Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 230S
Blade 230S Blade 230S Helicopters Information and Help
Like Tree268Likes
Old 05-31-2020, 05:19 PM   #1221 (permalink)
Nice!!!
The_Fox likes this.
T-Rex 250 450x 300x 180CFX MCPX-BL B400 130X MCPX 230S NANO-CPX NANO-CPS MSRX 120 SR MSR MCX
IF IT CAN'T BE FIXED WITH DENTAL FLOSS, THEN IT CAN'T BE FIXED..LOL
Liduno is offline        Reply With Quote Quick reply to this message
Old 05-31-2020, 06:10 PM   #1222 (permalink)
Took Brick's advice and sprayed the landing gear white. I dig it. Thanks Brick!
Brick likes this.
Team Newb pilot
All my helis and quads were lost in a tragic boating accident.
NCcraig is offline        Reply With Quote Quick reply to this message
Old 06-01-2020, 05:21 AM   #1223 (permalink)
looks GREAT The_Fox!
The_Fox likes this.
Vcontrol Touch, AccuRC & Heli-X Simulators
Oxy 5 MEG, 4 MAX
Logo 200 & 700 (RIP)
XL Power Specter 700 v1 & v2
Old 06-01-2020, 04:57 PM   #1224 (permalink)
Thanks! I can not promise, but i think this was the last one i made with Blade 230S internal mecanics. That's why i wanted it to be a blast.
Next will be a Blade 550X/600X project.
fiddle likes this.
My Helis: https://www.helifreak.com/album.php?u=238607
The_Fox is offline        Reply With Quote Quick reply to this message
Old 06-01-2020, 07:20 PM   #1225 (permalink)
After a crash caused a motor failure I've been twiddling my thumbs waiting on the replacement. Well today it came! Took about 20 minutes to replace the motor, they made it pretty easy with this little fella. Anyways here's a snippet of it! Hopefully it sounds right now!
230s V2 Back in action (0 min 40 sec)
c4r0n1x is offline        Reply With Quote Quick reply to this message
Old 06-02-2020, 01:21 AM   #1226 (permalink)
Looks right to me!
Old 06-02-2020, 10:41 AM   #1227 (permalink)
https://youtu.be/TdesgKOHIgA
I'm sorry I can't remember the settings I adjusted, but you can make the collective a little less twitchy. I only bring this up because it looks like you're smooth everywhere except collective/pitch control. I want to say I lowered my pitch, then raised the servo limit? Or vice versa? Which ever one it was, I ended up with the same amount of over all pitch, but it took more stick movement to get it there. It made my pitch control soooooo much smoother.
Old 06-02-2020, 12:16 PM   #1228 (permalink)
I just played with the pitch curve a little and it helped. Also a warn or sticky swash can make it jumpy.
I got my new swash today after breaking the anti rotation pin. Fitted it in about 5 mins and then went out and put 3 batteries through it. It was a little turbulent today but still some good flying.
Allan114 is offline        Reply With Quote Quick reply to this message
Old 06-02-2020, 04:55 PM   #1229 (permalink)
Ya, I guess you could spread out the middle numbers and get a similar effect.
Old 06-03-2020, 08:28 AM   #1230 (permalink)
Thanks I'll see if I can't dial that collective in a little bit!
Old 06-03-2020, 11:05 AM   #1231 (permalink)
Another thing that helped me with my DX6I, was to add a strip of nylon to the detente. Inside the transmitter, there's a metal strap that you can set to ratchet, for Plane mode, or slide, for Heli mode. I added a piece of nylon to that, to make the collective stick slide smoother. A ''sticky stick'' is bad for a smooth collective change.
I cut up one of those furniture slide things. Those things you put under heavy furniture, so they will slide on carpet.
Old 06-03-2020, 11:31 AM   #1232 (permalink)
There is a thread somewhere about the “Teflon mod” that describes this in greater detail. I use mouse feet tape on mine.
toadiscoil is offline        Reply With Quote Quick reply to this message
Old 06-03-2020, 11:50 AM   #1233 (permalink)
You're right, it was Teflon, not nylon
Old 06-03-2020, 02:33 PM   #1234 (permalink)
Question
I just had a mid flight tail motor failure. Black wire came off the ESC for tail motor.
Tools out, let's figure out what happen...
Edit: I can't figure out why it happen, but luckily nothing shorted and one quick solder job later and I'm in the air again. It's almost midnight here and almost full moon outside. Just returned from a test flight and all seems nominal. Still loving my night kit.
Me_How is offline        Reply With Quote Quick reply to this message
Old 06-03-2020, 09:02 PM   #1235 (permalink)
I had to soldier a couple wires on one of mine too.
Old 06-04-2020, 12:03 PM   #1236 (permalink)
Default smooth
Maiden my new 230S V2 yesterday. Flew really smooth like my 550X. You see the videos but until you fly one have one.......
hoverfun is offline        Reply With Quote Quick reply to this message
Old 06-05-2020, 02:04 PM   #1237 (permalink)
A picture is worth a thousand 4 letter words...
Old 06-05-2020, 03:40 PM   #1238 (permalink)
ouch mate
MCX2,NanoCPX,MCPX V2,NanoCPS V2,MCPS,
130X,Trio 180 CFX,70S,230S V2,450Xx2 230S Smart,150S,DX8,NX8
Stormbringer is offline        Reply With Quote Quick reply to this message
Old 06-05-2020, 03:52 PM   #1239 (permalink)
With that bend in the boom you can now put on a scale fuse
Beserkr likes this.
BrokeDad is offline        Reply With Quote Quick reply to this message
Old 06-05-2020, 04:02 PM   #1240 (permalink)
Originally Posted by BrokeDad View Post
With that bend in the boom you can now put on a scale fuse [IMG class=inlineimg]https://www.helifreak.com/images/smilies/icon_biggrin.gif[/IMG]
Lol I'm trying to practice 3d I need someone to hook a trainer cord to
