Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > V977/K110/K120
Like Tree14Likes
Old 08-19-2016, 12:00 PM   #41 (permalink)
Default Canopy repair
A thin fiberglass reinforced clear tape works wonders. Light and strong, and the result looks OK.
Remember to CA around the canopy grommets on the inside before use, otherwise they easily fall out.
Btw the K110 canopies are out of stock on Banggood, but the K120 ones are in stock - so rather order those at the moment.
Edit: Don't! They are of different shape AND the location of the mounting holes are different.
Micro: XK K110, Mini: Gaui X2 Formula
Medium: 330X 6S, G380
Big: G500, Align 700E
DX8, Phoenix
Old 08-19-2016, 12:02 PM   #42 (permalink)
Default You will need spare main shafts
I honestly didn't think they'd be possible to bend... but they sure do bend. So make sure you have a spare or two.
DX8, Phoenix
Old 08-19-2016, 12:29 PM   #43 (permalink)
<deleted>
Team USED
Shape S8,G700,G500,Shuttle 550,Trex 500 E/EFL Pro,Oxy 3(2),B400(5),450X,360CFX,Fusion 270(2),230S (V1/V2),200S,120S,Nano (CPS/S2),K110/120/130
BrokeDad is online now        Reply With Quote Quick reply to this message
Old 08-19-2016, 12:44 PM   #44 (permalink)
Originally Posted by BrokeDad View Post
A K120 canopy won't fit a K110. It's larger and the front grommets are further back. It also has a cutout underneath for the 2S battery.
A K100 or a V977 canopy should fit a K110.
Really? Someone on here said it fits. The K100 only has two grommet holes judging by pics online, but I'll order one and test. Plus the V977 which apparently is a direct fit AND has 4x grommets though the pics on Banggood show the old model with 2x.
DX8, Phoenix
Old 08-19-2016, 12:51 PM   #45 (permalink)
<deleted>
Team USED
Old 08-19-2016, 01:16 PM   #46 (permalink)
Thx man! See post #23 by BirdBarber - he says same shape but differently located holes.
I tried ordering the V977 canopy when the K110 was out of stock, but guess what - BIG sulplise... back ordered as well
DX8, Phoenix
Old 08-19-2016, 01:25 PM   #47 (permalink)
<deleted>
Team USED
Old 08-19-2016, 01:31 PM   #48 (permalink)
deleted
DX8, Phoenix
Old 08-19-2016, 03:05 PM   #49 (permalink)
Only the early V977 canopy had 2 holes. The current ones have 4 holes and are identical to the K110, I have used one on a K110 before with no modifications. They are also $2 cheaper.
Also the K120 canopy may look bigger, but if you have both take them off the helis and you will see the K120 will fit inside the K110 canopy perfectly, just like stacking Russian dolls.But the mounting holes are in a different location and it has the bottom cutout.I think it only looks bigger because of the mounting angle and taller skids on the K120. It's mounted with the nose pointing higher on the K120.
Name:	K120 vs K110 canopy01jpg.jpg
K110 2S, K130, HCP100S, 180CFX, T-Rex 250 & 450, V120D02S, Master CP BL, V200D03, V911
Devo 6S 7E F7 8S 10 12S F12E Deviation, Taranis X9D, T8J, 9X, DX6i, Phoenix 5, RF 7
Team Pilot: MallHeli FireDemon
Extreme Air Ninja 3.6 Channel
BirdBarber is offline        Reply With Quote Quick reply to this message
Old 08-19-2016, 03:18 PM   #50 (permalink)
-Duplicate post deleted-
Old 08-19-2016, 03:23 PM   #51 (permalink)
Ah! So the pics on Banggod of the V977 canopy is an old pic then!
http://www.ebay.com/itm/Tarot-Thrust...c5PbhZCaKM_VTQ
OK - all should be just dandy then! Thx guys!
DX8, Phoenix
Old 08-19-2016, 03:43 PM   #52 (permalink)
All of Banggood's V977 pictures that I looked at are of the old model. It only had 2 canopy grommets and the collective pitch range was not adjustable either. I don't think there are many of them out there.
I bought a replacement canopy from Banggood a few months ago and it was the new 4 hole canopy.
Old 08-19-2016, 03:51 PM   #53 (permalink)
Is the V977 canopy any stronger than the K110?
The XK one does tear quite easily. Not bad at all, but also not super durable.
I have very good experience with the Hisky HCP80 canopies for the Blade Nano, they are a lot stronger than the stock ones.
There's not by any chance a Hisky canopy that might fit?
I've tested divers Nano, nCPX and 120SR canopies - but no good fit. The Lynx mCPX BL canopy might fit with some trimming, but not great I think.
The strongest canopies I've ever had for micros are the ones from Team Extreme (all other "upgrades" I've bought from them were crap though) - they must be made from proper lexan I think - and just last forever. If we could find a fitting one there...
DX8, Phoenix
Old 08-19-2016, 03:58 PM   #54 (permalink)
The V977 canopy is the same strength as the K110. I'm pretty sure WL owns XK or at least manufactures the XKs for them. The canopies are identical and probably made in the same factory, but just with different graphics.
Old 08-20-2016, 05:15 AM   #55 (permalink)
Btw BB I see you're using zip-ties for tail fins.
Did you ever try these? (I have them on order)
http://www.banggood.com/Tail-Motor-M...-p-936293.html
and
http://www.banggood.com/WLtoys-V977-...-p-936299.html
DX8, Phoenix
Old 08-20-2016, 07:20 AM   #56 (permalink)
Originally Posted by babyuh1 View Post
HCP 100S-
Definitely use the nanotech 300mah batteries!
Tell me more please!
DX8, Phoenix
Old 08-20-2016, 10:58 AM   #57 (permalink)
and
That's the aluminum tail motor mount I use. I also bought those carbon fiber tail fins but they broke too easily. I still have some new in the bag in my parts bin that I decided not to mount. Somebody told me to use zip ties instead of tail fins and they work great for keeping the tail rotor off the ground and preventing damage.
The tail motor mount is a little hard to install the first time, but really stays in place on the boom. That's because the screws actually need to have two small grooves in the tail boom in order to screw them in. You can't even press the mount onto the boom when the screws are in place. I just take the screws out, press the mount on the boom then push a tiny drill bit in a pin vise thru the holes to start the two grooves on the bottom of the boom (insert drill bit into non threaded side). Then I pull it off and use a tiny round file to make the grooves a little deeper and all the way across the boom. Then put it back on and the screws go right in and can't slide down the boom because they are in the grooves. It works much better than they type that just rely on clamping force, and you really don't even need to tighten it extremely tight like the other ones.
Old 08-20-2016, 11:27 AM   #58 (permalink)
Gr8, thx!
DX8, Phoenix
Old 08-20-2016, 03:17 PM   #59 (permalink)
Default Alu upgrades?
BB, you seem to have a Dr's degree on these birds - what would you say about the alu upgrades for swash, grips, and head?
DX8, Phoenix
Old 08-20-2016, 05:31 PM   #60 (permalink)
I think I have crashed these more than anybody else is why I know them so well! lol
I've never tried aluminum swash or head because the stock plastic seems to work pretty good and absorbs crash damage. I only upgrade those parts on helis that have sloppy parts or break the plastic ones a lot. I haven't heard the results from people who have upgraded. I would think the bling factor would be the only major reason to upgrade, but I could be wrong.
