Go Back   HeliFreak > R/C Helicopter Support > MSH Protos > MSH Protos 700/800
MSH Protos 700/800 MSH Protos 700/800 Helicopter Support Forum
Like Tree9Likes
Old 05-01-2016, 12:56 PM   #21 (permalink)
Originally Posted by mystar60 View Post
Alan, I was doing the same with my tail where I checked for binding/rough fit.
I was trying to determine where the pin was to hold onto - either the slider or the forks
I did not touch the tail pitch slider but just the forks, opening them just a hair for a smoother non rough movement.
The thought crossed my mind having the pin eject and doing some blur piro's into the ground.
Hmm that makes more sense than what I did. The slider has more surface area to hold the pins than the forks. Also I could ca it in there better. Maybe I should have 2 sliders just in case.
Protos Max V2 (build), Synergy 516 (build) Logo 480xx (build), Gaui NX4 (build), Protos 380 (build), Oxy2 215 Sport (build)
ultrataco is offline        Reply With Quote Quick reply to this message
Old 05-01-2016, 03:26 PM   #22 (permalink)
Finally getting around to working on it today. I just checked the tail slider. The ca has hardened, the pins are stuck in the forks real good and the slider still slides nicely.
Just to be clear, when I said the pins were loose I just meant looser than originally. they couldnt just slide out or anything. I only opened the hole of the inner part. The outer fork holes I left alone.
Should I still replace it?
Old 05-01-2016, 05:13 PM   #23 (permalink)
The tail is finished. I do not enjoy epoxy.
cat photobomb
"get out of the way"
good enough
Next up: cyclic servos (MKS 950)
ID:	650119   Click image for larger version
ID:	650120   Click image for larger version
ID:	650121   Click image for larger version
ID:	650122   Click image for larger version
Old 05-01-2016, 07:10 PM   #24 (permalink)
Looks good dude, love the cat photobomb
It's hard to say without witnessing what you did to give advice. If it was me I'd replace it, especially over a 12 dollar part
HELIDIRECT - HOBBYWING - XNOVA - XPERT - PULSE - ROTOR TECH
Colin Broughton is offline        Reply With Quote Quick reply to this message
Old 05-01-2016, 07:18 PM   #25 (permalink)
Thanks. Yeah I probably will replace it since I ordered a new one already. So it's ok if there's a little resistance there initially?
Old 05-01-2016, 10:17 PM   #26 (permalink)
ultrataco - wise decision over a $12 part
Thebum - sorry I mixed up the two issues
Team Only Fine Helis
Rave ENV Nitro, Protos 380 Evoluzione, Protos Max v2, VBar Control
https://www.onlyfinehelis.com/
mystar60 is offline        Reply With Quote Quick reply to this message
Old 05-01-2016, 10:29 PM   #27 (permalink)
Yes..
MSH Protos
Xpert-Xnova-Jeti
KSKen is offline        Reply With Quote Quick reply to this message
Old 05-01-2016, 10:59 PM   #28 (permalink)
Here's an update for today. This is a long one.
MSH servo arms match the servos. Cool.
Did I mention this is my first 700? I need a longer table.
Servos installed. I was going to go without the rubber grommets but after trying it both ways, I put them on because I didn't like fiddling with the servos to keep them lined up right. I cranked them down pretty hard so they feel pretty much as solid as hard mounted anyway.
Assembling and installing the main grips.
Washout arms. Oh look, another plastic fork and pin. Don't worry, I resisted the urge to do any modification.
Assembled head, except links:
That's where I decided to stop for today. Almost done (with the build part anyway).
ID:	650210   Click image for larger version
ID:	650211   Click image for larger version
ID:	650212   Click image for larger version
ID:	650213   Click image for larger version
ID:	650215   Click image for larger version
ID:	650216   Click image for larger version
ID:	650217   Click image for larger version
ID:	650218   Click image for larger version
Old 05-02-2016, 05:10 AM   #29 (permalink)
Why do some servo horn adapters have slots in them and some don't? Most of the pics I see of them seem to be without slots, yet look them up as a spare part and they have a slot in them.
Keep the pics coming...
