Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 230S
Blade 230S Blade 230S Helicopters Information and Help
Like Tree232Likes
Old 03-06-2018, 01:43 PM   #441 (permalink)
Allan, did you check the tail rotor for a hairline crack?
Perhaps you hit a ghost with it, causing a hairline crack, in turn leading to your mishap.
net wurker is offline        Reply With Quote Quick reply to this message
Old 03-06-2018, 04:33 PM   #442 (permalink)
Originally Posted by jrman83 View Post
Good luck in that helping. IME with trying similar superglue will not hold to the plastic surface. Sanding it helps, but still not very good. A 2-part epoxy works much better. In a crash they will pop right off with superglue.
Well, unfortunately I was able to prove this wrong haha. The glue held. The zipties themselves broke lol. Along with the brand new chassis, brand new MH tail rotor, and one blade grip.
I can however say the Blade CF main blades are much stronger than stock (zero damage, even though they cut into the ground enough to get covered in dirt), and the MH tail boom is much stronger than stock (very mild bend, and took much more effort to straighten than a stock boom, also did not kink like the stock one does).
Also to note, the MH tail booms are sold in packs of two, for the same total price as a single stock one. So they're half the price too.
Pics in a bit
Nano CPS - 230s - Align 470LT - Goblin 570 - Goblin Black Thunder 700 - Rustler VXL - Hubsan H107D+ X4 FPV - LaTrax Alias
motoxxxman is offline        Reply With Quote Quick reply to this message
Old 03-06-2018, 04:41 PM   #443 (permalink)
I'm longing to get mine in the air. Deep freeze seems to be over.
Me_How is offline        Reply With Quote Quick reply to this message
Old 03-06-2018, 05:10 PM   #444 (permalink)
I will have a good look. The tail rotor is pretty new as I split the leading edge off a blade a few flights ago.
Pics in a bit
oh dear you are not having a lot of luck. Whilst frame damage is not too expensive to fix its a PITA to take everything loose to do it. If I crash and its clearly my fault then so be it but I hate crashing when I don't know the reason, which is what happened today.
Allan114 is offline        Reply With Quote Quick reply to this message
Old 03-06-2018, 06:16 PM   #445 (permalink)
Proof glue works.
I'm gonna do the same to the new chassis again too. It was a hard impact directly to the front of the skid, so I can't say the zipties didn't reinforce it. Actually, I think I CAN say the zipties helped. Look at the right side. It didn't break at the normal point, it broke at the actual mount, which glues together very easily
ID:	739322   Click image for larger version
Old 03-06-2018, 06:20 PM   #446 (permalink)
I know right? I don't know what caused this crash either. I think I may have lost orientation and rolled the wrong way? But I don't know for sure. And yeah, I don't mind buying a few parts here and there. But I just rebuild the entire thing with a new chassis last night, and now I have to do it all over again. Well, I may just glue the chassis for the time being. What does bother me a little now though is I just noticed the anti-rotation bracket broke off too, and nobody [local] has that in stock. So I'm grounded until I can receive a new one in the mail.
Old 03-07-2018, 10:10 AM   #447 (permalink)
Waiting for parts is something I have to do all the time. Something breaks and the LHS doesn't stock spares for the 230s so its onto the auction site for parts. Guaranteed it will be excellent weather when I am waiting for the parts. This was the main problem with the 180cfx as it ate parts. I am waiting for zip ties at present but the heli is back together and working.
Old 03-07-2018, 10:52 AM   #448 (permalink)
My heli would have been in the air quicker if I could have remembered the order of the plugs in the Rx. I forgot about the unused sockets. Does anyone have a diagram of the plug order. I would post one but I can't upload images until I sort my computer. My old steam driven one won't talk to a a lot of websites.
Old 03-07-2018, 10:57 AM   #449 (permalink)
https://www.helifreak.com/showthread...=2#post7531804
Scroll down to the fifth picture.
Flightnite1 likes this.
Old 03-07-2018, 11:46 AM   #450 (permalink)
Thanks that is useful, I've now copied it into my manual. I thought after a rebuild I would need to do servo centering and trim flights but it flies rock steady, so we are back in business.
motoxxxman likes this.
Old 03-07-2018, 11:51 AM   #451 (permalink)
Kewl!
