Go Back   HeliFreak > R/C Helicopter Support > Other Makes and Models Helicopters > V977/K110/K120
Like Tree16Likes
Old 08-20-2016, 10:19 PM   #61 (permalink)
Originally Posted by SHYguy View Post
BB, you seem to have a Dr's degree on these birds - what would you say about the alu upgrades for swash, grips, and head?
Adding weight is what you are doing, mainly, with that comes..., what?
I would recommend you to stick with plastic, more fly time and as BB said, bling is not needed with this birds.
It would not make it better, they use same bearings.
salrica is offline        Reply With Quote Quick reply to this message
Old 08-20-2016, 10:35 PM   #62 (permalink)
i ca glue in the bottom main shaft bearing as i have had the gear pop off and the bearing fall out in a crash. The gear is hard enough to find in the grass but forget about the bearing.I also use hisky gears , they seem to work better
pilotmotor is offline        Reply With Quote Quick reply to this message
Old 08-21-2016, 12:41 AM   #63 (permalink)
Great advice guys!
Micro: XK K110, Mini: Gaui X2 Formula
Medium: 330X 6S, G380
Big: G500, Align 700E
DX8, Phoenix
Old 08-21-2016, 12:53 AM   #64 (permalink)
I'm currently trying lining the main shaft bearing pocket sides with CA glue and letting it dry to form a layer to make it smaller, then I'm installing the bearing. Time will tell if this helps. I haven't lost a bearing since I started doing this, but it's only been a couple of weeks so far and I usually only lose one bearing every month or two anyway.
I've also stopped picking up a crashed heli by the head as I had one bearing pop out and get lost when I picked up the heli by the rotor hub when the main gear had already popped off.
K110 2S, K130, HCP100S, 180CFX, T-Rex 250 & 450, V120D02S, Master CP BL, V200D03, V911
Devo 6S 7E F7 8S 10 12S F12E Deviation, Taranis X9D, T8J, 9X, DX6i, Phoenix 5, RF 7
Team Pilot: MallHeli FireDemon
Extreme Air Ninja 3.6 Channel
BirdBarber is offline        Reply With Quote Quick reply to this message
Old 08-21-2016, 01:15 PM   #65 (permalink)
Originally Posted by salrica View Post
Just in case you need a new screwdriver for this helis
Screwdriver JIS Type s 0 Pollicis | eBay
My findings are slightly different. I hope this helps someone. http://www.rcgroups.com/forums/showt...php?p=35534106
Thickfog is offline        Reply With Quote Quick reply to this message
Old 08-21-2016, 03:33 PM   #66 (permalink)
Originally Posted by BirdBarber View Post
The V977 canopy is the same strength as the K110. I'm pretty sure WL owns XK or at least manufactures the XKs for them. The canopies are identical and probably made in the same factory, but just with different graphics.
I own both, V977 canopy is thicker a little, so it looks like it is stronger.
Anyway both could be repaired with duct tape infinitely
Twilight_Sun is offline        Reply With Quote Quick reply to this message
Old 08-23-2016, 02:47 AM   #67 (permalink)
Default Alternate main blades
I've tested now the bullet blades from the HCP100S. They are almost the same size. They fly at least as well, maybe even a little bit more stable. So highly recommended if you need new blades.
You can get a pack of 10 sets for only 12 bucks:
http://www.banggood.com/10-Pairs-His...p-1047523.html
The plastic in these and the stock ones seem great - much like the stock Blade main blades. I've btw always preferred bullet blades on all my Nanos and mCPX'es as well. Also for 3D.
DX8, Phoenix
Old 08-23-2016, 06:28 AM   #68 (permalink)
Tell me more please!
The Hobby King Nano Tech 300 MAH batteries are perfect for this bird. They are just as or more powerful and are much lighter than the stock batteries. They make a huge difference in how the heli flies.
Please don't confuse my experience with pessimism!
Protos 500, HCP100S, Raptor 50, many more!
babyuh1 is offline        Reply With Quote Quick reply to this message
Old 08-23-2016, 07:04 AM   #69 (permalink)
Sounds great! I did a comparison with 2x 1S 450 mAh batteries vs the stock 2S 450 mAh battery - and it does indeed seem "too" heavy:
Would you be so kind as to link me to the battery - so I'm 100% sure I get the right one? Is there also a Graphene version now?
