Go Back   HeliFreak > R/C Electronics Support > R/C Related Electronics DIY
R/C Related Electronics DIY DIY R/C Electronics for tinkerers and the budget minded
Old 10-11-2015, 11:39 PM   #1 (permalink)
TT
Default 'Dumb' discharger
Bear with me...my electronics knowledge is 'junior high' at best...
I plan on building some modular load banks to discharge lipos with. I plan on building modules that I can use in parallel depending on how much load I need.
For each module my plan is to use 5 8Ohm 100W resistors in parallel. My math tells me this will pull 15.75A on a 25.2V battery for 396.9W of dissipation. Is that right?
My current charger (Hyperion 720i Duo) does not handle regenerative discharge so until I buy a charger that does I need something to ramp-up the current to the load bank. Would a properly-sized motor controller work for this?
I plan to use a wattmeter and lipo low voltage alarm to keep an eye on things.
Any help here would be great!
TT is offline        Reply With Quote Quick reply to this message
Old 10-29-2015, 06:35 PM   #2 (permalink)
Yep - that works out the way I calculate it.
I would set the size of the resistor "stack" to limit the current to 1C or 2C max.
I assume the 15A current draw is for a 6S 5000mAh pack at 3C. I wouldn't go that high.
And, the 100W resistors may be marginal.
I would look for 150W or 200W resistors
By "motor controller", do you mean an Electronic Speed Controller (ECS)?
No, most likely not.
The typical ECS is a micro processor that switches on/off/on a set of 3 transistors and those are connected to a brushless motor.
The transistors are either fully on or fully off.
You need a big variable resistor ("pot" or potentiometer) to "dial up" the resistance you need.
They used to be used with DC motor speed controllers.
ticedoff8 is online now        Reply With Quote Quick reply to this message