Old 03-09-2018, 05:44 AM   #452 (permalink)
I got time to nip out and put three packs through it today and three perfect flights after the frame swap, so confidence is on the way up again now.
By way of stimulating some conversation this helicopter is a delight to own and fly. I really like the simplicity of the tail motor which dumps all the gears and shafts to drive the tail and also the servo and pitch control bits for the tail rotor. I've noticed on this section of the forum that we don't have continual threads about tail wag or vibration. Ok the helicopter is not as responsive as some but as a sport flyer it is great. I know I will never make a full on 3D flier. The other thing we don't hear much about is servo, ESC or Rx problems. These servo's don't seem to suffer in crashes. On my 180 I had just bought it and was spooling up to take off, The heli tipped and one blade struck the deck and it knocked one of the servos out, stripping a tooth off a gear, so I was straight into getting metal gears after about 2 seconds of using it!!! As I say I hit the ground hard the other day and the servos are perfect. Its the same set up as the 180 so I don't know why the servos weren't damaged. Are they metal gear servos?
Old 03-09-2018, 06:39 AM   #453 (permalink)
Yes the 230s are metal gear and one could argue oversized for the application. All good things for a sport/learning heli.
I have tons of helis from 180cfx, oxy 2, oxy 4, goblin 380s and 500s, protos 380, protos 500, T-Rex 470, mikado logo 550se and 3 700 helis. Guess what.... I still love flying the 230s for nice, relaxing sport flying in tight areas.
In fact I just fixed it back up the other night to get her going again after a crash this past December. Can't wait. Always a fun little heli to fly
Thickfog is offline        Reply With Quote Quick reply to this message
Old 03-10-2018, 12:10 PM   #454 (permalink)
Smile New season just started
After long wait took mine out for a pack, but it was too gusty during the day. Greased up main gear a tiny bit because it sounded like a coffee grinder.
Later put the night blades on and put another pack through at dusk, finishing off with taking dirt sample with tail fin.
I also learned something new - it is possible to crack an LED.
Have to retrace one tail side now.
and finally... my first tail rotor gave up when dirt sampling.
Still flies 100%, but I'll just swap it out or I'll never use my spares. BTW mine stock tail motor & rotor has zero play on the shaft contrary to observation of others.
ID:	739671   Click image for larger version
ID:	739672   Click image for larger version
ID:	739673   Click image for larger version
Old 03-10-2018, 01:30 PM   #455 (permalink)
Shame about taking a dirt sample with the fin. The tail rotors are very weak so that's to be expected, but I don't know how you fix the LED's I've not played with these. It sounds as if the mesh on your main gear is a bit on the tight side if it is a new undamaged gear. They normally sound very smooth. I would move the motor back a little and try that. I would also adjust the tail rotor hub a little to give some play. I don't really think it is a good idea to lubricate the gears as the helicopter seems to pick up quite a bit of dust that combines with the oil/grease to make a nice compound that causes wear.
Old 03-12-2018, 10:52 AM   #456 (permalink)
3 wks into 230s. It's an amazing heli. U can just about flying any style from basic to advance 3D. I haven't had any issues.
I was saving money for Fusion 270 but .... i'm thinking getting an another 230s and flying alternate. That's how much i fond of this heli....
2005h4 is offline        Reply With Quote Quick reply to this message
Old 03-12-2018, 12:57 PM   #457 (permalink)
I am glad you are enjoying your 230, they are great helicopters and, I find, very reliable.
I am not sure about buying another complete helicopter unless you fly some way from home and really feel the need to have a second "bullet so to speak. I would buy a bag of spares. Tail rotors, blade grips, main frame, tail boom are the only bits I've damaged with a few crashes. The tail boom was repaired and bent straight ok.
Old 03-12-2018, 03:08 PM   #458 (permalink)
how long does motor last?
Old 03-12-2018, 07:26 PM   #459 (permalink)
I've never heard of the main motor failing, ever.
The tail motor however can die if something causes it to overheat too many times, or if the wires get pinched without you knowing when installing a new boom. Crashes can kill the tail motor too if it hits a hard surface at the correct angle.
Old 03-12-2018, 10:30 PM   #460 (permalink)
good to know...thx.
Around 7 batteries continuous flights every day for pass 3 wks.
150s, oxy2, 360 cfx 3s & DX9
