Go Back   HeliFreak > R/C Helicopter Support > MSH Protos > Protos 380
Like Tree4Likes
Old 01-16-2017, 10:39 PM   #321 (permalink)
changing the setup i have soon
tacomaster is online now        Reply With Quote Quick reply to this message
Old 01-17-2017, 10:18 AM   #322 (permalink)
The Airetic
Originally Posted by OnTheSnap View Post
I haven't tried it yet, but I plan to fully test out a Edge Lite 50 or Edge 50 with heatsink and see how it works for the 380 (I'm sure they fit, but need to check). I'm not sure if the Edge lite 75 fits. It's def overkill.
But all these ESC can be used for Brain2 telemetry with current.
Edge 75 Lite will definitely fit. I managed to get one, and a Unisense, stuffed into the nose of my speed P380, with some skill, a lot of patience and a little spit.
Originally Posted by tacomaster View Post
What will suck is you will have to run an external BEC with those esc's. Edge is like 3amp continuous
And yeh. It does suck. I dont know why Castle can't seem to offer ALL of their features in one ESC. I got tired of waiting and moved to HW ESC's. I only run that Edge 75 in the speed because there was not a suitable HW for it.
Free Agent....With standalone opinions.
KiloXray is offline        Reply With Quote Quick reply to this message
Old 01-17-2017, 10:34 AM   #323 (permalink)
Does the HWv4 80 fit? It has the current sensor.
cquillen is offline        Reply With Quote Quick reply to this message
Old 01-17-2017, 11:43 AM   #324 (permalink)
Don't think so.
HW80A V4 Dimensions: 84.3x38.2x20.4mm
P380 ESC compartment dimensions:
HAPPY FLYING!
http://www.baysidercclub.com | AMA#912659 | RCHN #830
Jeti DS14 | Brain2
Protos Max V2 | Protos 380
canbarelyhover is online now        Reply With Quote Quick reply to this message
Old 04-18-2017, 12:48 PM   #325 (permalink)
Hi Guys!
I've ordered a 380, time to choose batteries....
Sorry if it was already answered, can you tell me what are the max battery dimensions for the 380? I know most of you runs the 1800 pulse, or optipower batteries, but i'd like to know what fits under the canopy in milimeters.
XL Power 520 - XL4020-motor, DS512HV + DS825 servos, Spirit Pro FBL
XL Power and Spirit FBL field rep.
Gtamas90 is online now        Reply With Quote Quick reply to this message
Old 04-20-2017, 01:21 AM   #326 (permalink)
Hogy vagy Tamas?
Which packs do you want to use?
- Michalis - OXY Heli -
...let the flying be second nature!
acidla is online now        Reply With Quote Quick reply to this message
Old 04-20-2017, 06:16 AM   #327 (permalink)
1800 is about the biggest you can run and keep it balanced.
tshelby73 is online now        Reply With Quote Quick reply to this message
Old 04-22-2017, 01:27 PM   #328 (permalink)
Originally Posted by acidla View Post
Hogy vagy Tamas?
Jól vagyok köszi, és te?
I plan to use Graphene 3S 1800 65C, two of them side by side in series.
The Pulse 1800 is around 44mm wide, this setup will be around 51-52mm wide, hope it will fit, already ordered 4 of them (to make 2 6S batteries )
BTW http://msheurope.com is now open, and shipping is free on orders above 100Eur!!!
Old 04-23-2017, 11:34 PM   #329 (permalink)
Én is jól vagyok a barátom
I believe 52mm width will be fine.
From where you found Graphene packs?
Old 04-24-2017, 06:09 AM   #330 (permalink)
It appears he found some 3s packs and is going to series them.
Old 05-30-2017, 06:57 AM   #331 (permalink)
Default Z power 850kV on P380
Does motor from Protos 500, Z-Power Z20A, can fit in P380?
Diameter 43mm, lenght of can 50mm.
Or original protos 500 black motor?
kV is OK but dimension and weight?
Anyone with that setup?
davor6696 is offline        Reply With Quote Quick reply to this message
Old 05-30-2017, 08:02 AM   #332 (permalink)
My concern is that the shaft isn't long enough since the protos 380 grub screw is on top. If someone has one to measure it may help.
