Go Back   HeliFreak > R/C Helicopter Support > MSH Protos > Protos 380
Like Tree4Likes
Old 05-29-2016, 11:07 PM   #41 (permalink)
I had the Tareq in my Goblin 380's and that was such a nice motor man. It ran ice cold, it was powerful like insannnnne powerful, never bogged etc. My friend had the 2820 it was not as juicy but we were just doing stupid high speed passes and massive power loops etc. For proper flying 3d I agree its probably totally unnecessary but I think I will do it if it fits
jsbach#1 is offline        Reply With Quote Quick reply to this message
Old 05-30-2016, 07:01 AM   #42 (permalink)
There are the lighter motors which will do well overall
http://www.helidirect.com/helicopter...aft-b-3mm.html
and the scorpion 2520 motors.
Here are some good options for motors if you prefer to run around 900kv on 6s
Good all round flight times and great 3d performance performance
http://www.scorpionsystem.com/catalo...30/HK3014_900/
http://www.helidirect.com/quantum-ou...820-880kv.html
http://www.helidirect.com/kontronik-...ess-motor.html
The micro pyro is 14 poles so may not work well with all esc but good match with Kontronik or YGE esc
For super powerful set up you can grab one of these
http://www.helidirect.com/helicopter...oblin-380.html
http://www.helidirect.com/scorpion-h...oblin-380.html
There is also the KDE 500xf 925kv motor and Xnova 3215 - 930kv Tareq edition. Both these motors are crazy powerful and overkill for the Protos 380.
dl5973 is online now        Reply With Quote Quick reply to this message
Old 05-30-2016, 07:46 AM   #43 (permalink)
That Quantum motor has been discontinued.
Team Lynx Heli Field Rep
DX9 - Goblin 500 Sport, Mini Protos, Blade 180CFX
Jomaba4308 is offline        Reply With Quote Quick reply to this message
Old 05-30-2016, 07:47 AM   #44 (permalink)
What motor-shaft lenght does it needs?
tomp is offline        Reply With Quote Quick reply to this message
Old 05-30-2016, 08:37 AM   #45 (permalink)
Double post sorry
Old 05-30-2016, 09:27 AM   #46 (permalink)
For Speed Controller
You can choose anywhere from 50a for a light set up. All the way up to 80a max for any superpowerful motor and very high headspeeds.
90a YGE/YEP or 100a v3 Hobbywing is overkill and just adds unnecessary weight.
Hobbywing 60a v4 or Hobbywing 50a v3 esc is perfect all round esc that comes with a very good internal bec for HV servos if you want to run HV servos. They both weigh the same at around 50grams.
http://www.hobbywing.com/compare.php?goods[]=481&goods[]=424&
The hobbywing 80a v4 is not necessary unless you want to fly 3500+ rpm and run 13+ collective pitch which is waste It weighs 97 grams and is a bit too heavy.
Old 05-30-2016, 03:47 PM   #47 (permalink)
But is the HOBBYWING Platinum Pro 60A a good choice ? its seems it is part of a good percentage of all proposed setups ?
I run a 100AV3 in another model and I happy with it but ...
if you look around (I looked in the hw section ) , and it seems people are very pleased for the flying and how it comes down cool but still you see complaining about a few things with the HW V4 's.
- big tail kick when you run an external gov ( I don't want to run the buildin gov , brain gov FTW )
- noise on the buildin rpm which seems to mess up the signal (like with Neo), which ppl fix why swithing FBL or running an external HW sensor.
Did I miss anything ? I agree the 60A spec is nice with the proposed motor but still , I wonder if it would be a good choice.
zomaar is offline        Reply With Quote Quick reply to this message
Old 05-30-2016, 03:51 PM   #48 (permalink)
The Airetic
IMO, the HW60v4 is an excellent choice. It's plenty big for the application. As far as the issues you noted here, neither one of them is a large problem when using the Brain gov. Use the ESC in Heli-linear mode to have decent soft start. The rpm out from the ESC works just fine with Brain, no need for external sensors.
Free Agent....With standalone opinions.
KiloXray is offline        Reply With Quote Quick reply to this message
Old 05-30-2016, 04:58 PM   #49 (permalink)
Question.. It's it worth just striping my current mini protos for the electronics? Running mks95/I yge 60 xnova 2618 and a gryphon bec ..
Manyc is offline        Reply With Quote Quick reply to this message
Old 05-30-2016, 05:32 PM   #50 (permalink)
Yes those components would work great. Stock pinion is 16T 3.5mm hole.
MSH USA
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 05-30-2016, 06:03 PM   #51 (permalink)
So what would be an appropriate kv for the 16t pinion for a max head speed of 3k?
