Introducing the Bump Controller CCS mobile app - Page 10 - HeliFreak
Old 07-10-2017, 11:00 AM   #181 (permalink)
Default Migrating Battery History from Android 4.x device to new device
Follow the steps below if you're replacing your old Android 4.x with a new device that's capable of running the latest CCS app with DropBox support (Android 5.0+ or Apple iOS):
1. Create a Battery History backup on the old Android 4.x device
- From the main screen, open Battery History screen (Tools -> Battery History)
- Perform the history backup (Tools -> Backup History)
- Resulting backup file will reside in the standard Android Download folder (location varies by device type)
- File name will be date-stamped with format of Download/CCS_History_2017_07_10.zip
2. Login/create DropBox account on the new Android or iOS device
- Install the new Revolectrix CCS app (v4.09+) on your new device
- From main screen, select History from the menu
- From Battery History menu, select Sync DropBox
- Click on 'Both' to perform a two-way sync with DropBox to confirm everything is working properly (no files will actually download since nothing exists yet)
- At the login screen, create/login to your DropBox account
- This will now connect the Revolectrix CCS app to your DropBox account and create a dedicated storage folder within your DropBox directory "/Apps/Revolectrix CCS"
3. Upload the backup .zip file to DropBox app folder "/Apps/Revolectrix CCS"
- There are several ways to get the .zip file uploaded from the old device to the DropBox app folder - direct USB connection to PC, or a variety of file management/upload apps.
- Simplest method is to simply install the free DropBox for Android client which is what is covered in these instructions
- Install DropBox app for Android, open the app, login with your DropBox account credentials
- In the left-hand pane, select Files
- From the file list, select "Apps", then "Revolectrix CCS" - this is the location where all CCS app data will be stored, including history
- Click the '+' button in the lower-right to add new files, then select "Upload files" option
- Locate and select your Download directory from the storage locations listed (exact location varies by device - sometimes its Internal Storage, others are on SDCard)
- Select the CCS_History_yyyy_mm_dd.zip backup file to upload it into the "Apps/Revolectrix CCS" directory
4. Unzip the .zip history file in DropBox
- This is probably easiest done on a PC or Mac - just select the .zip file and choose to unzip it into its current location
- This will merge the history files in the .zip into the "/Apps/Revolectrix CCS/history" directory where all battery history files are stored
5. Repeat step #2 and perform another 'Sync DropBox' to download all of the history data from DropBox to your new Android or iOS device
RevoKelly is offline        Reply With Quote Quick reply to this message
Old 07-10-2017, 12:28 PM   #182 (permalink)
Default Windows 10 CCS app status update
Just a quick update on Windows 10 CCS app progress ....
We are on hold until Windows 10 Universal Web App (UWA) SDK supports scanning for Bluetooth Low Energy devices.
UWA currently only supports pairing of BLE devices which is something that the Bump Controller hardware does not support.
This feature is supposedly releasing "soon" but I wasn't able to locate any dates.
Will post updates here as we know more.
Old 07-11-2017, 09:14 AM   #183 (permalink)
Originally Posted by RevoKelly View Post
What is the make/model of your tablet ?
Are you certain it supports Bluetooth Low Energy 4.x ? ... if not, download the free "BLE checker" app from Google Play to confirm.
Given the other Google Play issues, it wouldn't surprise me to find another gotcha, but confirming BLE support (the only specified hardware requirement for compatibility) is the first debugging step.
RevoKelly you are right this Android 6.0 tablet I purchased does not support Bluetooth Low Energy. I downloaded the BLE Checker app and it says not supported.
So for anyone looking to upgrade your tablet you can skip the INSIGNIA 8" tablet model# NS-P08A7100 It does not support Bluetooth Low Energy which is needed.
Thanks again for your help.
Revolectrix Ambassador BOOKER18
Gaui X3-Spartan VX1n | Gaui X4 II-Spartan VX1e | Gaui X5-Spartan VX1e | Gaui R5 V2-Spartan VX1n | Goblin 700 Speed-Spartan VX1n
JETI DS-14
iscripter is offline        Reply With Quote Quick reply to this message
Old 07-11-2017, 12:29 PM   #184 (permalink)
Gus
Kelly,
Update CCS v4.09 and Controller Firmware 4.02 release working fine on my:
Galaxy Note IV - SM-N910A (Android v 6.0.1) and on my new Galaxy Tab A SM-P580 (Android v7.0) Tablet.
Thanks...
Gus (KI7LPX)
Synergy E5s, Goblin 380KSE, Gaui X3, Beam E4, T-Rex 250 Pro, MX-155, CF-226, CF-258, F1-5, F1-6, Chameleon, AcroWhoop V2 (2), Convergence VTOL, SK SlowHawk 2, SK ParkHawk 4, Bionic Bird, CF Wing, ThunderBird EDF Jet.
Gus is offline        Reply With Quote Quick reply to this message
Old 07-11-2017, 12:54 PM   #185 (permalink)
Originally Posted by Gus View Post
Kelly,
Thanks...
Awesome !!!
Thanks, Gus
Old 07-12-2017, 05:39 PM   #186 (permalink)
Gus
Kelly,
Two things that I am seeing with the new release:
1- Bluetooth Transmitter is not being turned on by the Application like it did before, must now be turned on manually.
