Like Tree8Likes
Old 11-16-2015, 11:05 PM   #1 (permalink)
Default Best/Easiest 130X Tail Servo Replacement
So after well over 180 flights (and about a dozen crashes including todays), my stock tail servo is buzzing and not moving correctly.
I'm pretty sure it's hosed so I want to replace it.
I know a lot of them were replaced with a standard eFlite or Lynx servos but I'm looking for an easy swap without spending a ton (since the heli is discontinued).
What do the 130X gurus recommend these days?
Diabolo 700UL / Logo 700 / 600 / 550 / Goblin 500 / Oxy 2 FE / Blade 180CFX / mCPxBL / nano CPS / V-Bar NEO / V-Bar Control / uBrain / DX7
Old 11-16-2015, 11:37 PM   #2 (permalink)
Elite ds76t servo , but you will have to solder the correct servo connector
3D Ambitions is offline        Reply With Quote Quick reply to this message
Old 11-19-2015, 03:52 AM   #3 (permalink)
Another would be Lynx ds 883
HedgeHeli is offline        Reply With Quote Quick reply to this message
Old 11-19-2015, 04:09 AM   #4 (permalink)
Much better chances of bliss with the DS76T though . 883=crapshoot imo
-Kevin
wsntme is offline        Reply With Quote Quick reply to this message
Old 11-19-2015, 04:12 AM   #5 (permalink)
Wow, I did not know that I must be lucky. What are the mounting options for the ds76t - got a new 130x coming that will need a decent tail servo.
Old 11-19-2015, 11:38 AM   #6 (permalink)
The ds76t mounts on the lefts side of the tail boom. Opposite of the ds883 mounting position. I have two 130x's with ds883 servo's and so far they have been great far better then the stock linears. Good luck finding those though. Better to go with the eflite servo since it will be produced for a good while.
Old 11-19-2015, 12:25 PM   #7 (permalink)
This is how my ds76t is mounted
danb1974 is offline        Reply With Quote Quick reply to this message
Old 11-19-2015, 02:19 PM   #8 (permalink)
Great info thanks for the post
Old 11-21-2015, 06:27 PM   #9 (permalink)
danb, what servo mounts are those?
Also, do they work without any issues?
Old 11-21-2015, 06:31 PM   #10 (permalink)
Those are Lynx servo mounts , they work great.
Old 11-22-2015, 11:14 AM   #11 (permalink)
Default 130x Red Bull Conversion
I used the Walkera WK-03-4 to make the changeover on a 130X Red Bull. Great little servo. Choose a mount style and solder the original connector onto the new servo - make any needed adjustments to your gain settings on the helicopter itself and your in business.
ID:	620825   Click image for larger version
CREATURE is offline        Reply With Quote Quick reply to this message
Old 11-23-2015, 06:26 AM   #12 (permalink)
Smile
I have two 130X, both rotary build. On one I have a hitec setup with a DS76T tail, the other one has a complete Microheli servo setup with an MH-DS002S on the tail. Both setups work great. The DS76T is a bit crisper, but both tails hold really well!
MaxPhlyer is offline        Reply With Quote Quick reply to this message
Old 11-23-2015, 10:55 AM   #13 (permalink)
Just ordered the microheli tail servo, curious to check it out.
Old 11-25-2015, 11:58 AM   #14 (permalink)
Thanks guys. I ended up ordering the OEM as I want to sink as little money into this as possible since it is discontinued.
If I get another 180+ flights I'll be happy.
Old 11-25-2015, 12:03 PM   #15 (permalink)
Using the stock linear servo mount is possible, chop it in half and you can use the two pieces for a rotary servo. That's what I did initially, then bought a proper mount. Maybe one day I'll fix the 130x up
Minicopter Diabolo 550 w/ MSH Brain
Gaui X3 w/ Mini KBar
250 Pro DFC w/AR7200 (needs some costly fixing)
thepiper92 is offline        Reply With Quote Quick reply to this message
Old 05-07-2018, 12:18 PM   #16 (permalink)
Did the DS35 servo swap using a RakonHeli mount
OneMuscleRussell is offline        Reply With Quote Quick reply to this message
Old 05-07-2018, 06:40 PM   #17 (permalink)
Let us know if that DS35 works ok.
Eflite screwed it up by changing the circuitry in the servo, this caused a problem with tail hold.
This is a well documented problem with the latest DS35's.
Hope you got an older one.
https://www.helifreak.com/showthread...highlight=DS35
https://www.helifreak.com/showthread.php?t=516545
HW.
Many helis from the 70s to 2000s.
Align,Blade,GMP,Hirobo,Kyosho,Schluter.Flybars cool,FBL too. Currently flying the little ones.
Heliwhisperer is offline        Reply With Quote Quick reply to this message
Old 05-15-2018, 10:04 PM   #18 (permalink)
OneMuscleRussel - In case you need the info, here's a thread that explains how to tell whether you have an old style or a new style DS35.
FYI - How to identify good old DS35 from bad new version with wag
Kevin B.
"Fun, Learning, Friendship and Mutual Respect" - good words to live by
RC: 300x, 130x, DX6i, iCharger 106b+, Phoenix Sim
Other: Atmel AVR microcontrollers, electronics, 3D printing
helibus is offline        Reply With Quote Quick reply to this message
Old 03-02-2019, 11:42 AM   #19 (permalink)
Hi,
I almost had said that there is a new tail servo available: Lynx LX3005
h0988UHS-i
But now as I recheck the spec on their homepage https://www.lynxheli.com/product_inf...afbe7294f00c07, I recall that it is only made for 760Ás.
So if you have a rotary frame with any more modern custom FBL (ÁBrain, ÁSpirit, etc.) which support a true 760Ás tail configuration, you are good to go and test this alternative.
With my Walkera V120D02s heli (I originally wanted to "custom build" it and make it Spektrumized with Tarot ZYX-s) I have e.g the problem of the proper servohorn length, right ball head diameter, control push rod...and therefore I cannot find an easy tail servo replacement solution.
All mechnical parts need to match well.
@CREATURE
Maybe I should simply get the WK03-4 tail servo again for my V120d02sw and try it on a much lower digital setting than 333Hz (e.g 214/240Hz)? :-)
I had not any good tail hold and got a quick blow out in wind outdoors and the Tarot ZYX simply did not allow me choose a proper HeadingHold gyro value of anything more than +12-14 gain which is quite low.
It actually hovered once with that tail gyro gain indoors...but you cannot compare that to my Blade 4503D and DS76T or H3060 tail servos and much higher gyro gain values
Walkera Devo 10/DeviationTX (12CH DSMx & telemetry)...Ex-DX8...Blade 4503D...Walkera V120D02s...Blade 200QX BL Quad...StrykerQ (LEDs, M2 tuning)...Ex-NanoCPX...Ex-120SR...Ex-MPX EGP...PPZ P51-D Mustang...PZ Wildcat (searching fuselage-firewall)
Thomas.Heiss is online now        Reply With Quote Quick reply to this message
Old 03-04-2019, 10:23 PM   #20 (permalink)
I just finished the DS76T upgrade and now wish I had done it years earlier. The servo mounts are not cheap and I had to order them from the USA after some assistance from guys on here via another thread. My comment on that thread was that I had NOT used my deoxit for about 3 weeks. Fantastic.
Maturecruiser is offline        Reply With Quote Quick reply to this message
