Go Back   HeliFreak > R/C Helicopters > Low Head Speed Helicopters
Low Head Speed Helicopters Low Head Speed Helicopter Setups and Flying info
Like Tree15Likes
Old 03-12-2018, 09:28 AM   #61 (permalink)
You're running a Kontronik ESC, right?
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL -- Charge Case
prototype3a is offline        Reply With Quote Quick reply to this message
Old 03-12-2018, 09:35 AM   #62 (permalink)
Yes old jive pro 80.
The 400 in theory should be more efficient for the speed (& less likely to have an issue). 80% throttle (as suggested In the manual) to get 1600 vs 40/50% with the higher kv motors.
Ran for years with the 560kv, and months with the 520 without issues.
Steve
smittylube is offline        Reply With Quote Quick reply to this message
Old 03-12-2018, 09:39 AM   #63 (permalink)
The settings in the jive are 1 resets and figures out end points, 4 for heli gov, 10 for other than kontronics motors. As in different kv, resistance etc.
Steve
Old 03-12-2018, 09:50 AM   #64 (permalink)
Mode 10 (KSA) is generally only for really low internal resistance motors like the big single strand Scorpions.
Bad news is that the old Jives are not servicable at all. So, if there is a problem with your Jive, then it's just a paperweight.
I would be curious to run the hacker with a different ESC and check it with a megger.
Old 03-12-2018, 02:06 PM   #65 (permalink)
Ok thats interesting. The 520 is a single strand motor. The 560 flown forever is multi strand.
I was waiting since the pinion was back order and this weekend received an 11 tooth pinion so I stuck that on the 520. now I get 1605 rpm with about 63 % throttle. Much more acceptable than below 50 like before.Not 70/80% like I was targeting, but lets see how this goes I guess. Sounds fantastic on my test / set rpm hovers.
Getting super fast now at a motor swap and set pinion ;-)
Steve
Old 03-12-2018, 02:09 PM   #66 (permalink)
IIRC 65% or so is where you want to be on a Jive. Something about their throttle being mapped different than other ESCs... But it's been years since I owned one so I could be wrong.
Do you have a JLog?
GimpyGolden likes this.
Old 03-12-2018, 02:17 PM   #67 (permalink)
Not jlog, using E-fuel gauge and his (Thomas's) telemetry tack with Futaba.
Just went from the 14sg to the 16sz and I love it. Had the 14mz for about a decade, but switched to the sg for telemetry maybe 2 yrs ago. The 16sz is like coming back home with the programming. So many similarities to the MZ.
Steve
Old 03-12-2018, 05:34 PM   #68 (permalink)
It would be interesting to borrow a JLog as I know it logs stuff that you can't get otherwise out of a Jive.
Old 03-12-2018, 06:22 PM   #69 (permalink)
From your comment about programming 10 for low ohm single wire motors - would a 400kv hacker multi strand qualify?
Did 2 packs today and it flew stellar.
Steve
Old 03-12-2018, 07:13 PM   #70 (permalink)
Hard to say with any certainty. I'd probably run it with and without KSA and see if I noticed a difference.
Old 03-12-2018, 07:20 PM   #71 (permalink)
I will fly it more when it stops raining and see how it goes with the 520.
Thanks for the help.
I was thinking of the tribunus 130, but I've heard of some having issues, and also not in stock at the time I looked. And heck this was working excellent for years. I just really like the Vbar gov and the CGY750 gov and neither work happy with the jive I have.
Steve
Old 03-12-2018, 08:17 PM   #72 (permalink)
I switched all my Helis to the Tribunus ESCs. 3 - 200amp, 2 - 120 amp, and 1 - 130 amp. I just bought the 130 but I ran six of them last year without issue. I am using the VBar governor and VControl.
Synergy 766, E7SE, E5SS, E5S, 516, Protos 770 Evo, V Control, Neo, Tribunus
Freeskiken is offline        Reply With Quote Quick reply to this message
Old 03-12-2018, 10:41 PM   #73 (permalink)
I put the tri tail on....it is sweet....super smooth. Just have to get a 3 blade set of 95mm tail blades. I have the Hacker A50 14L 400 KV Motor installed with the 11 tooth pinion.
ID:	740035   Click image for larger version
ID:	740036   Click image for larger version
ID:	740037   Click image for larger version
trillian likes this.
Old 03-13-2018, 02:50 PM   #74 (permalink)
Tim Jones and Matt Botos will match sets of blades for you if you buy two pair. I have matched sets of 95 and 105 Cyclone blades that I use on my tri-tails.
Old 03-13-2018, 09:09 PM   #75 (permalink)
Hey thanks for the info. I didnít know they would. I ordered a set of Zeal 95mm tail blades for now. I may try and get some Rail blades as well.
Old 03-13-2018, 10:26 PM   #76 (permalink)
That tail looks very nice.
I'd get rails in a heartbeat., but that's just my preference.
Does the tail come assembled or did you put it together?
15/1600 the regular tail holds well for me and my flying, but I'll bet at 1200 that will really help.
Does the new tribunus do telemetry mah voltage and tack??
Steve
Old 03-13-2018, 11:37 PM   #77 (permalink)
Tail looks nice whos is it? does Mikado make one, what is that 3 tiny looking battery looking thing on the rear of the heli frame?
B450X Scorpion Powered,Blade 180 trio,Torrent 110,Tricopter lots of planes AMA 28 yrs.
Old 03-14-2018, 08:22 AM   #78 (permalink)
Do you have a JLog?
Yep mapping on Jive (not Pro) is as follows
Throttle% /2 + 50.
So throttle say 60% on your (100/100) Tx is 60/2+30+50 is 80% internally.
Also you do want KSA on Jive. It was actually designed for Hacker E-Turbine, The Tunado's predecessor. Does help with Fat Scorps too.
All this is in one version of the manual, maybe Ver7.
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 03-14-2018, 08:43 AM   #79 (permalink)
--- not 60% above 50. More like 20% above 50 = 60.
Steve
Last edited by smittylube; 03-14-2018 at 09:04 AM.. Reason: 20% above 50 In throttle curve screen
Old 03-14-2018, 08:56 AM   #80 (permalink)
If you run 80% on Throttle % in Tx you have 90% on the Jive internally.
Be ok with high gear ratio maybe, but rpm will decay with voltage dropping at end of flight.
Human Verification
