Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > 270CFX
270CFX Blade 270CFX Helicopters Information and Help
Old 11-25-2015, 12:05 PM   #41 (permalink)
Well, just decided to upload a single SIM flight. Never have, and wanted to show my normal tendencies during SIM flight. I haven't seriously flown in over 2 weeks aside form my recent maiden flights. So i'm not polished and not trying to "impress" during this video. I do more guiding the heli than I do keeping it in one spot. I need to work on that for sure...
I chose the Gaui X5 which I don't SIM with normally and had to get used to the rates and make some adjustments later in the flight.
...looks like I also need to work on my run-on sentences
I'll probably keep using the X5 to help train for the 270CFX
RealFlight with Gaui X5: a bit of messing around (7 min 13 sec)
Stretched Blade 270CFX w/Custom Scorpion+3Digi
MSH Stretch Carbon Protos 500+Custom 770kv Scorpion 4015+80A YEP+BrainV1
https://www.youtube.com/c/RCBound#699RCHN
RCBound is offline        Reply With Quote Quick reply to this message
Old 11-25-2015, 12:09 PM   #42 (permalink)
I'll be adjusting tail gain on the 270 and getting out to fly this afternoon I hope. It's below 30F and everything is officially white now...little cushion for the crashes eh?? haha
Old 11-25-2015, 12:38 PM   #43 (permalink)
Let me know how it goes I'm getting done work early today which is nice have a four day weekend
So I will be definitely getting some flying in
out flying..
$Gambino$ is offline        Reply With Quote Quick reply to this message
Old 11-25-2015, 01:41 PM   #44 (permalink)
right on john! go get some!
Old 11-25-2015, 01:46 PM   #45 (permalink)
U mean mike? Hahahaha
Going out soon ....this is where i hang the little guys....need to make space for all my damn heli's
out flying..
Old 11-25-2015, 01:50 PM   #46 (permalink)
haha...
so did you see my post about accidentally having -60/40 in my TX for the Gear channel with normal position being -60 :/
I haven't adjusted it yet cause I'm confused...I was flying fine but I just want one last clarification.
The radio needs to see a normal neg or normal pos on the gear channel?
Also, do each of the numbers adjust some sort of gain?
You mentioned the positive number is the tail gain. Correct?
Old 11-25-2015, 02:02 PM   #47 (permalink)
I have a nice work space but sill crowded...that mirror isn't normally up there. I wanted to watch TV(which is behind me) while at the bench haha
Old 11-25-2015, 02:18 PM   #48 (permalink)
For some reason it said in manual that 65was high and 28 was low not negative just 28 but this is for spektrum. It also said that the gyro / flap switch would control safe but it said not to alter numbers to much cuz safe would not work right. 65 and gyro to me is tail gain 65 has always been around what i had to program for tail so i figured this has to be it since it also didnt have me set up normally like i see for tail in that very same "gyro" menu i normally would see (just an exampke as if i were setting up lets say my 550 x) "f-mode" "normal"- 68 then below, "stunt -"64 ....for different heli's it would be set up like that. But for 270 cfx it made me change in the "gyro" menu itself f-mode to gyro, which is just different switches. So instead of the tail being controlled by your flight mode switch it is now controlled buy gyro/flap switch. That is why I believe those numbers are tail gain still. What protocol does the Taranis follow? Do u know? I'm telling you call HH have them do a call back it takes two minutes there will call you back and ask them someone there has to know or owns a Taranis or knows what protocol it follows. And you having them numbers like that explains why you were in self level mode too! How did u fly it like that? And what is your numbers now. As long as safe still activates when u flip switch, then it should be good. I would just lower the HIGHER number about 4 points. See how that works if not go down another 2 till tail stops doing that in iu3 .Why don't you PM me your phone number this way we could talk this takes too long I'll try to help you out
out flying..
Old 11-25-2015, 02:21 PM   #49 (permalink)
What taranis do u have
out flying..
Old 11-26-2015, 01:06 AM   #50 (permalink)
I'll toss some links in the description again.
I didn't even go inverted this time for some reason...just didn't like the frozen hands and the odd pitch pump behavior than continues.
Oscillations are gone on the plus side! It is still fun to zip around.
Had tail noise first flight which was cured simply by tightening up the tail blades...very small threshold so it seems...
Blade 270 CFX Snow Flights 5-7: Still tuning it... (13 min 20 sec)
Old 11-26-2015, 01:34 AM   #51 (permalink)
Blade 270 CFX: Slop in parts before first flight (1 min 29 sec)
Old 11-26-2015, 10:37 AM   #52 (permalink)
Well i just watched your video sounds like tail is good now as for the drifting when pitch pumping make sure on bench swash stays level thru the whole range up and down. I think the beast manual said "A" parameter was trim for behavior like that also. We can actually get into that setting also hh was kind enough to let us have that lol. I think im going to buy the firmware anyway in a few days. Just waiting on my beast programmer should be next wens. Looks like you are mostly there tho man good job. Happy Thanksgiving
out flying..
Old 11-26-2015, 02:43 PM   #53 (permalink)
looks cool but have you guys seen the prices of some of the parts? ouch..5 bucks for a set of pitch links.. I hope they sort out the slop issues
tonys-heli is offline        Reply With Quote Quick reply to this message
Old 11-26-2015, 04:26 PM   #54 (permalink)
$5 is affordable....... If price is the issue, then just buy a cheap helicopter with cheaper parts.............. You don't buy a hummer and complain about gas consumption..... Bottom line, you buy what you can afford including maintenance.
Quad350qx3 is offline        Reply With Quote Quick reply to this message
Old 11-26-2015, 04:50 PM   #55 (permalink)
I just want to know if I need to worry about that slop. I don't want to continue flying any trying to tune out my tail jerk on hard pitch pumps if head slop is the issue.
It has atleast a full mm that the head could slip up and down under pitch pumps.
The tail pitch slider arm is sloppy enough to worry me. All in all he heli flies good, but still feeling the same lack of confidence I'm feeling with the 230. Just not feeling connected to the heli, which could be rates and expos and stuff needing to be adjusted as well.
Old 11-26-2015, 08:07 PM   #56 (permalink)
Also make sure that the follower arms are screwed tightly.
Old 11-27-2015, 02:30 AM   #57 (permalink)
Started to dial down some tail wondering but my hands froze so gave up after 6 flights...4 of which were the 230S burning down some packs that were charged over a week :/
Blade 270 CFX: Wondering Tail (7 min 41 sec)
Old 11-27-2015, 06:07 AM   #58 (permalink)
Yeah definitely make sure the pitch links are screwed in pretty tight up on the head. there is little bearings in them so don't go to too tight or it will bind.... and if it's really that bad I would just call HH mine seems pretty tight tiny bit of slop but I'm sure when those blades are spinning the force of it keeps everything tight. Seems like your problem is the swash and the bearing in it just call HH man and tell them you don't feel comfortable what's how much slop is in that swash plate I'm sure they'll take care of you
out flying..
Old 11-27-2015, 09:09 AM   #59 (permalink)
Blade 270 CFX: Wondering Tail - YouTube
Man The only time I see snow is on TV here in California. Seems to fly pretty good only see tail wondering on Pitch pumps. Good luck Vronny p.s I fly most the time with no canopy also. Even my 360 has a little but flies great.
vronny is offline        Reply With Quote Quick reply to this message
Old 11-27-2015, 11:06 AM   #60 (permalink)
I couldn't resist the 15% Black Friday sale, so pulled the trigger on the 270. Going to be looking for help from RCbound and Gambino I'm sure ... Lol
