Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Nano CPS
Like Tree3Likes
Old 11-14-2015, 11:09 PM   #1 (permalink)
Default Nano CPS Goes Brushless! Yup Brush-less!
So I finally got around to tearing into my Nano CPS and I decided to go brushless. Not just for me but for all of you out there that were hoping it would be brushless. It's late here already so I don't have much time to write all the details but I will say it was a bit challenging to figure out the right settings on the TX and ESC. Here are some pictures, enjoy. I'll be happy to answer questions.
ID:	619432   Click image for larger version
ID:	619433   Click image for larger version
ID:	619434   Click image for larger version
ID:	619435   Click image for larger version
megasmicros is offline        Reply With Quote Quick reply to this message
Old 11-14-2015, 11:23 PM   #2 (permalink)
super!!!
delfin2003 is offline        Reply With Quote Quick reply to this message
Old 11-14-2015, 11:52 PM   #3 (permalink)
video plz!
Old 11-14-2015, 11:55 PM   #4 (permalink)
Looks great. If you have the time later I would be interested in more of the details and some opinions about how it flies.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 11-15-2015, 12:02 PM   #5 (permalink)
Subbed, I have as most (It seems) issues to get my CPS to work properly. So I need to fix that first. But hopefully that will be resolved soon and then I will jump on this asap
DX8 & DX9 | Rakon 200 SR X | Nano CP S | Nano FPV QX | Rakon NQX (MMW CL-0615-14 Motors) | ImmersionRC Vortex | Lynx Oxy3 (Building) | Bixler 2 Long Range FPV Project | HK Rarebear War Bird Speedster Project (Goal: 150-180mph) | Misc. HK foamies
The_Norwegian is offline        Reply With Quote Quick reply to this message
Old 11-15-2015, 04:39 PM   #6 (permalink)
Nice work!!
Thanks for showing us where to get the PWM signal from.
Is it the same (negative I think) signal, just like the CPX board?
Also are they your own design of servo spacers, or Pjaq ones?
Thanks!!
MB
Nano CPX x 3, mCPX-BL x 3,130X, 180CFX, Lynx 450X-L, T-Rex 250 DFC, T-Rex 450L, T-Rex 500, KDS Chase 360, SAB G380, G500 Spt, BT650, BT700-T, BT700 Spt, XLP520
"More the Knowledge Lesser the Ego, Lesser the Knowledge More the Ego" Albert Einstein
Miracle Boy is offline        Reply With Quote Quick reply to this message
Old 11-15-2015, 05:30 PM   #7 (permalink)
The signal can be taken from there or later on in the string. The signal itself is a bit different from the nCPX in the terms of the PW. The current revision of BL Heli will pick up the signal from 1ms to 2.02ms. The signal from the ncps will come into that range from about 40%-85% throttle. So I had to make some adjustments to the transmitter to make it work. If you use it on a flat throttle curve then this doesn't even matter just keep it between 40-85. The signal is positive where I picked it up, but will be negative later in the circuit. I used my design of spacers from the cpx and they fit just fine. They do push the board a bit forward but it has no effect on it. I'm not a 3D flyer myself so I can't really say how it will perform under those conditions but for what I do it's performing great.
Old 11-16-2015, 05:57 AM   #8 (permalink)
Thanks for the update That's interesting about the PW needing a different set up with the Tx throttle.
Do you sell those servo spacers from the CPX /CPS? I had a look for them on your site, but I didn't see them.
MB
Old 11-16-2015, 08:21 AM   #9 (permalink)
Yes I do. I'll have to check that I do show them in stock.
mcpx, nano cpx, nano cps, 130X, mcpx bl, 120sr, 120s, nano qx, 180qx, 200qx, 350 qx
Old 11-16-2015, 10:15 AM   #10 (permalink)
Thumbs up Awesome!
Is it necessary to mod the frame? Is it easy to install? Are you offering a kit? Or can I send it to you for installation?
heli227 is offline        Reply With Quote Quick reply to this message
Old 11-16-2015, 10:23 AM   #11 (permalink)
It is necessary to modify the frame for this type of motor. I can certainly make a kit or install it, your choice. It isn't difficult to install if your good with soldering iron.
Old 11-17-2015, 12:28 AM   #12 (permalink)
Bird is fixed, so I am ready to order
Any ETA when you think a upgrade-kit can be available?
Pre-orders?
Old 11-17-2015, 10:56 AM   #13 (permalink)
Thanks, I see them on your site now. Sadly my CPS has been returned as it was faulty out the box. Mine did all sorts of weird and not so wonderful things, even just sitting on the bench I'm waiting on a replacement from HH UK. I'll hold off till I get a replacement CPS.
Will you be producing another run of these spacers in the near future?
I see you only have 4 sets left at the moment.
MB
Old 11-18-2015, 03:14 PM   #14 (permalink)
Does it matter if the signal is positive or negative? Where is the negative? Where is tail signal?
jebie79 is offline        Reply With Quote Quick reply to this message
Old 11-18-2015, 05:45 PM   #15 (permalink)
Yes I will be making more when needed. I dont have the kits ready to post on the website but I certainly do have all the parts so if you send me an email I can get you set up.
Old 11-18-2015, 06:48 PM   #16 (permalink)
O.K. cool, thanks. I'll hold off for now and see if the replacement I get actually flys right, if it's o.k. I'll drop you an e-mail. Since we have to cut out the entire front vertical support to get the Oversky motor in there, I'd need a set of your spacers to add some strength to the frame.
MB
Old 11-21-2015, 04:17 AM   #17 (permalink)
PM sent
Old 11-21-2015, 08:48 AM   #18 (permalink)
Awesome! I'm re thinking my second thoughts about wanting the new Nano!
Heli's that I currently fly: Lynx Oxy3+ {Build In Progress!}, JR Forza 450 {hangar queen}, Blade 180CFX, Blade mCPX BL {work horse}, Blade NanoCPX - Blade Nano QX, Blade NanoQX3D - Phoenix 5.5 - Spektrum DX6 - - HeliFreak is great! -
Canadian_Jesus is offline        Reply With Quote Quick reply to this message
Old 02-05-2016, 09:06 PM   #19 (permalink)
How is this thing holding up? Any problems with the board?
Old 02-05-2016, 11:53 PM   #20 (permalink)
Default Cps
Everyone that flys needs a nano cps such an all some heli when it's set up right , from reg flying to 3d flying I've never had a heli I can 3d fly in the house this thing is nuts and fast for such a lil heli. How much do your kits run I wanna go brushless
Jsilva67 is offline        Reply With Quote Quick reply to this message
Tags
brushless, nano cps, nano cpx