Team MSH USA - Cyclone Blades
MSH Prôtos 380 Brain 2
MSH Prôtos Max V2 Brain
vtown nick is offline        Reply With Quote Quick reply to this message
Old 05-30-2017, 01:57 PM   #333 (permalink)
Lenght of shaft sticking out from motor is 24mm.
Old 08-11-2017, 02:58 PM   #334 (permalink)
Originally Posted by myxiplx View Post
Here's mine:
Heli ------------- Protos 380
FBL ------------ MSH Brain 2
Motor ---------- Xnova Tareq Edition 3215-930kV
ESC ------------ Hobbywing Platinum 80A v4
Servos --------- Turnigy S306G-HV
Tail -------------- MKS DS95
Batteries ------ Mix of existing 6S packs: Gens-Ace 1450mAh, Align 1450mAh, misc 1300 and 1200mAh. May pick up a couple of OptiPower 1800mAh packs.
RX -------------- Jeti REX6
Blades --------- Switch 383
Misc ------------ MSH Powerbus & Jeti MUI75 sensor (or JLog3 when available)
Did you have to modify anything to make your 80a v4 work? Is it too big?
Chase 360, Goblin Fireball, Protos 380, Trioblin 570, Trioblin 700, Chronos 700, Synergy N7, Protos Max V2 Leggero 800 EVO, DJI Inspire 1, Mavic Pro, Vortex 280, Mojo 280, Blade 200x, Jeti DS-14 MSH Brain2
RCHN #604
rchelipastor is offline        Reply With Quote Quick reply to this message
Old 01-10-2018, 05:01 PM   #335 (permalink)
Excited to be starting my 380 evo build soon. Should be here by the end of the week.
MSH Protos 380 Evo
Flight Style: Lower Headspeed Sport
FBL System: MSH Brain2 Mini
Transmitter: Spektrum DX9
Reciever: SPM4649T & 2 DSMX Satellites
Motor: Xnova 2820 - 890Kv
ESC: Hobbywing Platinum 60A V4
Governor: MSH
BEC: Hobbywing
Cyclic Servos: BK 3001
Tail Servo: BK 3005
Main Blades: Switch 383mm
Tail Blades: MSH 70mm
LiPos: Pulse 6s 1800mah
SAB Goblin Fireball 280, Goblin 380, Goblin 420, Goblin 500 Sport, Goblin 570
Oxy 2 FE, Oxy 3 Tareq, Oxy 4
MSH Protos 380 EVO
Spektrum iX12
wkderf is offline        Reply With Quote Quick reply to this message
Old 01-11-2018, 09:36 PM   #336 (permalink)
Just ordered this stuff, hoping to see it Saturday
Protos 380 Evo
Mini Brain 2
Xnova 2820 890
Kst X12 508 x3
Hobbywing 60a v4
Glacier 1800 6s 45c x3
Rotortech 386
Now I'm just needing a tail servo, I've seen plenty of mention of different servos in this thread but I'm having a hard time choosing between mini and micro. I'd like to keep it light if possible but I'm wondering if there are any balance issues with the micro. Also is anyone out there with a micro tail servo wishing they had gone with the mini?
I ready to get this thing and get it flying
Bigugly is offline        Reply With Quote Quick reply to this message
Old 01-12-2018, 12:02 AM   #337 (permalink)
Protos 380 Evo
Mini Brain 2
Xnova 2820 890
Kst X12 508 x3
Hobbywing 60a v4
Rotortech 386
I run the micro hv93i and it’s been flawless.
MSH USA
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 01-12-2018, 08:31 AM   #338 (permalink)
I also decided to go with a micro - not because of weight, but because of space. While a mini tail servo will fit, from the research ive done, its a tight fit and can take up room that could otherwise be used for wiring.
MSH Protos 380 EVO
Spektrum iX12
Old 01-12-2018, 09:16 AM   #339 (permalink)
I just replaced an Align DS535M mini with the HV93i micro - MUCH happier!
AndyO is offline        Reply With Quote Quick reply to this message
Old 01-12-2018, 12:55 PM   #340 (permalink)
Thanks for the replies. I'll go with the MKS micro
Human Verification
