Old 05-27-2008, 06:05 PM   #101 (permalink)
Nice video's Finless, can't wait to see the finished bird!
DarkTherapy is offline        Reply With Quote Quick reply to this message
Old 05-27-2008, 06:06 PM   #102 (permalink)
Hay thanks for the Bakerfield vids sweet!
bladebraker is offline        Reply With Quote Quick reply to this message
Old 05-27-2008, 07:21 PM   #103 (permalink)
Team Taco VP
Step 6 posted! Enjoy!
Bob
Old 05-28-2008, 08:49 PM   #104 (permalink)
Very exite!!!!
Trex 450SE V2, Trex 500 CF, Trex 600 Nitro Pro
DX7, AR7000s, JR770s
2.4 is for people who only listen to AM radio (like me)
mattkreps is offline        Reply With Quote Quick reply to this message
Old 05-28-2008, 09:54 PM   #105 (permalink)
Team Taco VP
Step 7 posted!
Enjoy,
Bob
Old 05-28-2008, 09:58 PM   #106 (permalink)
Default #7
Link does not work. Thanks for all the great information.
wmbige is offline        Reply With Quote Quick reply to this message
Old 05-28-2008, 10:13 PM   #107 (permalink)
Team Taco VP
Ooops sorry... All fixed!
Bob
Old 05-29-2008, 03:39 AM   #108 (permalink)
Talking
Wooooow.. Beautiful bird Bob!!! It seems Align did it again!! Can't wait to see how it flies!
mc.mark is offline        Reply With Quote Quick reply to this message
Old 05-29-2008, 03:52 AM   #109 (permalink)
Hi, Bob. You must have the greatest job ever....or is it a task? Anyway great work.
I suppose the flat spots on the clutch hub is for holding it with a big wrench while thightening and loosening the nut to the crankshaft, instead of the cloth....
Roadrune is offline        Reply With Quote Quick reply to this message
Old 05-29-2008, 09:40 PM   #110 (permalink)
Team Taco VP
Step 8 posted!
Enjoy,
Bob
Old 05-29-2008, 09:46 PM   #111 (permalink)
Thanks again, Bob. you da bestest
If, at first, you don't succeed, then skydiving is probably a bad idea for you.
george0079 is offline        Reply With Quote Quick reply to this message
Old 05-29-2008, 11:14 PM   #112 (permalink)
i have a question..... does it matter where the fuel clunk goes? i noticed that you have it on the inside of the frames, but from another vid it's on the outside of the frames. is this just a preference or does the manual show it on the inside.
just wondering
matrix1171 is offline        Reply With Quote Quick reply to this message
Old 05-29-2008, 11:20 PM   #113 (permalink)
Team Taco VP
???? I have no vid that shows the clunk line on the outside of the frames? I am totally unclear what your talking about? MAKE SURE your not looking at the tank plug on the outside of the frame! That is a tank plug rubber NOT the fuel pickup system!
Bob
Old 05-29-2008, 11:24 PM   #114 (permalink)
Default fuel lines
I sent Bob a tip about fuel lines in the tank, and he asked me to post it here. This tip was given to me by my buddy Russ McCutcheon of Vancouver Wash. If you look at fuel line it has a natural roll to it. This is because it has be rolled around a spool, and it wants to stay in that shape. The trick is install the fuel line so the natural roll points to the top of the tank. The fuel line will move easier in the direction of the natural roll. When flying upright gravity will pull the clunk down into the fuel. The natural roll to the fuel line will help the line move to the top of the tank when inverted. It makes a big difference when doing long inverted manuvers.
Try it, you will see how easy the line falls to the top of the tank, and the corners where the fuel is hidding.
Bob asked about after the line sits in fuel, will it still want to hold the rolled shape. The answer is yes. I have pulled out old line, set it on the table and it still held the the shape. It is going to be softer, but it still has some rolled shape to it.
Like I told Bob. I usally have to fish it out of the tank after it falls apart anyway.
Kevin T
KevinT is offline        Reply With Quote Quick reply to this message
Old 05-29-2008, 11:32 PM   #115 (permalink)
Team Taco VP
Thanks Kevin! I will check this out next time I have a chance but it sounds like totally sound advise! Thanks for sharing it......
Bob
Old 05-30-2008, 08:01 AM   #116 (permalink)
https://www.helifreak.com/showthread.php?t=70405
the fuel pick up system that goes from the tank to the inlet of the carb not inside the tank
maybe im seeing things but here is the vid i think i saw it in
Old 05-30-2008, 09:01 AM   #117 (permalink)
It was moved to the centre of the tank because it didn't reach all corners of the tank when mounted at the side.
The last thing you want is poor fuel delivery! So it has to be mounted in the middle.
toaster12 is offline        Reply With Quote Quick reply to this message
Old 05-30-2008, 09:56 AM   #118 (permalink)
ok, i was just wondering
Old 05-30-2008, 09:58 AM   #119 (permalink)
Great work Bob,
That rubber gromit/nipple on my Raptor was alot easier to put on the tank than on my T-rex 600N, now having to do that between the motor and tank it's not going to be fun.
It would be nice that the production would be different, maybe a 45 degrees shape on the tank, like on the Aurora, or if it would work on a 45 degrees on the front bottom part of the tank, but that would be more work, the frame would have to be designed for that.
I think that it will be hard to put the rubber/nipple when it has to be done at the field.
Nelson
nelson j is offline        Reply With Quote Quick reply to this message
Old 05-30-2008, 10:22 AM   #120 (permalink)
I think it's much easier to first mount the grommet, then the nipple, that just needs to be pushed in to a stop, instead of getting it correct all the way round. (bad english, sorry)
