Go Back   HeliFreak > R/C Helicopter Support > MSH Protos > Protos 380
Like Tree2Likes
Old 07-24-2016, 05:18 PM   #41 (permalink)
Originally Posted by myxiplx View Post
Yup, bagged up the motor and filed a flat spot where it needed to be.
I missed a trick though, I should have filed it opposite to the other flat spot on the motor. It's a minor thing, but would have balanced the motor shaft a little better.
The moment of inertia that close to the center of rotation is essentially zero.
Unless you grind off half the shaft, you will not have a balance issue
Old 07-24-2016, 09:18 PM   #42 (permalink)
Thanks for the replies. Already filed enough for the grub screw to hold. Should work fine.
bbrc77 is offline        Reply With Quote Quick reply to this message
Old 01-18-2017, 04:26 PM   #43 (permalink)
Default Jesus bolt tightness
How tight should the Jesus bolt be in the head block? Should I just snug it up, or should I tighten it enough to clamp the head block down on the main shaft so there is no play in the head block on the main shaft?
LyleT is offline        Reply With Quote Quick reply to this message
Old 01-18-2017, 07:38 PM   #44 (permalink)
Snug it up but don't over do it. The head design will clamp down on the main shaft once you get a little torque on it.
Team MSH USA - Cyclone Blades
MSH Prôtos 380 Brain 2
MSH Prôtos Max V2 Brain
vtown nick is offline        Reply With Quote Quick reply to this message
Old 01-18-2017, 07:50 PM   #45 (permalink)
The head block bolt has been the only bolt I have had to tighten . Very infrequent, but I had 2 a couple times
---DIABOLO 700 UL---
---MSH PROTOS EVO LEGGERO 700---
---MIKADO LOGO 550 2017---
---MSH PROTOS EVO 380---
JANtoolMAN is offline        Reply With Quote Quick reply to this message
Old 01-19-2017, 08:20 AM   #46 (permalink)
This happened to once as well. I decided to just use loctite on the nut instead of relying on the nyloc.
Scorpion Power Systems
Michaelinpr is offline        Reply With Quote Quick reply to this message
Old 01-20-2017, 01:26 PM   #47 (permalink)
Can I assume no idler pulley when using 21t pinion with 890 Nova?
(since it hits.)
Steve
smittylube is offline        Reply With Quote Quick reply to this message
Old 01-20-2017, 01:28 PM   #48 (permalink)
Ok I see it on page 7 ^^^
Steve
Old 01-20-2017, 04:23 PM   #49 (permalink)
wow it goes together quick!
Steve
Old 01-24-2017, 10:26 PM   #50 (permalink)
Super quiet no blades 3420 rpm.
NICe.
Steve
Old 01-24-2017, 10:31 PM   #51 (permalink)
NICe.
3420?
3000 hard 3D, 3200 omg 3D. It's super light with a high tail ratio. No need for HFS*** headspeed
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 01-24-2017, 10:39 PM   #52 (permalink)
Lmao
slogoat is offline        Reply With Quote Quick reply to this message
Old 01-24-2017, 10:39 PM   #53 (permalink)
That was what the rpm read when setting the end points for the gov.
Try it.- but I suggest no blades like I did.
It looks like at 3000 there is still a bit of headroom!
Set mine @ 2600/2800/3000.
That should be good I suspect.
Steve
Old 01-24-2017, 10:40 PM   #54 (permalink)
I think you will enjoy it at 2400 as well
Old 01-24-2017, 10:49 PM   #55 (permalink)
Pretty close to maiden. Hopefully tomorrow it will happen.
Sad I purchased this so long ago and have not been able to get it together till now.
Steve
Old 01-24-2017, 10:50 PM   #56 (permalink)
3420?
LOL, with the default pinion and my Scorpion motor, at full throttle (no blades) I get just over 4000 RPM.
I'll probably need to look at seeing if I can get a smaller motor shaft so I can go down a size or two on the pinion...
Old 01-24-2017, 10:54 PM   #57 (permalink)
And get a minute more flight time? I like that idea.!
Steve
Old 01-25-2017, 05:05 PM   #58 (permalink)
I mob around at 2400 a lot. Tail hold is great and you can hardly even hear it, just my zeals flapping
Old 01-25-2017, 07:37 PM   #59 (permalink)
+1 for 2400. That is my lowest head speed and I spend a lot of time there. Tail doesn't even blow out. Flys a little slow but takes everything I throw at it.
Old 01-25-2017, 08:24 PM   #60 (permalink)
What motor kV do you have?
I run a 22T and run 2400 - 3200 Brain2 Gov'd. Has been a perfect wide headspeed setup. Xnova 2820-890kV