2slow2g is online now        Reply With Quote Quick reply to this message
Old 05-30-2016, 06:21 PM   #52 (permalink)
Thanks.. saves me buying all the new electronics.. and lets me keep her as a shelf queen... I assume Type A shaft.. also will it fit 385mm blades? looking at some Halo's
Old 05-30-2016, 06:38 PM   #53 (permalink)
Default setup
[QUOTE=KiloXray;6994917]IMO, the HW60v4 is an excellent choice. It's plenty big for the application. As far as the issues you noted here, neither one of them is a large problem when using the Brain gov. Use the ESC in Heli-linear mode to have decent soft start. The rpm out from the ESC works just fine with Brain, no need for external sensors.[/QUOT!]
100% agree
TEAM:
CYCLONE BLADES
matt blaisdell is offline        Reply With Quote Quick reply to this message
Old 05-30-2016, 07:36 PM   #54 (permalink)
You would want a 1350kv motor and the 14t if you want max head speed of 3000 gov.
Team MSH USA - Cyclone Blades
MSH Prtos 380 Brain 2
MSH Prtos Max V2 Brain
vtown nick is offline        Reply With Quote Quick reply to this message
Old 05-30-2016, 10:06 PM   #55 (permalink)
Well, After seeing that gorgeous picture Alex posted this morning. I sent it to the wife and she insists I should get that so... Im in
Heli ------------ Protos 380
FBL------------ MSH Brain 2
Motor---------- MSH/Scorpion 1300kv (maybe)
ESC ------------YGE 60
Servos ---------KST 215mg
Tail --------------MKS DS95I
Batteries ------ Pulse 1350 35c
RX -------------- Lemon Satalites
Blades----------ALZRC 380 blades
Im hoping I can pull everything from my MiniP
mattbeau is offline        Reply With Quote Quick reply to this message
Old 05-30-2016, 10:16 PM   #56 (permalink)
oh. what pinion are you running with the xnova 2820-890? 21t?
That's the motor I ordered (and lots of other people judging from this list)
Protos Max V2 (build), Synergy 516 (build) Logo 480xx (build), Gaui NX4 (build), Protos 380 (build), Oxy2 215 Sport (build)
ultrataco is offline        Reply With Quote Quick reply to this message
Old 05-30-2016, 10:58 PM   #57 (permalink)
After seeing that inverted auto by Alex, im sold.
Heli ------------ Protos 380 red
FBL------------ Vbar Neo
Motor---------- Xnova 2820-890
ESC ------------Hobbywing 60 v4
Tail -------------- kst 565x
Batteries ------ TP 1300mah or 2250mah
Blades--------- Halo 385
Dirtyburd is offline        Reply With Quote Quick reply to this message
Old 05-31-2016, 03:19 AM   #58 (permalink)
My Wife's job just got easier for my coming Birthday...
And I have all the parts lying around!
Motor---------- Xnova 2820-890 (will Put the Tareq in my G380)
Servos ---------QF-S5865 HV
Tail -------------- QF-S4546 HV
Batteries ------ Optipower 1800 50c
Blades--------- TBD. Options?
|Black Thunder 700| Black Nitro 700 (building) | Logo 550SX | SAB G380 | Oxy 3 |
V-Control
QF-Servo | Lynx/OXY Heli & FPV field rep
Theunisjr is offline        Reply With Quote Quick reply to this message
Old 05-31-2016, 08:28 AM   #59 (permalink)
Zeal, Switch, SAB, etc.....?
Sent from my SAMSUNG-SM-N910A using Tapatalk
MSH, Cyclone
Way2evl is offline        Reply With Quote Quick reply to this message
Old 06-01-2016, 08:22 AM   #60 (permalink)
Here's mine:
Heli ------------- Protos 380
FBL ------------ MSH Brain 2
Motor ---------- Xnova Tareq Edition 3215-930kV
ESC ------------ Hobbywing Platinum 80A v4
Servos --------- Turnigy S306G-HV
Tail -------------- MKS DS95
Batteries ------ Mix of existing 6S packs: Gens-Ace 1450mAh, Align 1450mAh, misc 1300 and 1200mAh. May pick up a couple of OptiPower 1800mAh packs.
RX -------------- Jeti REX6
Blades --------- Switch 383
Misc ------------ MSH Powerbus & Jeti MUI75 sensor (or JLog3 when available)
Backyard fun: Oxy 2 FE and Oxy 2 Sport with VX1p
At the field: Protos 380 (Brain) | Gaui X3 (360mm + 380mm) - VX1e
TX + Sims: Jeti DS14 and Realflight (Wireless)
And now a Lynx team rep :-D
myxiplx is online now        Reply With Quote Quick reply to this message
Human Verification
