Go Back   HeliFreak > R/C Helicopter Support > Mikado Logo Helicopters > Mikado Logo 700 Xxtreme
Mikado Logo 700 Xxtreme Mikado Logo 700 Xxtreme Helicopters Discussion
Old 07-05-2016, 01:02 AM   #1 (permalink)
Default New Logo 700 Setups
I want to run a 14S setup as i only have 7S packs.
I plan on running the Xxtreme main gear ,hub/oneway with an 8mm motor shaft and a 17T pinion.
(lower bearing support for an 8mm motor shaft for the new 700 will be available soon)
headspeeds 1850, 2050 and 2150
VTX 717's mains
RT 105 tails
Kosmik 200
Pyro 800 -48 comp long shaft which is 55mm or Scorpion 4530 -500
BLS172 cyclic's
BLS 276 tail
NEO with Pro
TP Magna 7S 4400's
Fasster is offline        Reply With Quote Quick reply to this message
Old 07-05-2016, 07:06 AM   #2 (permalink)
I was wondering the same thing about the motor. I am also running 14S packs but don't want to use the old gear.
What would be a suitable motor than with around 450KV. Shouldn't the Scorpion 4530-450 fit
Would like to know if that is possible.
MrEmail is offline        Reply With Quote Quick reply to this message
Old 07-06-2016, 03:06 AM   #3 (permalink)
Sorry to go off the subject but is the new 700 available now? And where do I purchase?!?
Revolectrix Ambassador
Revolectrix.com 10% Discount All Products Code
LEESS17
Lee2782 is offline        Reply With Quote Quick reply to this message
Old 07-06-2016, 07:23 AM   #4 (permalink)
Preorder is up at mikadousa
Specter 700 x 2--Diabolo UL--Compass 6hvu--Logo 600--oxy5+, oxy5, Oxy3, oxy2, SAB Mini Comet
Cajun Aircraft
B.Ewing is offline        Reply With Quote Quick reply to this message
Old 07-06-2016, 04:37 PM   #5 (permalink)
http://shop.mikado-heli.de/LOGO-Heli...&c=8147&p=8147
Old 08-11-2016, 06:36 PM   #6 (permalink)
Let's see what setup you have for the 700...
Kit : 697/717
Esc:
Motor: motor/pinion teeth count
Headspeed:
Servos: cyclic/tail
Fbl:
Just curious, just want to make sure of whats ahead of my winter build.
Thanks.
TREX 700XN 👍🏼 / TREX600n FL HEAD\ Logo 550sx 2017\XL POWER SPECTER 700\TREX 470\Vbar NEO/VBAR CONTROL👌🏼😎Citizen 789😎 DX6I RF 7.5 ( BLADE 130s oh yeah!!) ()
doubletap is offline        Reply With Quote Quick reply to this message
Old 08-12-2016, 10:54 AM   #7 (permalink)
Kit : 697
Esc: HW130 V4 HV BEC
Motor: XTS 4525-530/13 tooth pinion
Headspeed:1800,1900,2000
Servos: BK 7002/BK 7006
FBI: VBAR NEO with governor
I Have everything but kit and motor. I'm trying to keep this heli light. Looking forward to my first logo!
GAUI R5 V2,Logo 700, GLOGO690, Gaui X5 Formula Stretch, all VBAR
VControl, DX9, DX7s
Accurc and RealFlight 8
C #773
Heli$ is offline        Reply With Quote Quick reply to this message
Old 08-12-2016, 06:08 PM   #8 (permalink)
Originally Posted by Heli$ View Post
Kit : 697
Winner! Keep it coming...
Old 08-13-2016, 06:08 AM   #9 (permalink)
Default 700 setup
Kit : 717vtx
Esc: kosmik 200
Motor: motor/pinion 4525/520 ultimate 13tooth
Headspeed: 1950/2050
Servos: cyclic/tail MKS X8 hbl880/850
Fbl: vbar neo vlink
Battery: Optipower 5000 50c
Awaiting kit an pinion
Raving jim is offline        Reply With Quote Quick reply to this message
Old 08-14-2016, 09:38 AM   #10 (permalink)
It would bolt in but the shaft is not long enough to meet the counter bearing, and I suspect you will run into blowing the main gear on 14s with no counter bearing support.
Representing:
AMain Hobbies, XNova Motors
Jason Bell is offline        Reply With Quote Quick reply to this message
Old 08-14-2016, 12:20 PM   #11 (permalink)
Kit with 697mm.
Motor: Scorpion HK 4525-520
Pinion: 14T
ESC: Kosmik 160
Servos: MKS HBL960 / HBL990
Gyro: Mini Vbar with Pro
I have everything but the motor kit and pinion.
Also need a backup guard.
Logo 700 | Logo 480 | Blade MCPX BL
Emusp is offline        Reply With Quote Quick reply to this message
Old 08-15-2016, 01:30 AM   #12 (permalink)
Scorpion has the Logo 700 shaft for the 4530:
http://www.scorpionsystem.com/catalo...K_4530_6mm_55/
3Dmuse is offline        Reply With Quote Quick reply to this message
Old 08-15-2016, 02:40 AM   #13 (permalink)
Originally Posted by Emusp View Post
Kit with 697mm.
Pinion: 14T
ESC: Kosmik 160
Regarding the backup guard, i will use the Scorpion one.
- Michalis |OXY Heli|XNova Motors|
...let the flying be second nature!
acidla is offline        Reply With Quote Quick reply to this message
Old 08-15-2016, 03:35 AM   #14 (permalink)
I also use the Scorpion one on my 700xx. I like having a switch so I can test controls are working without powering up the ESC. Many clubs and events (for good reason) do not allow powering up in the pits area. For my new 700 I'm thinking of just getting a 2s LiPo and running it through a switch like this
http://www.skyrc.com/index.php?route...product_id=168
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl
mahbouni is offline        Reply With Quote Quick reply to this message
Old 08-15-2016, 04:10 AM   #15 (permalink)
I am little afraid of electronic switches.
This one i believe is one of the best that you can find.
https://www.wr-store.com/product_inf...4r3nticjtuls50
Old 08-15-2016, 04:47 AM   #16 (permalink)
It's only a backup though. It just has to work for 10 seconds if at all
Old 08-15-2016, 05:16 AM   #17 (permalink)
Then its safe to use
Old 08-15-2016, 06:24 AM   #18 (permalink)
Think I will go with the Optipower ultraguard.
Old 08-22-2016, 11:46 PM   #19 (permalink)
If you're going 14S go with the 717mm mains, makes no sense going under 700mm IMO anyhow...
Mikado Heli
Scorpion Motors
Western Robotics RC,
Youth Generation Electronics
Old 08-23-2016, 07:05 AM   #20 (permalink)
Except when you want to build a smack monster, then I'd certainly do 697
Johnny31297 is online now        Reply With Quote Quick reply to this message
