Go Back   HeliFreak > R/C Electronics Support > HobbyWing ESC's
HobbyWing ESC's HobbyWing ESC Support
Like Tree1Likes
Old 01-07-2016, 10:34 PM   #61 (permalink)
Originally Posted by rollinthunder13 View Post
Darksyd3d does your video apply to the hobbywing 160 hv? any help would be greatly appreciated. this is my first 700 sized build and I am a little nervous about the flybarless set up and esc set up.
Yes, the setup is identical for the V4. When calibrating the throttle on the V4 you only have to leave the throttle in High for 2 seconds or it will go into stick programming. No biggie if it does, just unplug and start over. Setting the gov store is the same procedure.
Some of the verbiage has changed a little but nothing major. Feel free to PM me if you have questions
Hobbywing US factory team pilot BK Servo Spartan RCTeam LynxTeam OXY Team Xnova I get high by getting LOW!!
DarkSyd3D is offline        Reply With Quote Quick reply to this message
Old 01-08-2016, 07:16 AM   #62 (permalink)
This is what i love about this hobby and this forum,so many knowledgeable people that dont mind helping others try to learn and enjoy this hobby !!!
Thanks darksky3D
Goblin700compitition(vx1n),Trex DFC 550E(IKON),Goblin 500 (ikon) Trex 450L(IKON),Trex 250 DFC flb,Blade 400,CP PRO,180CFX, 130X,MCPX brushless,nano brushless, Realflight 6.5, Phenix 5.
rollinthunder13 is offline        Reply With Quote Quick reply to this message
Old 01-08-2016, 08:57 AM   #63 (permalink)
Thanks darksky3D
Anytime!
Old 02-01-2016, 07:21 PM   #64 (permalink)
Set mine (160 HV V4) up this afternoon on a new Protos Max 700 V2. No problem.
Loaded my main settings already with the computer and the programming box. Set it governor store.
Set the throttle limits, high and low using a liner throttle curve. 0-100
Then set a 50% flat throttle curve in normal. With the collective pitch stick (left) confirmed at 50% in the servo screen, throttle hold on, plugged it in, take off throttle hold, count 20 seconds, put throttle hold back on, unplug.
No problem really easy. Thank you for your help !!!!
Diabolo 700 BE, 600, Logo 600, 200, Goblin Raw 700, Kraken 580, VCT, VBar, Egodrift, Scorpion, Kontronik, MKS, XPert, KST
Freeskiken is online now        Reply With Quote Quick reply to this message
Old 02-01-2016, 11:34 PM   #65 (permalink)
Awesome man. If you want to check the logs all you have to do is plug the box in after the flight and before you disarm the esc. Press enter to connect, the R/P to scroll through the logs.
The rpm readout is a little weird as I think it's giving you the rpm of the motor, not the blades. The main concern is Max amps though
Old 02-02-2016, 11:45 AM   #66 (permalink)
Hi,
I taught the ESC would keep the logs in memory ?
proy is offline        Reply With Quote Quick reply to this message
Old 02-02-2016, 11:29 PM   #67 (permalink)
Originally Posted by proy View Post
Hi,
The 160 v4 doesn't have an internal flash memory and no option for external memory.
Old 02-03-2016, 07:18 AM   #68 (permalink)
Thanks,
So when the wifi modules comes out, we need to transfer the logs before taking the battery out.
Or in the meantime connect a pc to get logs.
Does all company work the same way ?
Old 02-03-2016, 07:24 PM   #69 (permalink)
Your best bet would be to take a pic of the readings with a cell phone for now. Not all companies are without a computer interface but its a give and take with Hobbywing. You get an awesome performing speed controller at a great price. You sacrifice the ability to save logs at least for now.
Might be a cool idea if they came out with a new prog box that had a micro sd card slot for saving settings and logs
Thanks,
Old 02-03-2016, 08:34 PM   #70 (permalink)
not sure if that's a good idea, since some people already have 1 pbox, some have 2. Getting another would make it 3 pboxes. lol. I think the wifi app would be the way to go. Nothing worse than carrying all these things on the field. Keep it simple just use the phone.
Just wished they would hurry it up a bit and send you a Hobbywing wifi express for testing.
Also wouldn't mind seeing the HW pc app to have the ability to extract those logs too. Similar to Castle ESCs and some other cheaper brand esc too
gimbleguy is offline        Reply With Quote Quick reply to this message
Old 02-04-2016, 12:05 AM   #71 (permalink)
That would be nice as well. I think it may cost a little less to add a memory slot to a PG vs the esc itself. I MAY be incorrect but I thought the wifi express was only for set up, not reading logs. Possible something changed since HW didn't have an esc capable of logging when the WE was first announce over a year ago.
We all hoping to see them soon but I haven't heard anything yet
Old 04-06-2016, 10:23 AM   #72 (permalink)
hi guys, im little bit confusing about the voltage at learning. What is the best for optimal governor. 3.8v 4.0v 4.2v ?? i know that castle use 3.7v nominal so what is the best with hobbywing thanks
Lynx Heli Innovations Field Rep
OXY 4 !! Neo
Logo 200!! Logo 550!! Neo-VControl Touch!!
Pilot rc Laser 88, mikado V-plane, DA-70-MKS hv777
jean-michael is offline        Reply With Quote Quick reply to this message
Old 04-06-2016, 08:03 PM   #73 (permalink)
Yes, It applies to all Platinum Pro V3 and V4 controllers. Feel free to pm me if you have questions
Old 05-26-2016, 01:30 PM   #74 (permalink)
What if I use a lower cell count lipo after governor is set?
i.e. governor setup using 6S, then I run it with 5S. Never done this but wondering.
sidneyw is offline        Reply With Quote Quick reply to this message
Old 05-26-2016, 11:11 PM   #75 (permalink)
If you plan to do it often you'd want to use gov elf mode. But if only ever so often it will be ok but check esc temps. The gov might freak out a little. I haven't tried it before on the HW
Old 07-22-2016, 09:15 AM   #76 (permalink)
Just as an aside for those of you a bit squeemish to spool up your larger (700-800) helicopter on the 50% set up phase. I usually just clamp mine to my workmate in my yard (See pic)
As mentioned the 50% spool up is very mild but this adds a sense of security to the process.
Old 07-22-2016, 11:50 AM   #77 (permalink)
Gotta be careful clamping a heli down, it can lead to ground resonance and end very badly. One chap recently rested bricks on his skids to hold the heli down and the resulting vibrations caused a tipover under power.
Radio & FBL: Spartan Vortex, MSH Brain, Jeti DS-14, Spektrum DX8G2
Sims: RealFlight & AccuRC
Old 07-27-2016, 11:11 AM   #78 (permalink)
Just to make sure, a few things.
1) Once I do the 50% RPM standardization in <gov.mode>, do I have then to go back to my program box and switch that governor setting to <Heli mode> ?
2) The only time I would use airplane mode for a helicopter would be if I used an external governor?
Old 07-27-2016, 10:49 PM   #79 (permalink)
Correct on your first part of the first question. If you're using an external gov you don't have to do the standardization at all. Just set it to fixed wing mode.
Question 2 is also correct
Old 07-28-2016, 06:26 AM   #80 (permalink)
Great, thank you
