Go Back   HeliFreak > R/C Helicopter Support > MSH Protos > Protos 380
Like Tree2Likes
Old 07-15-2016, 09:23 AM   #21 (permalink)
Watch your battery- these are the Pulse 1800mah, with Velcro and straps set on its side you can read the writing when looking from the side of the heli. The end of the battery was set level with the top of the tray. Slid it down so the bottom of the pack was even with the bottom of the tray and it se am not to rub anymore.
Can now be found on the links.
Doom Buggy is offline        Reply With Quote Quick reply to this message
Old 07-15-2016, 09:37 AM   #22 (permalink)
Originally Posted by rasheem View Post
Quick tip #2
Problem: You have max2, protos500 and swash leveler for 500... But you don't have a swash leveler for protos 380...
Solution: Swash geometries of P380 and P500 are same... Only inner diameters are different, that is 6mm for P380 and 8mm for P500...
So you need an adapter (6mm-8mm), that's way you can use swash leveler of P500 when it's needed. And that adapter is Protos Max v2's motor shaft adapter (if you use 8mm shaft on the Max, that adapter is not needed)
And for the people who fly a Mini Protos, the swash leveler is a direct fit
Old 07-15-2016, 10:20 AM   #23 (permalink)
Monokote DayGlo Red trim sheets a perfect match.
Old 07-19-2016, 03:30 PM   #24 (permalink)
Did you spot the mounting recess for the Bluetooth adapter?
Now: OXY2 || OXY2 || OXY4 ||
Then: Lots
TEAM LYNX/OXY
MinskUK is offline        Reply With Quote Quick reply to this message
Old 07-21-2016, 03:11 AM   #25 (permalink)
Can you post a pic?
- Michalis - OXY Heli -
...let the flying be second nature!
acidla is offline        Reply With Quote Quick reply to this message
Old 07-21-2016, 08:18 AM   #26 (permalink)
Originally Posted by acidla View Post
Can you post a pic?
Rub
Old 07-21-2016, 08:21 AM   #27 (permalink)
Mine touches the canopy too
But the cg is more important to me than the black paint getting scuffed from the inside of the canopy
MSH USA - MSH BRAIN - HOBBYWING - XNOVA - XPERT - PULSE
Colin Broughton is offline        Reply With Quote Quick reply to this message
Old 07-21-2016, 08:27 AM   #28 (permalink)
My luck......id rub thru to the battery!
Old 07-21-2016, 10:50 AM   #29 (permalink)
lol, it's not that bad. It's just resting against the canopy. The batteries coke with some pretty heavy duty heatshrink
Old 07-23-2016, 12:03 PM   #30 (permalink)
When shortening the pushrod for a micro tail servo, do a dry run first with the components and measure the amount you need to trim.
I found I actually needed it 6.5mm shorter, and since the ball links are screwed very deeply into the ends, it's best to err on the side of cutting the pushrod shorter.
I took 10mm off mine, giving me ~1.5mm of room to lengthen each pushrod. That should be enough room to set the tail mechanically for flybarless units that want the blades at zero pitch with the servo at 90°, and also for units that want a little offset on the blades.
Backyard fun: Oxy 2 FE and Oxy 2 Sport with VX1p
At the field: Protos 380 (Brain) | Gaui X3 (360mm + 380mm) - VX1e
TX + Sims: Jeti DS14 and Realflight (Wireless)
And now a Lynx team rep :-D
Old 07-23-2016, 12:14 PM   #31 (permalink)
that's what I posted in another thread here...but you said it way better than I did. that works for any setup also...thank you
tonys-heli is online now        Reply With Quote Quick reply to this message
Old 07-23-2016, 01:53 PM   #32 (permalink)
Also, run the battery straps in place before you strap down the ESC!!
I just learnt that one the hard way lol.
Old 07-23-2016, 01:58 PM   #33 (permalink)
When strapping the ESC down with the O ring, you're going to want to use a driver to hold it stretched over but open, so you have a bit of slack.
Old 07-23-2016, 03:15 PM   #34 (permalink)
Always use the online (up to date) version of the manual, if it hasn't been stated yet
Old 07-23-2016, 06:51 PM   #35 (permalink)
Hello everyone,
I thought I read someone say something about this but I couldnt find it.
I switched to a micro tail servo and I find the servo arm hitting the servo mount on the nut. I think I could grind a bit off the nut? What do you say?
JANtoolMAN is offline        Reply With Quote Quick reply to this message
Old 07-23-2016, 07:05 PM   #36 (permalink)
That's what I did, before I realized I needed to use the updated manual (see above post). There's a standard M2 nut supplied for this very reason (page 54 of the proper manual)
Every morning, I get up and look through the 'Forbes' list of the richest people in America. If I'm not there, I go to work.
jbobb1 is online now        Reply With Quote Quick reply to this message
Old 07-23-2016, 08:17 PM   #37 (permalink)
Duh really, sorry , didnt even think to look in the manual. Thats not funny
Old 07-24-2016, 08:23 AM   #38 (permalink)
Old 07-25-2016, 08:54 AM   #39 (permalink)
Quick tip #3 (from Rasheem)
These are tail blades... There's an orange blade for Protos500 at the left... And Protos380 stock tail blade which comes with my P380 Evo Red kit...
And yes, they are almost same... The only problem is root... 2.6mm for P380 and 4mm for P500...
68mm from bolt hole to tip... Same profile, same everything...
There is only a little bit grinding work. If you dont mind, give it a try
http://www.fast-lad.co.uk/store/prod...ducts_id=10226
Edit: I weigh them... 5.2g for p380 tail blade pair... 5.4g for p500 tail blade pair...
Rasim Ozturk
[Prôtos Max V2][Prôtos 380 Evo][OXY3 GL][Vbar Neo][Vbar Control]
rasheem is offline        Reply With Quote Quick reply to this message
Old 07-26-2016, 07:11 AM   #40 (permalink)
For HobbyWing users: If you choose to run the battery side esc wires through the esc cage- run a programming extension when you mount the esc- saves a good bit of time.
Somebody explain this one. I haven't looked at my kit yet maybe I would understand then.
Lynx Innovation Team Pilot
Protos Max v2 Brain, Goblin 500 Ikon, Oxy 3 Neuron, Oxy 3 Qube Neuron, Gaui Nx4ii Brain, 180 lynx ubrain,
Soon to have Protos 380
benddg is offline        Reply With Quote Quick reply to this message
Human Verification
