Go Back   HeliFreak > R/C Electronics Support > Mikado V-BAR Control
Mikado V-BAR Control Mikado V-Stabi/V-BAR Control Flybarless System Software and Hardware Support
Old 07-25-2016, 11:14 AM   #1 (permalink)
Default VCopter thread
Hey guys, I know I promised a VCopter thread so here it is! So let me first say, I am a relative noob when it comes to quads, setups, and tuning. This would prove to be the perfect testbed for me as I would experience a lot of what new people would as well.
Equipment:
I fell in love with ehe Neato frames Dallas 220 BUT they didn't have any of those in stock so I got a Neato180 and found the equipment for it. This is what I chose:
(1) Neato Frames 180
(4) Voodoo quads MR 2204-2650KV motors
(4) Little Bees Pro 20 amp ESCs
(1) Pyrodrone run cam
(1) Lumineer 600 mw Video transmitter (found out this was overkill and a 200mw would be just as good)
(1) Maytek power distribution board
(1) VBAR NEO with Copter and rescue (not in 3D mode yet)
(4) Gemfan Bull Nose 4045BN props
(1) Fat shark antenna
(1) Extension
Goggles:
(1) Fat shark HD 2 goggles
(1) UBAD LaForge Video rx with diversity antenna
(1) Immersion RC Diveristy antenna
(1) Mad Mushroom antenna
Build:
Building a quad is a tight event. I was able to get all the ESCs inside the frames as well as the PDB and the VTX and camera. The build went well, the only hiccup was programming the ESCs. I got some help from Brian Phillips (this guy KNOW how stuff!), I got the ESCs programmed and then it was off to set the NEO.
Surprisingly it took no time to get the NEO setup! Once you plug the ESCs into the correct ports according to vstabi.info, then it is just setup of the gains and such.
I chose to go with the default gains and use the transmitter to adjust in the air. The stock gains were way too high, I had to lower them about 20 points but now it is solid. Climbs are hard and fast and decelerations are quick and precise.
The Video is one of the coolest things going, I can see how they are addictive and with the diversity setup, I can fly virtually anywhere without a loss of signal.
Here are some pics and I will add some later:
ID:	663446   Click image for larger version
ID:	663447   Click image for larger version
ID:	663448   Click image for larger version
ID:	663449   Click image for larger version
MikadoUSA Tech Support
Laughingstill is offline        Reply With Quote Quick reply to this message
Old 07-25-2016, 12:15 PM   #2 (permalink)
In terms of video performance you will get an improvement by fitting a mad mushroom on the model as well.
Absolute rank amateur on quads here, just thinking about starting.
I've not read about the NEO but on other FCs you are able to program the ESCs through them. It will make things so much easier when an update comes along that you want to try.
Andy from Sandy is online now        Reply With Quote Quick reply to this message
Old 07-25-2016, 01:17 PM   #3 (permalink)
I too am just starting, and while I do not have a VControl radio, I found this blog to be helpful in getting into the technical parts of this multirotor thing.
Here's an article on how to program BLHeli firmware ESCs through Cleanflight without having to go through the hassle of building, soldering, flashing, and using an Arduino nano unit to program each ESC: https://oscarliang.com/flash-esc-via-cleanflight-fc/
You can dig around to find more information on ESCs and other bits of cutting edge developments.
https://oscarliang.com/choose-esc-racing-drones/
https://oscarliang.com/oneshot125-esc-quadcopter-fpv/
I'm definitely interested in seeing other heli guys get into this FPV stuff, it's one hell of a rabbit hole, and seeing a heli-pilot's perspective really helps.
Fauropitotto is offline        Reply With Quote Quick reply to this message
Old 07-25-2016, 02:14 PM   #4 (permalink)
With the NEO you cannot program the ESCs though it, you need to do them separately and then plug them in. Everything else is done in the transmitter.
As far as updates go, do you mean an ESC update?
Old 07-31-2016, 01:38 PM   #5 (permalink)
With the flight controller I have been looking at it is possible to do a firmware update and also a setup on the ESCs through its USB connector.
Thanks for the links Fauropitotto, I will take a look.
Old 07-31-2016, 02:54 PM   #6 (permalink)
Yes, the NEO does not do that (yet maybe?). I will talk to to the Rainer at IRCHA and see if that is a possibility in the future
Old 07-31-2016, 03:17 PM   #7 (permalink)
I'm curious is vcopter only supported on the neo or is it like vplane any old vbar supports vcopter? I know I'm being lazy and not checking vstabi but I'm here so I figured I'd ask
__________
Goblin 380, 500, 570, Mikado 690SX, 480Xx(Stretched 500) , Protos Mini, Max V2 , Oxy 3, Vbar Control/Neo Vlink (Citizen 758)YouTubeProgress:http://tinyurl.com/oliver1071
oliver1071 is offline        Reply With Quote Quick reply to this message
Old 08-01-2016, 12:10 AM   #8 (permalink)
VCopter only on Neo.
VControl
Old hand at Planks
Peter
Old 08-01-2016, 06:13 AM   #9 (permalink)
To bad would be a nice cheap option for quads. I guess the hardware is limiting on the older ones.
__________
Old 01-28-2017, 01:39 PM   #10 (permalink)
I would like to put a Neo on my Invertix 400. The ESCs are already reversible so I shouldn't have to reprogram them should I ? Can you use rescue feature on a quad ?
Diabolo 700 BE, 600, Logo 600, 200, Goblin Raw 700, Kraken 580, VCT, VBar, Egodrift, Scorpion, Kontronik, MKS, XPert, KST
Freeskiken is offline        Reply With Quote Quick reply to this message
Old 01-28-2017, 01:59 PM   #11 (permalink)
Yes you can, I have on my Neato 180
Old 01-28-2017, 02:08 PM   #12 (permalink)
Cool I am going to try it.
Old 01-28-2017, 11:58 PM   #13 (permalink)
Well I bought another VBar Neo Vlink with Rescue to put on the Invertix 400. I was thinking I am going to install a U/I Sensor with it.
Looking forward to trying it out.
