Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 230S
Blade 230S Blade 230S Helicopters Information and Help
Old 07-12-2016, 05:09 AM   #1 (permalink)
Question Custom momentary Switch for Dx6i (Blade 230s)
Hey folks
For us Dx6i - 230s users is it possible to fix a good quality momentary switch similar to the one on the Dx6?
The reason to do this is because I've noticed personally its hard for me to flick the ELEV D/R switch on the fly to apply PANIC and then flick it back instantaneously.
I'd rather have a momentary switch on the right (Cyclic) side just above or next to the RUDD D/R switch so that I can manage collective and let go of the cyclic.
I feel I'd have better control with my left hand focusing on the collective while I use my right fore finger to press the switch.
First of all is it possible to route the wires from the ELEV D/R and get it working with a momentary switch??
Jake
jakeaheli is offline        Reply With Quote Quick reply to this message
Old 07-12-2016, 06:25 AM   #2 (permalink)
I just got another idea.
Since the trainer switch is a momentary one, would it be possible to swap the ELEV D/R with the trainer. So that I now have the trainer switch as the ELEV D/D and the ELEV D/R switch as the trainer switch
Jake
Old 07-12-2016, 07:33 PM   #3 (permalink)
Anyone with a Dx6i past or present ever given this a thought???
Old 07-12-2016, 07:52 PM   #4 (permalink)
I think you can use a mix and have the trainer do a valve on a channel. all depends on how you have it set up. I used 2 switches and turn it into a 3 pos switch. just had to set the PWM to a value through a mix
HELI_FUN is offline        Reply With Quote Quick reply to this message
Old 07-12-2016, 07:56 PM   #5 (permalink)
Default this might help
https://www.helifreak.com/showthread.php?t=521663
Old 07-12-2016, 08:49 PM   #6 (permalink)
Correct me if im wrong. I have set up the 230s according to the manual for the dx6i.
Mix 1 has already been assigned to turn STABILITY mode on and off. I have it set to 1 so STABILITY is always off.
Ive done assigned this to work on the GYRO/FLAP according to the manual.
Can i create a new Mix 2 and experiment with this Trainer Sw?
Im at work, will have to check it when i get home.
Jake
Old 07-13-2016, 07:22 AM   #7 (permalink)
I've attached some pics of Mix 1 and Mix 2.
Mix 1 as you can see has ELEV D/R assigned to activate PANIC. I can't change this to the trainer switch (It doesn't have the option) however it does come up with the other ones.
Mix 2 is just blank.
Is there a way to check the firmware version i currently have ?
Jake
ID:	661723   Click image for larger version
Old 07-13-2016, 09:12 AM   #8 (permalink)
I can't assign mixes to the trainer switch on my dx6i either.
I really wish I could for the same reason.
I basically dont use bailout...if anything I just flip my gyro switch into stability for a moment or two.
crimson66 is offline        Reply With Quote Quick reply to this message
Old 07-13-2016, 07:09 PM   #9 (permalink)
Brings me to the conclusion that I can't assign a Mix to the trainer SW.
Would i do more damage than good by physically swapping out the switches as i described earlier?
Putting the ELEV D/R switch in place of the trainer & the trainer SW in the ELEV D/R's place.
Jake
Old 07-13-2016, 07:22 PM   #10 (permalink)
Jake
Your other option would be to bridge them. Of course then you'll be stuck with that for all your models unless you use a connector you could pull apart inside.
Team USED
Shape S8,G700,G500,Shuttle 550,Trex 500 E/EFL Pro,Oxy 3(2),B400(5),450X,360CFX,Fusion 270(2),230S (V1/V2),200S,120S,Nano (CPS/S2),K110/120/130
BrokeDad is offline        Reply With Quote Quick reply to this message
Old 07-13-2016, 07:53 PM   #11 (permalink)
The Blade 230s is the only model I currently fly with the dx6i. The other 2 banks i have RF7 and Phoenix settings stored.
Plus i use the Throttle Cut button for my timer. I don't think i really need to bridge.
If i did go ahead with my plan would it work ?
Jake
Old 07-13-2016, 09:31 PM   #12 (permalink)
For e.g would i blow up a capacitor or microchip if i happen to get the polarities wrong on either of the switches while testing?
Old 07-13-2016, 09:51 PM   #13 (permalink)
You should be fine
Always remove the batteries before taking the back off your TX
According to the image below that I found on the net, the ELV D/R switch just has 2 wires, it would just be a case of wiring a push button with these 2 wires
If you get it wrong...
- open circuit - the switch won't work
- short circuit - the switch will be on all of the time
toys2cars2toys is offline        Reply With Quote Quick reply to this message
Old 07-13-2016, 11:15 PM   #14 (permalink)
Originally Posted by toys2cars2toys View Post
You should be fine
Hi toys2cars2toys,
Thanks for reassuring me that all will go well I am quite familiar with the insides of the dx6i as i recently installed a back light.
My original plan was to swap the elev d/r & trainer switch and re solder both the 4 wires.
So that now,
I had the trainer switch (momentary) where the elev d/r use to be and the elev d/r switch in position where the trainer used to be.
Swapping the switches but not their functions. Does that make sense?
Jake
Old 07-14-2016, 07:28 PM   #15 (permalink)
Going to take the move this weekend. Will analyze my DX6i tonight after work & purchase 2 types of switches (Push button and a tiny momentary toggle)
Depending what feels better to me will install it. Might even drill a hole if necessary and fit the tiny toggle somewhere where I can have one of my fingers ready on. I feel this is going to be very important to me in order to keep the 230s from crashing less.
A super quick flick of the PANIC can save me a lot of unnecessary crashing
Its just a matter of me getting used to how she handles/flies. I'm quite intermediate with my 3D orientations inverted etc.
Lets see how we do...This is exciting
Jake
Old 07-14-2016, 07:50 PM   #16 (permalink)
Excellent, good luck
I have mine on the left shoulder, opposite from throttle hold
There's nothing to stop you undoing the switches and shuffling them around to suit you
If you're going to drill a hole, how about on the back grip, near your fingers?
Though it might get knocked in transport
Old 07-14-2016, 09:58 PM   #17 (permalink)
Cheers
I will position my fingers on the tx while simming pretending to fly and determine what's best. I could do the rubber grip area, lets see.
Will post some pics up once done.
Jake
Old 07-15-2016, 11:33 AM   #18 (permalink)
If this works for you i'm gonna take the plunge and do the same!
Old 07-16-2016, 05:58 AM   #19 (permalink)
Just purchased a good quality push button today. It fits just right in the already drilled hole of the trainer toggle. Will be working on it tomorrow and hopefully get it fixed up
I feel its going to help a lot in those quick fraction of a second trying to save the 230s better than flipping a hard ELEV D/R switch.
Jake
Old 07-16-2016, 01:13 PM   #20 (permalink)
This could be a saving grace for a lot of people with dx6i's! I'm excited for you. haha