DX8, Phoenix
Old 08-23-2016, 10:54 AM   #70 (permalink)
Here is the link and there is a higher C rated one as well.
PS don't believe their listed weights, they are lighter.
Old 08-23-2016, 12:50 PM   #71 (permalink)
See no link
DX8, Phoenix
Old 08-23-2016, 08:30 PM   #72 (permalink)
http://http://www.hobbyking.com/hobb...arehouse_.html
OK, lets try again! This is from the US, you could order from any of their warehouses.
Old 08-23-2016, 10:26 PM   #73 (permalink)
I used a digital micrometer to check mine at the same spot on the top. The V977s were .34mm & .36mm and the K110 was .35mm. I think there must be some manufacturing variance if your V977 is thicker than the K110, I wouldn't count on it always being like that. My V977 canopies are the newer 4 hole design, not the old 2 hole design.
I would weight test them, but they have too much packing tape on them! lol
Edit: I just measured multiple points around a couple of canopies and the thickness varies quite a bit from point to point and canopy to canopy, by as much as 50%. So the only true test would be to weigh them, but too many repairs on mine to do that.
Twilight_Sun, do you have two un-taped canopies and a good scale? Inquiring minds want to know which to buy! lol
Old 08-24-2016, 03:20 AM   #74 (permalink)
OK, so the 35-70C
Did you try the 45-90C, any difference? And is it heavier?
Edit: I just ordered 3x 45-90C packs:
I also ordered this canopy (not positive it fits but I would guess so) for the HCP100S:
DX8, Phoenix
Old 08-25-2016, 02:16 PM   #75 (permalink)
My mechanical micrometer says that k110 - 0.20mm, v977 - 0.31mm
I've measured the same point on both - flat part near right rear grommet.
Both are cut a little (near skid) and have some tape (not a lot)
k110 - 1.99g
v977 - 2.64g . it looks like it is a significant difference
also I have near a new canopy for v977 (without cuts) - 2.60g and 0.25mm on left side (right one has small amount of tape on that place. but near it - 0.30mm)
By the way they have different behavior in "nose to ground" crashes. V977 can survive more force but tend to crack only. k110 could be jammed sometimes with no cracks. I dunno what is better.
Of course I can say only about mine ones. k110 is stock one. v977 one is stock one is aftermarket.
P.S. and both v977 ones without one grommet
Old 08-25-2016, 11:15 PM   #76 (permalink)
I have an untaped K110 canopy, it is 2.24g. Looks like there is a bit of variation between them. My V977s have a full layer of "crack preventative" tape inside so it's pointless to weigh them. The V977 canopy is $2 cheaper so I'll be ordering them. Both canopies seem to hold up fairly well compared to Blade and smaller Walkera.
Edit 08-27-16 My new K110 arrived, it's canopy is 2.60g, .36g more than my old one.
Old 08-25-2016, 11:40 PM   #77 (permalink)
Good idea to have this handy, so you will not dry your packs that low.
http://www.ebay.com/itm/1S-6S-LiPo-B...item1c60297ee0
This one gives reading from 1s up to 6s
Old 08-26-2016, 12:16 PM   #78 (permalink)
I use this one to charge and monitor the voltage on my 1s lipos.
sikwati is offline        Reply With Quote Quick reply to this message
Old 08-26-2016, 01:50 PM   #79 (permalink)
Hey guys,
I still have stock K110 canopy, didn't brake it yet. I think I read somewhere that if you add duck tape on the canopy when it is still fresh you can extend it's life for almost forever. What do you think about that? Do I have to apply it from the outside or the inside for better protection against cracks?
LukasKri is offline        Reply With Quote Quick reply to this message
Old 08-26-2016, 07:41 PM   #80 (permalink)
I use clear packing tape applied to the inside of the canopy. You can also the use spray-on clear PlastiDip to coat the inside of the canopy, it's the stuff people use to coat the handles of tools and such. If you use PlastiDip then break the tips off of toothpicks and insert the tips into the canopy grommets before you spray it on. I put stuff on the inside of the canopy because it looks better, I don't know if inside or outside is stronger.
https://plastidip.com/our-products/plasti-dip/
