Go Back   HeliFreak > R/C Helicopter Support > Gas Powered Thoughts
Gas Powered Thoughts Advice for Gas Helicopter Success from Carey Shurley
Old 08-11-2016, 05:25 PM   #21 (permalink)
Hey Doug,
Hope your well mate
Yeah, like the Goblin, Agile and 766, everything to be gained form keeping servo lead runs short and FBL out of any potential Heat Failures.
I think this has been a reliable formula to date.
Joey.
jc23cl is offline        Reply With Quote Quick reply to this message
Old 08-11-2016, 10:14 PM   #22 (permalink)
Joey, looks fantastic As always, amazing work.
Protos 380 - Xnova 2820 - HW60V4 -Brain2
Goblin 570 - 91SRX Tareq - Hatori - Brain2
Goblin 700c - TRM VX300se - TRM - Brain2
Protos 770 Max V2 - Xnova 4535 - HW160V4 - Brain2
Sowa is offline        Reply With Quote Quick reply to this message
Old 08-13-2016, 01:43 PM   #23 (permalink)
Drool...
So glad this came to fruition. Will the gearing have a particular blade length in mind?
Sent from my SAMSUNG-SM-G900A using Tapatalk
Whiplash Gasser l Goblin Gasser
in2deep is offline        Reply With Quote Quick reply to this message
Old 08-13-2016, 07:35 PM   #24 (permalink)
the usual 690-715 depending on your flying style and blade design in terms of loading
I tend to run 690ish blades on all these things.
Carey Shurley
Proprietor - Gas Powered Helicopters
carey shurley is online now        Reply With Quote Quick reply to this message
Old 08-15-2016, 07:53 AM   #25 (permalink)
Question
Pardon the newbie questions:
Why wouldn't you run 716 - 806 blades?
As I expect that it will be heavier than electric, wouldn't it make sense to improve the disk loading? (thinking autos, etc.).
Tuned Zenoah motors have more power; wouldn't they handle the larger disk?
Learning all the time from you guys...
Al
Synergy E7se HC3-SX
Align T-Rex 550E HC3-SX
Futaba 14SGH
RealFlight 7.5
al_voisine is offline        Reply With Quote Quick reply to this message
Old 08-15-2016, 10:25 AM   #26 (permalink)
true the larger blades are great for improving the disk loading but the fact is that just like glow motors its not that hard to overload the engines ability to hold/recover disk rpm
a good example is the goblin nitro, most 700 models use 700ish mm blades. They chose to use 650ish blades to improve overall performance at the expense of better blade loading.
doesn't apply so much with electrics where there is so much power available
Carey Shurley
Old 08-16-2016, 05:20 AM   #27 (permalink)
Thanks, Carey! If I understand, you think even the newer motors would not be able to hold RPM with the longer 806 blades. So flying style would be seriously affected.
AL
Synergy E7se HC3-SX
Futaba 14SGH
RealFlight 7.5
Old 08-16-2016, 01:43 PM   #28 (permalink)
sorta depends on your flying style and pitch requirements. If you're just sport flying using a lower head speed with the proper drive ratio you can get away with longer blades
high performance/high headspeed seems to work better with shorter blades
Carey Shurley
Old 08-17-2016, 12:04 AM   #29 (permalink)
Gonna keep my eye on this
jhartsock3 is offline        Reply With Quote Quick reply to this message
Old 08-17-2016, 09:51 PM   #30 (permalink)
Looks killer!
Is there an guestimate as to when this will be available?
Raptor 50FBL, x50FBL, Trex550, Compass Odin 90
nathan211 is offline        Reply With Quote Quick reply to this message
Old 08-18-2016, 12:46 PM   #31 (permalink)
everytime I make a prediction I wind up being wrong but it won't be as long as some of our previous projects. I'd like to have at least one flying this year, time will tell. Its hard to predict how long it takes to have parts made in relatively small qtys and whether or not there are any quality issues when they are made
Carey Shurley
Old 08-18-2016, 03:54 PM   #32 (permalink)
Since the 766 was originally designed to be bigger than 700 size(everything built heavier), will trying to make it into a 700 gasser make it heavy compared to the other gassers out there? Otherwise, I think it is a great looking heli.
Trex 600n, A610's, Fut.9254, OS50, JR9303
JR Ergo 46, JR4735's, OS46FX
Trex 450P, A410's, A510, Align esc, GP780 gyro, AR6110,
Blade 400, Hitec 65mg's, JR290 w/Fut. 401, stock esc w/Sport Bec, Sonic head and tail
Fairview is offline        Reply With Quote Quick reply to this message
Old 08-18-2016, 06:12 PM   #33 (permalink)
Well, I'm not sure what the weight of the converted model will be yet so I can't answer that
however there will be multiple drive ratio options to run the various blade lengths
Carey Shurley
Old 08-19-2016, 02:09 PM   #34 (permalink)
I have enough helis!
Hmmm a Synergy Gasser... hmmmmm....
Futaba 14SG, Synergy E5, Furion 6, Beam E4(v1) FBL, CGY750, Skookum
dpelletier is offline        Reply With Quote Quick reply to this message
Old 08-20-2016, 06:01 PM   #35 (permalink)
Looks great let me know when I can pre order.
Team Synergy
bmw576 is offline        Reply With Quote Quick reply to this message
Old 08-21-2016, 09:59 AM   #36 (permalink)
Default Its going to be big
If you're flying that machine with 816 blades I think the performance is going to be similar to the JR or Airstar/Vario machines, more sport than 3d. In 716 configuration its going to be close to 3D, but it still may be heavier than the rest not sure about that after Carey puts one together it will be interesting to see what it comes up with.
Ideally under 13 lbs will be better but some of the conversions tend to come in closer to 14. Since the synergy is a bigger model, I would expect it to be close to 14 than 13. Of course you can always fly it with the big blades and 3D slowly with it like guys fly it on 1 battery pack at slow head speed. In the gasser configuration it will beat that performance I'm sure.
-=>Raja.
MA 1005, Hanson 280, 4309 flights, Spectra-g, Hanson 270, 3434 flights
Whiplash-g V1-2, Hanson 300, 1944 flights, Whiplash-g V2, Hanson 300, 825 flights
Jewel on-board Generators, Miniature Aircraft Team Manager
rbort is online now        Reply With Quote Quick reply to this message
Old 08-21-2016, 02:37 PM   #37 (permalink)
Huuummm I don't need another heli but this looks interesting !
banshee rider is offline        Reply With Quote Quick reply to this message
Old 08-21-2016, 03:26 PM   #38 (permalink)
What will be really interesting, is how the 766 in the 716 format will compare to the Agile performance wise. Carey mentioned the Agile was very responsive converted.
"I love the smell of Nitro/Gas in the morning!"
Citizen 654
rcnut is online now        Reply With Quote Quick reply to this message
Old 08-21-2016, 11:36 PM   #39 (permalink)
Is it just me or is that using a nitro tank? Wouldn't a proper Dubro tank be better?
Atomic Skull is online now        Reply With Quote Quick reply to this message
Old 08-23-2016, 03:22 PM   #40 (permalink)
Most gasser conversions use the tanks from the heli it was originally (nitro), and a lot of the gas conversions I've seen were using Trex 700 tanks.
Keith - MSH Brain2 Beta Test Team
Synergy N606 | Synergy 516S | GAUI NX5 | T-REX 470LP
FrSky Help Click Here
https://kc3dprint.com - 3D Printing on Demand and Printed RC Helicopter Upgrades
Number is online now        Reply With Quote Quick reply to this message
