Go Back   HeliFreak > R/C Electronics Support > R/C Related Electronics DIY
R/C Related Electronics DIY DIY R/C Electronics for tinkerers and the budget minded
Old 02-10-2016, 07:30 PM   #1 (permalink)
Default Wire to wire extensions?
I recently swapped out an esc on my warp 360 and the new esc motor wires are about 15-20mm to short at the closest point I can mount the esc so I was wondering what the best way to go about extending them would be I also have to swap out the 3.5mm connectors on the esc to suit my 4mm connectors on the motor wires so I will be losing more length there there again
Fizzy is offline        Reply With Quote Quick reply to this message
Old 02-29-2016, 04:07 PM   #2 (permalink)
You probably already know what you should do.
You are going to need a soldering iron, solder and some skills.
Assuming the old ESC had 4mm bullet connectors (that matched the motor), unsolder them for reuse.
Don't unsolder / cut the bullets off the motor or the new ECS.
Assuming the new ECS has 3.5 male (or female), it most likely came with 3.5 female (or male) bullets that were loose in a ziplock bag. If not, then go buy three.
Get some 12awg (or something that is close to matching your ECS's / motor's wire gauge) and cut three pieces that are about 20mm each.
Solder the 3.5mm bullet on one end and the 4mm bullet on the other.
If you have three different colored shrink tube, then use that to "color code" each 20mm wire extension.
Bob's Your Uncle.
Old 02-29-2016, 06:48 PM   #3 (permalink)
Thanks for the reply and info, You just confirmed what I was thinking to be the easiest way to go about it ,
thanks again
