Old 05-21-2008, 09:09 PM   #41 (permalink)
Originally Posted by Finless View Post
The gear ratio is 8.25. The pinion is 12T. I don't know the tooth count on the main gear but with that you can figure it out
OK I did... it's 99
Bob
Thanks Bob!
Originally Posted by torkboy
Long-
We are running 1850, and 1900. Both headspeeds are awesome, I dont think there is anymore need for a higher headspeed. The YS's sweet spot seems to be around 15300 rpm.
We all love modifying helicopters don't we? If there is any chance to reduce the ratio to 8.0 or 8.18 that's would be great!
Long Nguyen
Long Nguyen is offline        Reply With Quote Quick reply to this message
Old 05-21-2008, 10:37 PM   #42 (permalink)
Hey Jason B.
Do you use any shim for the YS91SR?
Long Nguyen
Old 05-21-2008, 10:42 PM   #43 (permalink)
No, I didnt not use the motor spacer for the YS motor.
Representing:
AMain Hobbies, XNova Motors
Jason Bell is offline        Reply With Quote Quick reply to this message
Old 05-21-2008, 10:43 PM   #44 (permalink)
So the gear mesh was right on?
Long.
Long Nguyen
Old 05-21-2008, 10:43 PM   #45 (permalink)
Jason, can you comment about how difficult it is to remove the main shaft?
jared_of_atlanta is offline        Reply With Quote Quick reply to this message
Old 05-21-2008, 11:02 PM   #46 (permalink)
I finally found my problem when flying my 600N Pro............I should be building the barring blocks of an Avant Aurora instead of flying.
"Tighten-up.........Tighten-up...........Tighten-up.........close call with ground.....Tighten-up... .......Tighten-up............"
Just joking thanks Bob.....
Jeti DS-16 Carbon in Red
Logo 600SX/Pyro700-52L / Jive80+HV / V-Bar Silverline 5.3 / SAVOX
600Nitro Pro / Solid G/ 8900G - TT RedLine 53
Trex450 / Performance Aerobatics AdictionX / Blade mCPx2
mclaren is offline        Reply With Quote Quick reply to this message
Old 05-22-2008, 12:42 AM   #47 (permalink)
Cant get any of the links to work i press them and the little helifreak window does not appear with the right click save as option?
Team Lynx
Team Mad 4 Heli
Gens Ace Batteries
Citizen # 310
jody is offline        Reply With Quote Quick reply to this message
Old 05-22-2008, 02:09 PM   #48 (permalink)
Team Taco VP
Step 3 posted!
Enjoy,
Bob
Old 05-22-2008, 02:55 PM   #49 (permalink)
Please Bob, stop with the little clip between segments!!
T-Rex600N Pro
X9303/R921
Spartan Ds760 Gyro (love it)
mporlier is offline        Reply With Quote Quick reply to this message
Old 05-22-2008, 02:56 PM   #50 (permalink)
I like the little clip.... but change them up a little. Make the text easier to read..... and add in a hot babe or two holding the heli.
Just a guy and his heli....
LITHIUMSTATIC is offline        Reply With Quote Quick reply to this message
Old 05-22-2008, 03:16 PM   #51 (permalink)
grand rc hooked him up big time, why shouldnt he? just fast fwd through it if you dont like it, thats what i do.
-Nich
LPS - Last Pack Syndrome - It's always the "last" pack.
ImNix is offline        Reply With Quote Quick reply to this message
Old 05-22-2008, 03:19 PM   #52 (permalink)
Sheesh..... it's only a 4 second little clip. I guess those 4 seconds can seam like eternity if your in deep anticipation of the next step. The hot babes would make it a more pleasant 4 seconds.
Old 05-22-2008, 05:30 PM   #53 (permalink)
Long.
The main gear mesh with the pinion is not adjustable.
Simple, Remove the tank(like 2 seconds), and access the set screw with a 3mm wrench, I use a ball ended L shaped alan wrench. Once the set screw is out, pus the pin out, an your done.
Representing:
Old 05-22-2008, 05:39 PM   #54 (permalink)
hot babes with heli bikinis
rotorhead58d is offline        Reply With Quote Quick reply to this message
Old 05-22-2008, 06:04 PM   #55 (permalink)
Ok now got the vids down and i am loving it. Not quite as good as building my own but ppretty darn close Great work Bob as ALWAYS!!
Team Lynx
Team Mad 4 Heli
Gens Ace Batteries
Citizen # 310
Old 05-22-2008, 10:27 PM   #56 (permalink)
The Capi
Great looking kit, kind of curious why Augusto didn't anodize the parts.
Old 05-22-2008, 11:00 PM   #57 (permalink)
chrome don't get ya home
Old 05-22-2008, 11:06 PM   #58 (permalink)
The Capi
Anodizing isn't the same thing as chrome. And anodizing helps to prevent leaving small scratches and finger prints on the nicely machined parts.
Old 05-22-2008, 11:08 PM   #59 (permalink)
I think they have a type of anodizing that's natural looking..... at least they do on hot rods.
Old 05-22-2008, 11:16 PM   #60 (permalink)
The Capi
Alum naturally rusts, this forms a thin layer of alum oxide. This layer will be thin as eventually the oxygen can't reach the alum throu the layer of alum oxide. Anodizing is a process to force the natural process to continue making the alum oxide layer thicker. The thicker alum oxide layer is much harder which helps prevent scratches and the oils in your fingers attacking the metal. Visually the only difference between a anodized and a non-anodized piece is the anodized piece looks little whiter and hazier.
Tags
aurora, avant, finless, helifreak aurora videos