MSH Protos Max V2 - Gaui X5/Hurricane 550 - Trex 500/450xl - Blade 300x/230s/mcpx bl
ukpaul is offline        Reply With Quote Quick reply to this message
Old 05-02-2016, 08:56 AM   #30 (permalink)
I'm not sure. This is my first experience with them. I assume the ones with slots are servo savers and the other kind are not, or maybe break-away type. I really don't know.
Old 05-02-2016, 11:53 AM   #31 (permalink)
I'm not quite sure what you guys mean.
The ones in the max v2, are the ones with slots.
Its just how they work. First you attach the center hub to the servo splines. Then you attach the servo arm, and use the screw to fix them, to the center hub, so the slot is there to be able to fasten then.
Maybe the the pictures you saw where not using the included servo adapters, for example mks x8 servos need to use their own because the kit ones do not fit.
zomaar is online now        Reply With Quote Quick reply to this message
Old 05-02-2016, 12:28 PM   #32 (permalink)
The centre hub in ultrataco's pics have no slot, like in most of the pics I see posted. Mine have a slot. Look them up as a spare part and they are shown with slots. I was wondering why. I guess the design was changed sometime.
Old 05-02-2016, 12:30 PM   #33 (permalink)
oh weird. I thought you were talking about the arms.
Old 05-02-2016, 12:38 PM   #34 (permalink)
They are referred to as 'servo horn adapters' in the manual, so that is what I called them, to avoid confusion, which seems to have confused everyone lol. Center hub or round bit in the middle might have been a better choice lol
Anyway, there appears to be two styles, without slot and with slot. I guess with slot is prolly a v2 version?
Old 05-02-2016, 12:48 PM   #35 (permalink)
heh I just read "slots" and assumed the arms. My Monday morning reading comprehension is not so great. I'm not sure what the slot would be for on that inner part.
As mentioned earlier in the thread, I apparently have an older tail fin so it's possible I have other older parts, too. That would be odd since I just ordered mine from the most recent batch a week ago. Oh well. I don't mind.
I can't wait to get back home and work on it.
Old 05-02-2016, 01:45 PM   #36 (permalink)
I also assumed you talked about the arms :-)
Old 05-02-2016, 01:58 PM   #37 (permalink)
"As mentioned earlier in the thread, I apparently have an older tail fin so it's possible I have other older parts, too. That would be odd since I just ordered mine from the most recent batch a week ago. Oh well. I don't mind. "
My kit also had the solid fin using 3rd bolt.. I also had the washout arms pre-assembled.. My first kit also included Gorilla gear...second one didn't. Must depend on who packed the kit and to what extent some items were assembled..
MSH Protos
Xpert-Xnova-Jeti
Old 05-02-2016, 10:08 PM   #38 (permalink)
This sure makes turning links easier.
links installed
Batteries partially mounted. When I have a better idea of where cg should be, I have some 3M industrial velcro to stick onto the trays.
ESC: Hobbywing 160, the first thing I bought for this build a few months ago.
I soldered on bullets for the motor a while ago, soon after I got it.
Now this is the part I'm most unsure about in the whole build. Hooking up the ESC/battery wiring. It also seems like it may be tricky to hook up the motor wires. They are going to have to bend pretty good. and I have to keep it all away from the motor. Also, I need to buy some tape to stick on the esc.
This is how I want to hook up the batteries.
ID:	650386   Click image for larger version
ID:	650390   Click image for larger version
ID:	650391   Click image for larger version
ID:	650392   Click image for larger version
ID:	650394   Click image for larger version
Old 05-02-2016, 10:31 PM   #39 (permalink)
Using zipties for now. Not sure I trust it enough to fly like this though.
Old 05-02-2016, 11:01 PM   #40 (permalink)
You could do this.
Diabolo 550 Vbar NEO : Diabolo 600 Vbar NEO : Diabolo 700 Vbar NEO: OXY 5 Vbar NEO : Logo 600SX V2 Vbar NEO : SAB G380 Vbar NEO : OXY3 TE : Vbar Control : Citizen 735
shadco is offline        Reply With Quote Quick reply to this message
