Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 230S
Blade 230S Blade 230S Helicopters Information and Help
Like Tree242Likes
Old 08-09-2018, 11:31 AM   #781 (permalink)
Originally Posted by Liduno View Post
The flight system compensates for the CG, there's no need to add weight, that will only add to your collective issues..If anything, just move the battery forward. The collective issue may just be that you're used to bigger more powerful helis? You can set your travel adjust to 125. If that's not enough, you can adjust your throttle curve.
Do you recommend increasing both the POS and NEG to 125 or just the POS? Thanks
Blade 500X, 450X, 300CFX, Fusion 270, 230S V2, 180CFX Trio, DX6i, DX7G2, Devo 7/10, Walkera 450D01/03 ++
corbettkg is offline        Reply With Quote Quick reply to this message
Old 08-09-2018, 12:18 PM   #782 (permalink)
Different radios have different settings for travel adjust, the DX6i for instance has an arrow for each direction of the stick. You will effectively increase the sensitivity of the stick by increasing the travel to 125 in both directions. If you just do it in one direction, you wont have equal reactions in positive and negative pitch.
Just to be clear, I'm talking about travel adjust, not expo or dual rates. I don't think expo/dual rate effects the pitch or throttle channel.
T-Rex 250 450x 300x 180CFX MCPX-BL B400 130X MCPX 230S NANO-CPX NANO-CPS MSRX 120 SR MSR MCX
IF IT CAN'T BE FIXED WITH DENTAL FLOSS, THEN IT CAN'T BE FIXED..LOL
Liduno is online now        Reply With Quote Quick reply to this message
Old 08-09-2018, 01:15 PM   #783 (permalink)
OK, thanks. I thought that is what I should do. I have the DX7 G2 Tx. The TRAVEL ADJ has 100 over 100 on the screen rather than arrows but works the same as you described. I will give it a try.
Old 08-09-2018, 10:18 PM   #784 (permalink)
Just picked up my V2 today. It’s my first heli larger than an MSR X and a nano CPX. I flew 3 batteries tonight with no issues whatsoever and no crashes. Since I have a DX6i, all flying was in agility mode. I am beyond impressed with this thing. It instills so much confidence and trust. When coming from the nano, this heli allows you to swing the tail with such confidence and know what you angle will be coming out. I’m in love with the thing. By the third battery I was doing high speed fly-bys with control and stability.
I did not believe I would progress near as far as I did in three flights.
Kudos to Blade. They knocked it out of park with this one.
Cman likes this.
Mochocow is offline        Reply With Quote Quick reply to this message
Old 08-10-2018, 05:14 AM   #785 (permalink)
Originally Posted by Mochocow View Post
Just picked up my V2 today. Itís my first heli larger than an MSR X and a nano CPX. I flew 3 batteries tonight with no issues whatsoever and no crashes. Since I have a DX6i, all flying was in agility mode. I am beyond impressed with this thing. It instills so much confidence and trust. When coming from the nano, this heli allows you to swing the tail with such confidence and know what you angle will be coming out. Iím in love with the thing. By the third battery I was doing high speed fly-bys with control and stability.
Like you I found this heli really quite easy to fly after my 180cfx. I think all the smaller heli's are quite twitchy and fast to react but the 230 is more sedate in the sky. I also like its simplicity with no mechanical tail drive. This gets rid of a lot of complexity, reduces the parts count and potential sources of vibration and noise. Hence I also find the 230 a very quiet heli.
Allan114 is offline        Reply With Quote Quick reply to this message
Old 08-10-2018, 05:22 AM   #786 (permalink)
I went out and put three packs through my spare 230s today. It is quite windy so just really poodling around. I have found that I can get 5:25 minutes out of my 1000mAh Gens Ace batteries with this heli as it has the std 230s motor. My normal 230 has the larger Turnigy 4200 motor and I only get 4:25 with that. This said the Turnigy motor as quite a bit more punch in collective.
I've also been building up the RKH frame. I find this really easy to work with and its a pleasure not to have to use the self tapping screws. The only bit where you need the old self tapping screws is for the swash anti rotation guide and one of those screws stripped out in the guide but I found that it can be drilled out to 2mm and a blade nut and bolt can be used through the whole lot which has got to be stronger. Another thing I noticed is that all the bolts are only really just nipped up so it would be best to undo each bolt, add a small bit of loctite and then screw it up a bit firmer.
Old 08-10-2018, 02:53 PM   #787 (permalink)
Congrats
The 230 is just a must have heli.
You can certainly give credit to the Nano tho.......such a twitchy little guy, but also the ultimate simulator. Sims are fine, but the Nano will advance you quickly.
The 230 as you found out is just a perfect flying machine in Agility mode.
A most enjoyable flyer.
