Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Nano CPS
Old 11-30-2015, 08:21 PM   #1 (permalink)
Default I got the HH brushless kit working! (soldering requried)
I tapped the signal where Mega showed it in the other thread, soldered on the power leads and bingo! Works!. This is like a 10 to 20 minute job if you can solder, very easy, all you have to remove is the canopy (and motor of course) I'll follow up with pics and a vid, when you hit TH the motor stops abruptly and spins the heli out just like the cpx .
I assume soldering is required since someone tried installing it the plug and play way and it didn't work, I didn't even try it TBH.
*edit*
Here are the pics, it's sloppy and the esc is just floating there but it flies and what a considerable difference in power!
ID:	622309   Click image for larger version
ID:	622310   Click image for larger version
Gaui X5-MiniVbar | Gaui X3-MiniVbar | Gaui X2 SK-540 | 250 Pro DFC |130X 3S GY280 | 300X-Ikon | DX8 | Real Flight 6.5
bmc76 is offline        Reply With Quote Quick reply to this message
Old 11-30-2015, 09:17 PM   #2 (permalink)
Blade Nano CPS with Horizon Brushless kit (soldering required) (3 min 33 sec)
Old 12-01-2015, 12:40 AM   #3 (permalink)
Awesome heli!! Great flying too!
sunsetmaro is offline        Reply With Quote Quick reply to this message
Old 12-01-2015, 03:29 AM   #4 (permalink)
Well..nothing a soldering easy job can't be done!
REAL thanks for postin it!
Selled my nano cpx to Australia months ago. Maybe now with the autoleveling thing and brushless i can buy another in CPS form.
Glad to see a brushless. Shame HH didn't come up with that. That's why i haven't bought one.
A big company selling a BRUSHED system in 2015 is just not right, that way they are sayin customers are moron and stupid, and need to buy "acient" tech for "us" gain profit!
to the brushless autoselfleveling nano! Many thanks for posting pics and video!
Now we have: CPS, 200SRX & 230S with autoselfleveling...
Please make a 400size heli or a 300 helisize with autoselfleveling... normal people that buy your product's don't have the know how to put "ikon's" or "mikados" Flybar units and tune them.....and "Kbar's" are not yet autoselfleveling or 6axis gyros!!
PLEASE:
Can post a p+ic of what the exact 3 wires of the mini board goes into the big board?
That will be awesome, and put an arrow pointing where is that signal...!
bentheboss is offline        Reply With Quote Quick reply to this message
Old 12-01-2015, 08:46 AM   #5 (permalink)
Mikado 550SEV-2 w/Brain2, and XL Power 380 w/ Mini Brain2 controlled by Futaba 18SZH
BigEddie is offline        Reply With Quote Quick reply to this message
Old 12-01-2015, 08:55 AM   #6 (permalink)
Here is the overhead view. Thanks to Megamicros for showing where the signal spot is.
Vibrations will cause more problems with the bl kit, mostly in stability mode so watch that, also the one time I tried soft start the heli spun around on the table.... so I"ve been spooling up in normal then moving to iu2 once spooled. Also if you hit TH the motor just stops and spins you out. Any cpx guys try an xp3a with hh bl kit? Did it do the same with that esc? That was annoying with the cpx, but I just land and spool down in normal, kinda of pia, I usually just get it close to the ground and hit TH to land.
Old 12-01-2015, 09:04 AM   #7 (permalink)
PLEASE:
I have to agree with it being completely ridiculous releasing a brushed heli in 2015, especially with how ultra horrible the brushed motor is already known to be.
There is pretty much 0 buzz around this heli on the forums, not surprising no one was excited about it. For me it was either send my 2 boards back to Mega for repair again, or just give this new one a shot.
Old 12-01-2015, 02:59 PM   #8 (permalink)
What batteries are you running? Do I see that you removed the rubber mounts from the board and double taped it down?
Align 600n, 2 x Gaul nx4,Gaui gasser,
Goblin 380,600 scale Hughes 500e,230s Huey,Oxy3
chrisl is offline        Reply With Quote Quick reply to this message
Old 12-01-2015, 03:34 PM   #9 (permalink)
stock batteries, 45c 150mah.
I forgot about the tape. I wanted to see if it would fix the twitch, still twitches, though either it's starting to happen less or I'm starting to notice it less. either way the dbl sided tape didn't make any difference in flight in 3d mode, stability mode doesn't like the tape
Old 12-01-2015, 03:43 PM   #10 (permalink)
Good to know, I don't use the stability mode anyway! I like the power it puts out, just might have to go brushless!
Old 12-01-2015, 03:50 PM   #11 (permalink)
Yeah I was surprised by the power, I don't remember the cpx being that peppy with the stretch kit and HH bl kit. And those are the same ones I was running on my cpx, I have probably 150 flights on the motor and esc, batteries are all 4 brand new though so that is probably it.
Old 12-01-2015, 04:05 PM   #12 (permalink)
Yeah, that setup is working nice! It'd be good if you could get rid of that (slight) head wobble.
You definitely must try the MMW mylipo.de 205mah batteries.....
rcflyair is offline        Reply With Quote Quick reply to this message
Old 12-01-2015, 05:22 PM   #13 (permalink)
Yeah i'm gonna work on that tonight, it only happens with the stretch kit, hope I can tune it out as I really prefer the stretch blades.
Old 12-01-2015, 07:40 PM   #14 (permalink)
I got the headshaking under control, just blade balance, runs nice and smooth in my hand and isn't shaking in piros anymore. So doesn't look like I'll have to stop using my stretch blades
Old 12-02-2015, 05:25 AM   #15 (permalink)
Did you have to change the throttle curves to get it to work.thanks for the good work
xxxntwv is offline        Reply With Quote Quick reply to this message
Old 12-02-2015, 08:22 AM   #16 (permalink)
A few things about the throttle.
1. soft start does not work, I have to start in normal to spool up then move to idle up.
2. motor kicks in late, seems low point needs to be adjusted
3. motor seems to be at full power well before 100% so high point needs to be adjusted
4. motor stops abruptly once TH is hit.
I still haven't messed with the low/ high points to test, I've been using the highest speed. I only got in the 2 flights the other night when I wired it up and last night I just spooled it in my hand to balance the blades. Sun is out so I'm going out in the front yard this morning before work for a few flights.
Old 12-04-2015, 05:52 PM   #17 (permalink)
what tail motor/rotor are you running?
and what does it weigh in at?
blue92ehsi is offline        Reply With Quote Quick reply to this message
Old 12-04-2015, 06:29 PM   #18 (permalink)
Stock tail motor, lynx tail rotor, I haven't weighed it, I imagine 3 or 4 grams over stock if that. I can weigh it tonight when I get home.
Old 12-04-2015, 06:33 PM   #19 (permalink)
oh the rotor looked huge in the video. might be deceiving. makes me want to get one looking at the way that thing piros
Old 12-04-2015, 06:50 PM   #20 (permalink)
Looks good, have you considered de-soldering the original motor connector to save weight?
Mr.Merlin is offline        Reply With Quote Quick reply to this message
