Go Back   HeliFreak > HeliFreak.com Rules, Support and Testing > Other Websites > RC Heli Nation Podcast - Listeners Corner
RC Heli Nation Podcast - Listeners Corner RC Heli Nation Podcast - Listeners Corner for Suggestions and Announcements from RCHN
Old 06-15-2016, 03:03 AM   #1 (permalink)
Default power supplies
Time for me to think about building a new charging setup. My 2 old Dell serial PS's don't cut it any more.
What is the best power supply for the $ out there nowadays? is it still the HP DSP-1200 for its size and close to 1000W output, or there's something better/newer/smaller?
I'll need 24-36v so I'm thinking about floating and serializing 2-3 of whatever it is.
I am a Heli-Coholic! Citizen #207
PRTOS Max v2 PRTOS 380 Speed Goblin 380 Blade 180CFX
MKS KDE MSH Brain
Tomy. is offline        Reply With Quote Quick reply to this message
Old 06-15-2016, 06:30 AM   #2 (permalink)
I am need too. One of my DP-1200's crapped out. I can't seem to find any that will ship to PR.
Scorpion Power Systems
Michaelinpr is offline        Reply With Quote Quick reply to this message
Old 06-15-2016, 07:58 AM   #3 (permalink)
Message DSW He is in Florida, shipping should not be too bad to PR.
Good luck!
-Markus
*LINKS*
* G700c BRAIN2 * T-rex 500 *308DUO *450x #429
Relisys190 is offline        Reply With Quote Quick reply to this message
Old 06-15-2016, 09:44 AM   #4 (permalink)
Thanks. That is an option but I like to make them myself. I used to sell them too.
Old 06-16-2016, 01:05 AM   #5 (permalink)
Thanks Mike for hijacking my post
Seriously, you're also looking for them, still those DSP-1200 are the real thing?
MKS KDE MSH Brain
Old 06-16-2016, 04:11 AM   #6 (permalink)
I think they are awesome. Super low profile. High watts. Decent price. I have not seen anything else pop up that would seem better.
Old 06-16-2016, 06:41 AM   #7 (permalink)
I was thinking about grabbing some of these myself. I'm stringing 750's together in series myself. Still don't know if I need 1200 though. It's strange I have the 750's putting out 25v at 60amps which doesn't make sense to me I would think two 750's in series are 750 watts not 1500 watts. But I guess it may be 1500 or I'm way overdriving my psu's
__________
Goblin 380, 500, 570, Mikado 690SX, 480Xx(Stretched 500) , Protos Mini, Max V2 , Oxy 3, Vbar Control/Neo Vlink (Citizen 758)YouTubeProgress:http://tinyurl.com/oliver1071
oliver1071 is offline        Reply With Quote Quick reply to this message
Old 06-16-2016, 07:18 AM   #8 (permalink)
think of it this way: one gives 12.5V * 60A = 750W, two in series give (2*12.5V) * 60A = 1500W. if you put them in parallell instead, you'd get 12.5V * (2*60A) = 1500W.
togi is offline        Reply With Quote Quick reply to this message
Old 06-16-2016, 07:52 AM   #9 (permalink)
Ok so it does add the wattage together. So really 1200's are overkill since a 15amp 110 outlet can only support around 1600 watts anyway without tripping the circuit.
I guess it depends though I think my one generator has a 30 amp 120v twist lock so that should be cool hmm time for an upgrade.
__________
Old 06-16-2016, 12:22 PM   #10 (permalink)
It sounds like those 1200's are the way to go. I'm not sure I'll use the full 2000W+ output, but the small size and quiet running will be awesome, I can build a much smaller case now.
BTW I'm still running the Hyperion 720 super duo v3 that I think is the absolute underdog of chargers, with the latest firmware it does everything and more on 2 channels than the new chargers do (ok no bumping) and it has a great PC software for programming, control, charge graphing and battery tracking so what else can I wish for?
MKS KDE MSH Brain
Old 06-16-2016, 01:14 PM   #11 (permalink)
Keep in mind as you're doing your calculations that the DC output wattage does not equal the AC input wattage. There are significant power losses in the conversion and regulation, depending on the power supply most do something around 85% efficiency. So achieving 1500W output would actually require more like 1800W input.
On a single 15A circuit (110VAC) you're looking at roughly 1650W, or about 1400W DC output (if there's nothing else on the circuit.) However, that doesn't mean two DSP-1200s is overkill. It's easier on the supplies if you're not running them at max rated capability; they'll generate less heat and last longer. IOW, some margin is desirable when determining how to power a high output charger.
Team MikadoUSA
REVOLECTRIX Ambassador
hemp is offline        Reply With Quote Quick reply to this message
Old 06-16-2016, 02:37 PM   #12 (permalink)
The DPS 1200's are 900watt each. 1200 is just the model.
Old 06-16-2016, 02:54 PM   #13 (permalink)
Max rating, yes. Also used supplies are by definition, not new. They may not be able to keep up with their spec rating, so I wouldn't push them anywhere near 900W if you want them to survive long.
Team MikadoUSA
Old 06-16-2016, 03:02 PM   #14 (permalink)
Of course. I just got the impression some people thought they were rated at 1200w because of the name.
Old 06-16-2016, 03:03 PM   #15 (permalink)
Yeah I thought they were 1200's.
__________
Old 06-16-2016, 03:32 PM   #16 (permalink)
Regardless of the DPS 1200 wattage, the size is so convenient. They are flat and short. Leaves a lot of room in the charging case for other options.
Old 06-16-2016, 03:57 PM   #17 (permalink)
I prefer the Meanwell, even smaller. But there's definitely a price difference!
Team MikadoUSA
Old 06-16-2016, 05:01 PM   #18 (permalink)
I would love a meanwell but I can't stomach the price. But..........if I had bought a decent size meanwell 5 years ago it probably would have paidfor itself. I bet I have gone through at least $250 in ebay used psu's.
Old 06-16-2016, 05:14 PM   #19 (permalink)
Yeah that's why I use the delta 750's and their super cheap. and no capacitor needed you jump the contacts and get variable fan speed based on temp too unlike Dells I've done which are a single speed.
http://www.ebay.com/itm/361578727515...%3AMEBIDX%3AIT
__________
Old 06-17-2016, 12:12 PM   #20 (permalink)
Can you measure the size of these? I can't find the measures anywhere on the web. Amazon says that these weight 5lbs that's probably total bogus though. If you know their weight please let me know. Thanks!
MKS KDE MSH Brain