AMA 70865
mikem65d is offline        Reply With Quote Quick reply to this message
Old 08-11-2018, 12:01 PM   #788 (permalink)
Well I finished the build on the RKH frame today. I noticed that I had to shorten the control rods about three turns each to get zero pitch with the servos set to centre. On the test flight I ended up shortening the control rods one more turn to get the lift off point on the stick about one mark above centre. I then had a vibration and landed and found the tail boom had come loose as I'd missed tightening and loctiting two screws on the tail boom clamp so I just nipped them up and flew off again. I still noticed some blade tracking issues and every now and then a funny fluttering noise from the rotors. When I got home I changed them for a new set I had and what a difference. Much smoother and quieter.
Has anyone else had a duff set of rotors.
Cman likes this.
Old 08-11-2018, 08:23 PM   #789 (permalink)
I'm a little confused, are you still 0 pitch at center stick?
Old 08-12-2018, 10:48 AM   #790 (permalink)
Yes it is about zero pitch at centre stick. I don't really bother to spend ages setting the pitch statically because it is all about how the thing flies and at what point on the stick travel the heli leaves the ground. I like the heli to leave the ground at just above mid stick. What I do is just do some take offs and note where the stick is and adjust the servo rods until it lifts and starts to hover where I want. I think all these stability modes etc can give a false impressions when setting up in a static environment. I set the servos level using the servo centreing feature then set the swash level and the blades about neutral pitch at mid stick then start flying and fine tune from there.
Old 08-12-2018, 05:10 PM   #791 (permalink)
Wont that give it less negative pitch? Couldn't you do it through pitch curve, that way it's the same when inverted?
Old 08-12-2018, 09:52 PM   #792 (permalink)
Last iteration of these 230's. I bought three new ones back when they came out. After the next crash they will be officially retired. probably have three thousand flights on them. motors still strong. all electronics are solid including the servos. I'm flying without a canopy post, and cracked frame. Original skids, mains and swash. Thats about 35 cents a flight.
BrokeDad likes this.
jackovart is offline        Reply With Quote Quick reply to this message
Old 08-13-2018, 04:59 AM   #793 (permalink)
Not really, it hovers upright at about one mark positive on the stick and inverted it hovers with about one mark negative. I would say if the heli lifts off at mid stick then you have a little too much positive pitch. At zero pitch the heli should not lift.
Old 08-13-2018, 07:28 AM   #794 (permalink)
0 pitch at midstick, by definition, means it shouldn't have lift. What I meant was, give a little more negative pitch below midstick, and a little more positive pitch above midstick by using your pitch curve settings.. That way you have equal positive and negative pitch. If you add positive pitch by adjusting the links, you have to be decreasing negative pitch.
Old 08-13-2018, 01:37 PM   #795 (permalink)
I understand but I am not sure on this DXe how to do that.
Old 08-13-2018, 01:59 PM   #796 (permalink)
AH OK! I never reprogrammed a DXE, I don't know how adjustable they are. I know you can download different models, but I don't know if you can customize the settings.
Old 08-13-2018, 06:35 PM   #797 (permalink)
Got myself a new flying spot. Good friend of mine just happens to live on a plot of land most conducive for flying. It is a 200 yard bowl that descends about 100 feet over the flying distance. So you take off and fly down hill. Big open space. Going out tonight for some laps.
Old 08-14-2018, 03:48 AM   #798 (permalink)
Lucky you that sounds great, I wish I had a bit of private land to use. I have to share with dog walkers and, now in the school holidays, lots of kids. Sometimes when I walk up to my field and see several people around I turn round and go home.
Old 08-14-2018, 12:44 PM   #799 (permalink)
Default Upgrades/ New canopy
Hi all, Thanks to BrokeDad I got this 4503D Blaze canopy, thought I'd give it a try and its just dandy!!! I put a small piece of foam under the front landing gear support to attach the tab on the canopy to keep it from moving as it was rubbing on the main gear. I used some double sided foam tape to mount it and cut a slit for the tab, works great. The landing skids are the CF Microheli U type that raises the tail up a bit. All else is stock. That is an Admiral 1600mah 30c Batt with the lipo low voltage alarm on it. I had quite a time trying to fit that with the 1000 or 1300mah batts I use with the stock canopy, but this 450 canopy has loads of room, with the 1600mah I am getting 15 minutes of flight sport flying no 3d. Awesome visability as well. Balances spot on also.
ID:	753341   Click image for larger version
ID:	753342   Click image for larger version
ID:	753343   Click image for larger version
T-Rex 470LP, Goblin 380, XL Power 380,T-Rex 500XT, XL Power 520, Oxy 4 Max, Align 300X
MSH Brain2
Spektrum DX8 Gen2
BgSkyFlyr is offline        Reply With Quote Quick reply to this message
Old 08-14-2018, 12:57 PM   #800 (permalink)
Looks Great BgSkyFlyr !! I added a small piece of foam too. It's super quiet and really helps my old eyes see it better. I have white skids on mine from the 200S/SRX.
Team USED
Shape S8,G700,G500,Shuttle 550,Trex 500 E/EFL Pro,Oxy 3(2),B400(5),450X,360CFX,Fusion 270(2),230S (V1/V2),200S,120S,Nano (CPS/S2),K110/120/130
BrokeDad is online now        Reply With Quote Quick reply to this message
