Protos 380 setups - Page 4 - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > MSH Protos > Protos 380
Like Tree4Likes
Old 06-01-2016, 02:15 PM   #61 (permalink)
Default Blades
Found another option. RotorStar. The ones I've had before seem pretty good, though sometimes needing balancing.
Compass 6HVU, 550U, Chase 380, Graupner MZ-12
cycled is online now        Reply With Quote Quick reply to this message
Old 06-01-2016, 06:40 PM   #62 (permalink)
Do you think 1 Spektrum Sat or 2 for this bird???
DX9, OXY 3 (2) Stretched & Stock, Gaui X3, Protos 380, Fireball 280, Synergy 516 (maidened) all Ikon and Brain, Hobbywing
hshooman is offline        Reply With Quote Quick reply to this message
Old 06-01-2016, 06:57 PM   #63 (permalink)
The same as you run on your X3.
KDS Agile 5.5, Ikon, KST, KDE motor/Gaui X4ii, BK servos, Brain / Gaui X3, Ikon, KST, Scorpion 1580Kv
Frsky Taranis plus
PhoenixRC upgraded to wireless
Larryu is offline        Reply With Quote Quick reply to this message
Old 06-01-2016, 08:25 PM   #64 (permalink)
I'd run 2 if at all possible. Peace of mind is priceless.
Representing:
AMainhobbies, Mikado V-Team,
Jason Bell is offline        Reply With Quote Quick reply to this message
Old 06-01-2016, 08:35 PM   #65 (permalink)
Originally Posted by OnTheSnap View Post
As the guys mentioned, at 250g lighter it's just well past diminishing returns. I've spent time looking at the miniBrain2 governor log graphs and the 2820 890 is giving me bullet proof performance even with ham fisted tic tocs, and all heavy collective maneuvers. If you already have it, use it. But it's adding some weight and cost. Not a big deal since it's already a very light model.
What pinion are you running? What would reasonable max and min governed head speed be with your setup (assuming headroom for governor)?
Ivan
9sec240 is offline        Reply With Quote Quick reply to this message
Old 06-01-2016, 08:51 PM   #66 (permalink)
I'm running a 23T which is over geared a bit since I'm running high headspeeds during test. I run a yge 90 at the moment in it and run it down to 2400 headspeed and it has worked well. So right now I'm flying from 2400-3500.
MSH USA
Short replies are friendly replies.
OnTheSnap is online now        Reply With Quote Quick reply to this message
Old 06-02-2016, 01:05 AM   #67 (permalink)
I would always run 2, it's not expensive, and if you run one sat all you need is a bad cable and your model is going in.
Two satellites is a much more reliable option.
Backyard fun: Oxy 2 with VX1p | Trex 250 SE with VX1e
At the field: Protos 380 (Brain) | Gaui X3 (360mm + 380mm) - VX1e | Trex 600N VX1e
TX + Sims: Jeti DS14 and Realflight (Wireless)
And now a Lynx Team Pilot :-D
Old 06-02-2016, 04:08 AM   #68 (permalink)
is that 3500 a set HS or measured during triggered overspeeds ??
because if you run 3500 HS , I don't dear to think what the overspeeds are like ...
But I assume the brain 2 can log this , so What is the max registered overspeed HS you saw on your P380 ?
zomaar is online now        Reply With Quote Quick reply to this message
Old 06-02-2016, 04:50 AM   #69 (permalink)
Unless you run magnets and hall sensor on the head (not main gear), you can't measure overspeed RPM. With today's RPM sensor on the motor phase, you can only read motor speed which doesn't go up on overspeed. That is unless you run no OWB like my P500.
Old 06-02-2016, 05:45 AM   #70 (permalink)
lolz,
your absolutely right , since the owb disengages .... and rpm of the motor is measured on E helis.
I didn't think this through, because at the release of the MAX V2 OTS reported some measured overspeed RPM/ forces which made them change the preload washers to stronger ones , I wonder how they measured this.
