DX7 Binding With Gov Mode On CC35 - HeliFreak
Old 04-27-2008, 03:10 PM   #1 (permalink)
Default DX7 Binding With Gov Mode On CC35
The other day I turned off my TX before unplugging my 450 battery. So the copter started to spool up then fell over in the grass. So today I tried to set up my fail safe but could not. I am running a CC35 in gov mode so as soon as I flip throttle hold to off the 450 starts to spool up to the desired rpm.
I tried to bind the setup with the throttle hold on but the radio just kept beeping saying "warning throttle hold on" on the screen. It would bind fine if the throttle hold was off. So is there anyway to have 0 throttle on a esc that is set up for gov mode?
Jeff
500cf, cchv85, ccbec, 5452mg, 7703d, 3400g, ....>400 flights > 5 crashes make an offer!
600N Sport, os50hyper, mp5sb, 8717, thunder tiger 600mm, solid g, 8900g, 7100r
Compass K3D, os50hyper, outrage, 8717, 8900, spartan, 8900, radix, 7100r
rupps5 is offline        Reply With Quote Quick reply to this message
Old 04-27-2008, 09:10 PM   #2 (permalink)
DJW
Check this thread for some good info on the CC35:
https://www.helifreak.com/showthread.php?t=66593
I've got mine set up this way, with a normal curve of 0-65-65-65-65. So when I power up, the ESC doesn't spool up, but as soon as I put in any throttle, away it goes. Seems to work well so far. Alternately, you could bind with this setup, then switch back to a flat curve without rebinding. This would keep the 0 failsafe. I like having the 0 throttle as well as TH, so that I don't need to turn on the TX, then TH, then the heli.
DJW is offline        Reply With Quote Quick reply to this message
Old 04-28-2008, 07:34 PM   #3 (permalink)
You have to set the throttle curve to have a 0 point and bind, then set back to what you normally use.
But I would have 0 as my low stick point in Normal, even if you use GOV mode.
Terry
AMA#47402, IRCHA # 3395
Pinecone is offline        Reply With Quote Quick reply to this message
Old 04-28-2008, 08:35 PM   #4 (permalink)
ok, thanks for the tips guys
Jeff
Insurance
Human Verification
