Old 07-01-2008, 06:26 PM   #261 (permalink)
The Capi
Tach your TV.
Old 07-01-2008, 06:36 PM   #262 (permalink)
Originally Posted by HFG View Post
Tach your TV.
You're showing your age. Most people nowadays have flat-screen TVs that don't scan.
HeliFreak Support
Graupner MZ-32
Old 07-01-2008, 06:42 PM   #263 (permalink)
The Capi
CRT are infinitely better than "digital" displays.
Old 07-01-2008, 08:32 PM   #264 (permalink)
Got none to tach! We're all lowly "digital" display users here. I used to have one of those Sony Wega HD 36in flat tube TVs. What a great picture. If it wasn't for an 7.2 earthquake on Guam and the TVs 300lbs, I'd still have it!
But it made a HUGE mess, some choice sounds and lots of smoke!!!
Jesse
T700N FBL - V-Bar w/ 3DX Head
T250 Super Pro - HS-5084MG Tail Servo
X9303
HELINHAWAII is offline        Reply With Quote Quick reply to this message
Old 07-01-2008, 09:07 PM   #265 (permalink)
Digital is awsome--it's the compression SUCKS. IMO
jared_of_atlanta is offline        Reply With Quote Quick reply to this message
Old 07-01-2008, 10:04 PM   #266 (permalink)
The Capi
Watch a Barco or old Runco 9" gun CRT then tell me how great your "digital" tv is.
Old 07-01-2008, 10:56 PM   #267 (permalink)
Default heli tach
i know this is off subject but i have a atmega128 programmer. the red one. is it possible to change this to a pic programmer? i also have the smartcard for it.
copterx 450 ae v2(agusta 109a fuselage)
http://rcfriends.createforum.com
Hawk_Sport is offline        Reply With Quote Quick reply to this message
Old 07-02-2008, 08:58 AM   #268 (permalink)
The Capi
Short answer NO, longer answer NOPE.
Old 07-02-2008, 09:24 AM   #269 (permalink)
What wattage should the 22ohm resistor be rated at for the lcd backlight? Is there anyway to tell the wattage of a resistor by the colors?
Old 07-02-2008, 09:29 AM   #270 (permalink)
The Capi
A 1/4W will work fine. There is no colour bar for the wattage but you can tell by the size.
Old 07-03-2008, 06:40 PM   #271 (permalink)
OK on the breadboard my LCD contrast was too high on 5v but just right on ground, on the protoboard it is too low on ground. I'll try it on 5v but if that is too high, do I just put a resistor between the LCD pin 3 and 5v until I find what works?
Old 07-03-2008, 07:04 PM   #272 (permalink)
Nevermind 3.3Kohm resistor between ground and pin 3 works great.
Old 07-03-2008, 07:39 PM   #273 (permalink)
Hmmm. Found a problem with Hawk_Sport's friend's board (and mine since I copied it). The sensor has one lead going to the 4.7k resistor and pin 8 on the PIC. The other lead is connected to ground. It should be connected to 5v (according to Mike's diagram). This causes the PIC to not receive any signal from the sensor and makes the LCD display 0000 rpm. SO, Hawk_Sport, you're gonna hve to fix this on yours (PS: this wouldn't give you the block on your LCD screen so this problem is unrelated).
Old 07-03-2008, 08:06 PM   #274 (permalink)
LOL. With 3 viewing ports my tach reads from 660rpm to 15000 rpm. Guess I'll see if 2 holes gives me a little lower high end.
Old 07-03-2008, 08:22 PM   #275 (permalink)
Default heli tach
thanks Jared for noticing this and informing me of the problem... what pins did you connect it too? sorry meaning where did you connect the sensor too? so this wouldnt fix the problem at all about the blocks on top of screen? i was goin to take the chip outta package and try it again but?
Old 07-03-2008, 08:30 PM   #276 (permalink)
Default heli tach
i will be putting the other one to # 14 on the pic as this gives +5....
Old 07-03-2008, 08:38 PM   #277 (permalink)
Default heli tach
poop on me.... i buggered up and put the live on number 14 pic, instead of the ground.... now i gotta try and solder this one back and cut the ground instead and put it on 14 pic....
ok all fixed now... ground is running to pic #4 as this is also +5... i turn it on and still get black squares on top of screen ...mind you i dont have the disk installed nor the chip... the chip is packaged ready to be mailed to mike tommorow afternoon....
Old 07-07-2008, 09:50 PM   #278 (permalink)
Tach your TV.
1200 rpm
kas4j is offline        Reply With Quote Quick reply to this message
Old 07-09-2008, 11:50 PM   #279 (permalink)
In the writeup, it said to have a 2 inch disk with three 1/4 inch slots. What if I want two slots? How big should they be?
Old 07-10-2008, 12:37 AM   #280 (permalink)
I finally ordered my parts last week to build one, so hopefully they will arrive today or tomorrow so i have something to do over the weekend.
Nige69 is offline        Reply With Quote Quick reply to this message
