply to this message
Old 01-17-2016, 03:20 PM   #267 (permalink)
Fits pretty well and room for battery too! Pretty tail heavy but battery has room to go forward. Got the tail prop at home painted black to match mains. Mains are the CF blade for Ares Optim 300. Can't wait to fly it!!!
Old 01-18-2016, 09:52 AM   #268 (permalink)
Looks great! Post a vid when you get it in the air.
Beggers can't be choosers.......
Termite is offline        Reply With Quote Quick reply to this message
Old 01-18-2016, 09:57 AM   #269 (permalink)
I'll get out to fly today, my final college semester(for now atleast) starts in 7 days......I need to get lots of flights in before then!
Old 01-18-2016, 03:19 PM   #270 (permalink)
Looks terrific. Wow. Should you take off the orange tail fin, as you have managed to keep the original for stability, and this will keep the weight off the tail.
Was there much to do in the way of alterations to mount it to the 230 chassis? Also what is the battery access like? Now I want one, ho, ho - where can I get one from?
Old 01-18-2016, 03:20 PM   #271 (permalink)
The stock skeletonized tail fin does nothing for stability. It helps keep the tail rotor from hitting the ground and the scale fuse's tail fin doesn't do that because it doesn't extend down far enough. Now, he could put a "stinger" (bent piece of wire or something) on the bottom of the scale fuse's tail fin like a lot of full scale helicopters have.
Mike680 is offline        Reply With Quote Quick reply to this message
Old 01-18-2016, 03:50 PM   #272 (permalink)
You can buy one from hobbytown.com or at your local HobbyTown if possible. Not much alteration. I cut up the tail a bit to fit the very end around the tail motor mount.
Battery access sucks for now as I am taping on the nose (which I cut off for battery access) every flight. That will be changed with paperclips on one side and tiny tiny magnets on the other. There is plenty plenty room for the batteries though.
It doesn't attach exactly, the boom is pretty much holding the hole thing on because of how the fuse wraps around it nicely. I mearly had to zip tie a paperclip underneath in order to keep the fuse off the main gear. I'll post pics later.
It is sweeeeeet watching the footage at low headspeed because there appears to be 4 stationary blades! Good stuff!
Old 01-18-2016, 03:51 PM   #273 (permalink)
Took the words right out of my mouth. Thanks!
Old 01-18-2016, 06:29 PM   #274 (permalink)
[QUOTE=RCBound;6822042]You can buy one from hobbytown.com or at your local HobbyTown if possible. Not much alteration. I cut up the tail a bit to fit the very end around the tail motor mount.
I have a scale hughes 300 with difficult battery access, so have one battery in there full time and charge in situ, and only fly occasionally for a novelty. The tri blade head would suit this body.
Old 01-18-2016, 07:05 PM   #275 (permalink)
Blade 230 S: Scale Fuselage (5 min 0 sec)
Old 01-18-2016, 07:11 PM   #276 (permalink)
I flew it a second time just now and it flies pretty dang well. I'll have that video uploaded late tonight.
Old 01-18-2016, 07:13 PM   #277 (permalink)
I don't like extra weight, and my main focus is 3D so i prolly won't fly with the scale canopy again, but it was fun!
Old 01-19-2016, 12:31 AM   #278 (permalink)
Blade 230 S: Scale Canopy Flight 2 (4 min 20 sec)
Old 01-19-2016, 06:08 AM   #279 (permalink)
Looks awesome though, would be great to have it set up like that when it is on the shelf even if you don't fly with it.
Old 01-19-2016, 10:03 AM   #280 (permalink)
Here's a couple pics of my 230s with a Rakon/Lionheli fiberglass canopy and Lynx carbon plastic blades:
https://goo.gl/photos/xTomMagQrc5Sswu47
https://goo.gl/photos/QYWvL9NLJmXKWrJG9
https://goo.gl/photos/GVMUHKmDxAeRC9Gk9
https://goo.gl/photos/A4zMSLRXRPXqgWHv9
Align 450 Pro DFC•Hausler 450 sev2• HK 250gt• Blade SR• (2)Blade nCPX• (2)Blade mCPX•Blade mCPX bl•Turnigy 9XR Pro
Victory Motorcycles: 2007 Victory Vegas Jackpot•1999 Victory V92c Classic
kla912000 is offline        Reply With Quote Quick reply to this message
