Old 06-27-2008, 10:53 PM   #201 (permalink)
[quote=mikef;736048]The BLUE LCD should work fine. It has the same controller and the pins are the same. The Backlight will be a completely separate circuit but all you have to do is connect power to the two pins that control the backlight.[quote]
which two are they? it's working but no back light..
kas4j is offline        Reply With Quote Quick reply to this message
Old 06-27-2008, 10:55 PM   #202 (permalink)
+5 on pin 15
ground on pin 16
jared_of_atlanta is offline        Reply With Quote Quick reply to this message
Old 06-28-2008, 03:37 AM   #203 (permalink)
Mine has connections marked A & K
K= Ground and A is +5v via a 22ohm resistor
falconea45 is offline        Reply With Quote Quick reply to this message
Old 06-28-2008, 12:33 PM   #204 (permalink)
The Capi
Anode and Cathode, the back lighting is just an LED.
Old 06-28-2008, 12:48 PM   #205 (permalink)
Why do you need a 22ohm resistor?
Old 06-28-2008, 01:40 PM   #206 (permalink)
The Capi
Limit the current. an LED is a diode, it has a forward conduction voltage then a very small internal resistance.
Old 06-28-2008, 01:58 PM   #207 (permalink)
Default heli tach
hey all i just got the rest of my parts to finish mine. however i am not having any luck.. the lcd is the one that mike used. also my ir led and sensor do not have poer at all to them? as it goes the question here is this. the a&K on the side ? do they need to be hooked as well on the power source?
copterx 450 ae v2(agusta 109a fuselage)
http://rcfriends.createforum.com
Hawk_Sport is offline        Reply With Quote Quick reply to this message
Old 06-28-2008, 02:02 PM   #208 (permalink)
Hook up your IR led to the +5V from your processor board and make a common ground connection there too. The sensor is wired to the PIC.
As for the LCD, some of us are finding that grounding pin 3 (instead of power it) will enable your display.
Jesse
T700N FBL - V-Bar w/ 3DX Head
T250 Super Pro - HS-5084MG Tail Servo
X9303
HELINHAWAII is offline        Reply With Quote Quick reply to this message
Old 06-28-2008, 02:23 PM   #209 (permalink)
Default heli tach
ok so what happens when you ground 3 instead of 5? make 5 live? you are losing me real bad here.... as for the ir and sensor. the board was made from a nother friend of mine... is the ir and sensor , and mem button all wrong? he went from what was on the instructions. the motor and 2.5 k pot work but nada else... very frustrating...and i have also changed project boxes....
Old 06-28-2008, 03:01 PM   #210 (permalink)
In the original design from mikef, on the lcd, pin #3 was wired to +5V along with pin #2. I am saying that some of us working on this project have found that wiring the pin#3 to ground instead of wiring it with +5V has enabled our displays to turn on where as they wouldn't before.
As for the IR led...it's is on it's own circuit with +5V applied to the anode and a resistor then ground applied to the cathode. What I was saying is that you can wire it to your processor board for power and ground. The instructions don't show that but the documentation states that all that is needed to tie all the individual circuits togather is to wire them all to power.
Does that help any?
Jesse
X9303
Old 06-28-2008, 03:29 PM   #211 (permalink)
Default heli tach
it somewhat makes sence, but the board that was made for me has everything on it as per the instructions. so i would have to go through everything again to see where everything is goin ... both the maker and i couldnt really tell from the pics where the ir led and sensor were goin on the board along as the mem button. if i could upload a diagram of the board i have you would see what i mean. i compared it to the specs of mikes diagram and it looks dead on but not sure... unless someone wants to email me then i shall send the diagram i have of the board that was made for me...
my email is
[email protected]
thanks guys for the help thus far
Old 06-28-2008, 04:45 PM   #212 (permalink)
Default heli tach
i figured out a way to actually export to a bitmap file so here is the board i have... any help would greatly be appreciated.
Old 06-28-2008, 05:41 PM   #213 (permalink)
Default heli tach
ok think i figured this out. maybe... looking at one of the pics in original file . is the mem button on 5and 6 or 7-8....? on the board itself? pink and white wires... also i dont know exactly where the sensor is located but my board following the schematics looks top notch.... another question here... if i neg number 3 on lcd where do i put the +5 live too? and where am i goin to ground too? the existing ground on 1?update... got the ir led goin but no go on sensor or lcd? update again... neg'd number 3 and now i get squares at top of lcd screen? any takers on this?
Old 06-28-2008, 09:58 PM   #214 (permalink)
Default heli tach
well i have givin up on this thing. i am now probly goin to put it in parts bin and leave it . just totally forget about it as i am unable to figure any of it out. i keep loking at the schematics of my board and then look to mikes and everything looks like it should work. so why is it not working? ehhhh i give up. junk drawer time
Old 06-28-2008, 10:18 PM   #215 (permalink)
The Capi
Hawk you coming to the T.dot smack down here in Toronto in a few days ?
Old 06-28-2008, 10:23 PM   #216 (permalink)
Default heli tach
haha wish i could, but i dont drive anymore. so i have no way to get there... hope ya have fun anyways... cheers and happy flyin
Old 06-29-2008, 04:19 PM   #217 (permalink)
Default heli tach
ok so i am still trying to figure out these blacks squares. i neg'd number 3 with number one. i am goin to take it off number one and neg it to the ground strip instead. see if that may work. however i still have the problem of the plus five i took off the 3.? where in the world am i putting that?
Old 06-29-2008, 05:24 PM   #218 (permalink)
Default heli tach
ok can anyone post a pic of their boards so i may see what is what? thanks
Old 06-29-2008, 05:31 PM   #219 (permalink)
I don't know what "neg'd" or "neg" means.
You don't put the +5 you took off of pin 3 of the LCD screen anywhere. You cut it off!
You should take a picture of your board. The board layout you posted earlier tells us where you put your parts, not how you connected them together (the more important bit).
Old 06-29-2008, 06:03 PM   #220 (permalink)
Default heli tach
i'll email you a pic of the board. that way you can see where everything is if you dont mind... its in pcb format. i open it using pcbexpress, i can email you that as well? or anyone that can help me with this as i am really getting peeved off... even with the negative(neg) on pin 3 on lcd i still get just the black squares. i am about ready to trash this thing ... so if anyone would like to offer any help pls do soo...