2.Charging 1 6s battery on one PL8 and a 2nd 6s battery on a second PL8 at the same time. The Tablet displays shows PL8 #3 and PL8 #4 screens side-by-side, but will only show the data from one or the other, Previously, an extra tap on the screen would show the data from both screens at the same time (side-by-side). If you need, I can shot the screen when I get back on Friday.
Gus (KI7LPX)
Old 07-12-2017, 07:28 PM   #187 (permalink)
Kelly,
1 - This is a side-effect of upgrading the Android SDK version - we are working on making it automatic. Just to clarify - this is only a problem when you manually turn BT off, right ? If BT is left on, then the CCS app always connects as expected ?
2 - We found that the double-tap behavior wasn't always discoverable, so we added explicit buttons for it . The "tab" and "grid" buttons in the upper-left serves the same purpose for switching between showing all chargers (grid) vs the selected charger (tab).
Old 07-12-2017, 08:56 PM   #188 (permalink)
Gus
Kelly,
1 - I will verify this on Friday.
2 - I will try this on Friday also.
Thanks...
Gus (KI7LPX)
Old 07-30-2017, 10:20 PM   #189 (permalink)
Can anyone that's running the iOS version confirm there are no issues with the latest CCS v4.09 and latest iOS update 10.3.3 ?
Thanks in advance!
-Dave
Logo 700 / 600 / 500 / Oxy 2 FE / Blade 180CFX / mCPxBL / nano CPS / V-Bar NEO / V-Bar Control / uBrain / DX7 / Diabolo 700UL next
Old 08-01-2017, 12:01 AM   #190 (permalink)
Thanks in advance!
-Dave
I installed and ran through 5 different charge cycles today. No issues with my BC+PL8v2 and iPhone.
Noticed new feature to allow changing charge constant current set point while charging... only on the BC and not in the iPhone app.
Got two more charge cycles in today (during lunch). App seems to be fine with iOS 10.3.3 and formula 409 (CCS 4.09)
KC8CYF is offline        Reply With Quote Quick reply to this message
Old 08-01-2017, 12:06 PM   #191 (permalink)
Great. Thanks!
Old 08-15-2017, 05:59 PM   #192 (permalink)
What does the 4 colored bars (red, orange, yellow, green) signify in the secondary information window cell voltage?
Bypass percentage?
Could not find anything in the manual about it.
Just curious.
Thanks.
Old 08-16-2017, 08:42 AM   #193 (permalink)
Bypass percentage?
Just curious.
Thanks.
Yes, cell bypass percentage for balancing.
Old 09-28-2017, 07:00 PM   #194 (permalink)
Default Bump CCS app version 4.12/4.13 and Bump firmware v4.05
Just requested release of the latest iOS and Android CCS apps which include Bump firmware v4.05, so you should see it available in the next few days (Android before iOS).
Several new goodies and bug fixes - let me know if you run into any issues:
// Version 4.12
// FEATURE: Controller connect timeout feature and setting
// FEATURE: Controller Firmware 4.05
// - BUGFIX: Battery history upload sometimes skipped
// - BUGFIX: Minor UI rendering cleanup (Cell IR warnings, numeric value edit, etc.)
// - BUGFIX: Sometimes prompted to perform Power Supply setup even though it has already been done
// - FEATURE: Trickle charge support for NiXX/Pb (both Trickle-only operation and trickle after peak)
// - FEATURE: "Show Power Supply Select screen on startup" settings option
// - FEATURE: Improved grouping/ordering of Settings
// - FEATURE: Optional "Simplified" UI mode (hides subview details)
// - FEATURE: Feature Controls for restricting capabilities
// (parallel charging, multi-pack, manual, favorites, rate adjust,
// clear setup on complete/stop/error, BumpTag/preset editing, settings access, auto-starting)
Old 03-30-2018, 12:16 PM   #195 (permalink)
Can you tell which logo of batteries this program knows?. I was able to find: Gens Ace, Thunder Power and which more? Cant find any info about it.
Thank you
Maksel is offline        Reply With Quote Quick reply to this message
Old 04-08-2018, 12:18 PM   #196 (permalink)
I just switched from an iPhone to a Galaxy S9+. I went ahead and purchased the Android version but the NFC tag read is not working. I have only used the iPhone version which obviously didnít support NFC. Was this feature removed from the Android version?
Gscott is offline        Reply With Quote Quick reply to this message
Old 04-08-2018, 04:22 PM   #197 (permalink)
Did you enable NFC on the Galaxy 9? It's not on by default.
"Just a lot of moving parts beating the air into submission"
rcflyersd is offline        Reply With Quote Quick reply to this message
Old 04-08-2018, 04:50 PM   #198 (permalink)
Yes. I double checked it again and it was turned on. Iíll try again later.
Old 04-24-2018, 02:38 PM   #199 (permalink)
After reading all the recent posts I was worried about having just updated my 2 Bump controllers. But my Galaxy S8, Bumps and my 2 dual PL8 chargers and 2 single PL8 chargers didn't skip a beat when I charged and discharged some batteries with them.
It's been a WHILE since I've upgrade their firmware. Looks like some nice improvements have been made.
Mark
mkovalcson is offline        Reply With Quote Quick reply to this message
Human Verification