Old 06-02-2016, 06:23 AM   #71 (permalink)
While you can't log/measure overspeed RPM with FBL, you can measure it with shutter-style optical RPM reader, or an audio-type reader.
Old 06-02-2016, 10:07 AM   #72 (permalink)
Anybody got any experience with the BK DS-3005 HV tail servo? I might go for that over the bigger, heavier DS-5005HV for the P380
MB
Blade Nano CPX x 3, mCPX-BL x 3,130X, 180CFX, Lynx 450X-L, T-Rex 250 DFC, T-Rex 450L, T-Rex 500, KDS Chase 360, Goblin 380, Goblin 500 Sport, Spartan Vortex, DX8
"More the Knowledge Lesser the Ego, Lesser the Knowledge More the Ego" Albert Einstein
Miracle Boy is online now        Reply With Quote Quick reply to this message
Old 06-02-2016, 10:13 AM   #73 (permalink)
lolz,
Audio is the easiest way pull from a video. The Protos 380 does amazing overspeeds like the max. I haven't measured them yet but probably in excess of 4200 rpm or more.
MSH USA
Old 06-02-2016, 10:17 AM   #74 (permalink)
MB
I ordered one (out for delivery now ) for my p380 but I've never used one. Hopefully it's good.
Protos Max V2 (build thread), Gaui NX4 (build thread), Logo 480xx (build thread), Protos 380 (build thread), Blade 230s Night, Oxy2 215 Sport (build thread)
ultrataco is offline        Reply With Quote Quick reply to this message
Old 06-02-2016, 10:53 AM   #75 (permalink)
MB
I have used this servo on 3 helicopters and I love it. Actually worked better for me than the popular 95i.
Synergy Field Representative & Rail Blades/#Team Scorpion/#Team BK Servos/#MSH Brain Flight Team/#Jeti Team Pilot/#Team Pulse/Team Canomod/AMain//
Greg Jackson 2017 Team USA F3N https://www.youtube.com/channel/UCci..._R4nja0RYeXykg
GJacksonF3N is offline        Reply With Quote Quick reply to this message
Old 06-02-2016, 12:28 PM   #76 (permalink)
Thanks Greg, that's good to know!
MB
Old 06-02-2016, 02:46 PM   #77 (permalink)
So for the xnova 2820-890 is there only one version shaft. They all say for gob 380
RCHN Citizen 790
-Protos maxv2 evo,xnova,Hw160, xpert, brain-Logo 600sxv2, hw130, mks scorpion,optipower,brainProtos -380 evo,Mks,xnova,HW,pulse,brain2. Jeti ds16
keither1984 is offline        Reply With Quote Quick reply to this message
Old 06-02-2016, 02:49 PM   #78 (permalink)
The Airetic
That's the one. Gotta remember, when they made that motor (and marketed it) there was only one 380 sized heli in town.
Better make room, there's a new guy!!!!
Free Agent....With standalone opinions.
KiloXray is offline        Reply With Quote Quick reply to this message
Old 06-02-2016, 02:53 PM   #79 (permalink)
Just ordered one from esprit. Already got my HW 60 sitting on the workbench. Servos, lipos, and of course the 380. I'll be good to go.
RCHN Citizen 790
Old 06-02-2016, 03:04 PM   #80 (permalink)
I'm going to perform a transplant procedure and take components from my G380 to the P380.
Heli -------------Protos 380 yellow
FBL-------------mini Brain2
Motor-----------Quantum 2820-880KV
ESC ------------Hobbywing 60 v4
Servos ---------KST 215MG V2
Tail --------------KST BLS505X
RX---------------2x Spektrum sats
Batteries ------ Pulse 1800 45c
Blades----------RJX 382mm (I've had good lucks with this brand)
Extras-----------Power bus, gorilla landing skids
dgunawan is offline        Reply With Quote Quick reply to this message
Human Verification
