Old 05-14-2009, 09:49 AM   #241 (permalink)
Is there anyway to tell if one of the my torque tube bearing rubbers has come off without beeing able to see it? AKA how will it feel?
jared_of_atlanta is offline        Reply With Quote Quick reply to this message
Old 05-18-2009, 04:16 PM   #242 (permalink)
So I just finished my build and I am going though the finless set-up of the head, and electronics. Per Bob's suggestions on setting up the swash mix so the washout block almost touches the head block the swash mix comes out to 38% is this right? All the links were pretty long when built per the manual so they need to be tightened to get the head right. Please keep in mind I went through the head at mid stick and all the linkage are straight ie washout arms seesaw arms and blade grip arms. Thanks in advance for any help.
Mrdeadair is offline        Reply With Quote Quick reply to this message
Old 05-30-2009, 07:29 PM   #243 (permalink)
Thanks Bob. Your videos are awsome.
This time i will watch you videos BEFORE building.
If it won't hover, Don't bother !
carlos is offline        Reply With Quote Quick reply to this message
Old 07-28-2009, 04:09 PM   #244 (permalink)
What sort of pitch are you getting mrdeadair, i seem to be having the same sort of issue, everything set up perfect as per bobs instructions but in swash mix my pitch setting is at max 40% and at this i only get + and - about 8 degres with 0 pitch at centre stick :-(
dr_cheeks is offline        Reply With Quote Quick reply to this message
Old 08-20-2009, 08:02 AM   #245 (permalink)
Isn't there a way to access/download all files at once - like a ftp server or package?
vinterbo is offline        Reply With Quote Quick reply to this message
Old 08-20-2009, 08:30 AM   #246 (permalink)
Someone needs to make a firefox extension that downloads the video file whenever you click on one of the video download links.
Old 09-27-2009, 10:37 AM   #247 (permalink)
Will you make the tuning video? I'm probably not the only one have a hard time tuning my 90-engine so some aid would be greatly appreciated. Thank you!
Align TRex 600N Sport / 700N LE
Hirobo Lepton EX / SDX
Powered by BeastX (all of them)
Slayaah is offline        Reply With Quote Quick reply to this message
Old 10-03-2009, 11:47 PM   #248 (permalink)
Default 700 videos
thanks bob for the great info
watso is offline        Reply With Quote Quick reply to this message
Old 10-12-2009, 12:47 PM   #249 (permalink)
Have I missed the tuning and carb smart tuning vid? It isnt linked on the front page.
pathfindercod is offline        Reply With Quote Quick reply to this message
Old 10-15-2009, 08:32 PM   #250 (permalink)
hey can someone tell me the differance between this t-rex 700 kit model KX018003A and KX018003 with out the A cause they look to be the same package KX018003A is the ones i see if i order from china and in the states i don't see ne1 selling the KX018003 one
burton8012 is offline        Reply With Quote Quick reply to this message
Old 11-07-2009, 11:12 AM   #251 (permalink)
Thanks for your videos bob! Your videos were extremely helpful when I built my electrict 600 some time ago.
Now I have ordered a 700LE! Do you (or anyone else) know if there are significant differences from the standard 700 when it comes to building? Is there anything particular I should be aware of when watching the 700 build videos?
Jotto is offline        Reply With Quote Quick reply to this message
Old 11-07-2009, 01:50 PM   #252 (permalink)
Afaik there are no differences apart from the aluminium parts have no black coating, which looks pretty cool btw .
And the alu tailgrips are the upgraded alu parts instead of the standard plastic grips.
So Bob's very helpfull videos are still spot-on IMO.
Great Heli btw, you'll love it
One day I got stung, and now I love rotor sounds...Team RIGIDHELI.COM
T-Rex 700N Pro, Compass 7HV ult., MSH PRTOS
EricW is offline        Reply With Quote Quick reply to this message
Old 11-20-2009, 01:37 PM   #253 (permalink)
Default T Rex 700 Nitro conversion
Sure would like to see a video using KDE parts and an electric conversion of the Trex700.
flyrtm is offline        Reply With Quote Quick reply to this message
Old 11-24-2009, 01:08 PM   #254 (permalink)
Thanks Bob for yet another great video! have used your videos to build the 500,600 and now this one. Maybe you can clear up a question I have - included in the 700N was the G600 governer and the 2in1 regulator/onboard glow but I am using the DX7 with the AR7100R receiver and running the OS 91-HZ-PS motor. Now this receiver already has voltage regulation but no onboard glow and the receiver also has a governer built in but the sensor does not fit the motor properly because of the pump.
The question is should I maybe change my receiver to maybe a AR7000 and use all the align equipment or do away with the align and use the AR7100R capabilities????
GrantSA is offline        Reply With Quote Quick reply to this message
Old 11-30-2009, 12:23 PM   #255 (permalink)
Grant,
You sure the spektrum backplate sensor doesn't fit this motor? Can you install it between the pump mounting plate and the backplate? Washers would be used as shims under the other 2 arms of the pump mounting plate to keep it level.
I just bought this motor for my 700 (building) and hope i can use the backplate sensor.
WWBD?
chuckk is offline        Reply With Quote Quick reply to this message
Old 11-30-2009, 12:31 PM   #256 (permalink)
Team Taco VP
Yes it will fit under and around the pump. Go into the T700 forum (I think it was also posted in the Aurora forum too) as there were many posts showing pictures on how to do it.
Bob
Old 12-13-2009, 10:34 AM   #257 (permalink)
Default Thanks Bob!!
I must say your videos helped me allot through my Trex 500,600E & 700(E-coverted) builds!!
I did wanted to ask one thing: is there a seup video to the GY611 Gyro?? I can't seem to find any..
Thanks again
Ron
rontossm is offline        Reply With Quote Quick reply to this message
Old 12-13-2009, 12:30 PM   #258 (permalink)
Team Taco VP
Yes I did one for the Trex 600 Electric. Look in my forum at the post Heli Skills and Setup. You will see it listed under gyros.
Bob
Old 12-15-2009, 10:32 PM   #259 (permalink)
COOL BOb,
zone is offline        Reply With Quote Quick reply to this message
Old 01-26-2010, 04:39 PM   #260 (permalink)
I have the magnets (governor sensors) the destructions do not have how to secure the magnets to the cluch bell, and you did not say how to secure the magnets in your video.
Help Bob!
Grumpy D is offline        Reply With Quote Quick reply to this message
