Go Back   HeliFreak > R/C Electronics Support > Flybarless Helicopter Systems > AP and Scale
AP and Scale Discussions for Scale, Multi-blade and AP applications using CSM Cyclock, Helitronix Multi-mixer, Spartan AP2000i, Firmtronix, Digimix-3.
Old 05-03-2008, 09:26 AM   #1 (permalink)
Default Vario 3 blade head and helicommand rigid
Hi.
I am trying to set up a vario aluette gasser with 3 blade head.
Anyone that have tryed this?
I cant get the rigid to work ok, if fells a bit twitchy on the cyclic.
And i have problems to understand the setting in rigid menu, like
what parameter does what.
Anyone that kan put some light over this so i understand exactly
wich parameter i should change.
Rickard is offline        Reply With Quote Quick reply to this message
Old 04-12-2009, 11:12 PM   #2 (permalink)
Originally Posted by Rickard View Post
Hi.
(remember that an articulated head will respond 90 degrees after imput,
a ridged head will be somewhat less than 90 degrees more likely
between 90 and 70 degrees) . I tried the advised 75% EXPO and the
helicopter was downwind 50 feet before I could stop it. I cranked it down
20 points at a time until I got a control feel I liked. In my case 15% as
I like responce sooner than later. This may change when I get it in the
scale body. Just some ideas until real help comes along Mine is a
Blade 400 4 blade head (Ridged). Good luck
Blade 400 X 8, CopterX CF SE V2 EXI-450, Clone CF V2 Pro
DX6 X 2, DX6i X 4 Need one? DX7 X1 not in use, it's CRAP!
Rotorjim is offline        Reply With Quote Quick reply to this message
Old 04-13-2009, 09:57 AM   #3 (permalink)
By twitchy do you mean it's too sensitive to control?
I recommend you reduce "control travel" in aileron and elevator in the "mixer" tab if you haven't already since the more blades you have the less cyclic travel you need to get the same response as say a 2 bladed head.
Also in the "Rigid" tab on the software, you could reduce the "stick gain" - it's kinda like expo on your tx.
If you hover your cursor over the parameter in the software, a box appears that expains what it does.
Hope that helps
j_js1 is offline        Reply With Quote Quick reply to this message
