warp 360 - HeliFreak
Go Back   HeliFreak > R/C Helicopter Support > Compass Model Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 08-16-2016, 06:05 AM   #1 (permalink)
Default warp 360
For some strange reason my warp does not fire up. Last night I flew several packs and returned home with my heli in one piece, this morning it the motor would not kick in, no throttle. I tried rebinding and the results were nil. I did not crash or change any setting. Hope some one can help me.
sing23 is offline        Reply With Quote Quick reply to this message
Old 08-16-2016, 08:58 AM   #2 (permalink)
Sing, please provide more information. What ESC, radio, motor, fbl?
NX4|eXo|Chronos|7NT
*AccuRC Substance Guru*
Saje Marvin - Citizen 125
Raz0rSh4rp is online now        Reply With Quote Quick reply to this message
Old 08-16-2016, 02:52 PM   #3 (permalink)
And what has power and what doesn't.
What did you try to do to fix the problem?
GravityJunkie is offline        Reply With Quote Quick reply to this message
Old 08-16-2016, 03:24 PM   #4 (permalink)
If it is a BeastX based FBL make sure you didn't bump in some throttle trim.
Team USED
BrokeDad is online now        Reply With Quote Quick reply to this message
Old 08-16-2016, 06:43 PM   #5 (permalink)
The only time the same thing happened to me it was dead ESC.
Logo 500XX,600SE lowRPM, Warp 360 , Sport 360
T500 AP
Luigi_tuga is offline        Reply With Quote Quick reply to this message
Old 08-16-2016, 11:13 PM   #6 (permalink)
Sing23,
Make sure that the BEC in the ESC is providing power to the AR7200BX.
I remember your machine-it flew GREAT!
Old 08-17-2016, 08:27 AM   #7 (permalink)
fixed, the thro trim was to high.
Old 08-17-2016, 10:26 AM   #8 (permalink)
Nice
T500 AP
Old 08-17-2016, 12:25 PM   #9 (permalink)
OUTSTANDING!
Old 08-17-2016, 12:30 PM   #10 (permalink)
Problem fixed throttle trim to high, Ah Clem just wondering if you could send me the set up for the beast and my tx (dx6) ? My heli started to act very strange after the throttle fix. Not sure what happen but it flew out of control, I might have messed it up trying to fix the other problem. I tried to pm you but your box is full.
Old 08-17-2016, 01:51 PM   #11 (permalink)
Sing,
When Ah Clem sends you the setup stuff (if he still has it), the thing you might want to seriously consider is sitting down and try to figure out what does what. I know I will be willing to help you with any question you may have if I know the answer. I'm sure any team member will do the same thing, as well. The bottom line is this: The more you learn the less time you spend trying to figure out what's wrong. All of us have been there and all of us are willing to help. I know I spent six months learning how to set up a helicopter properly, so if I can do it, you can, too!
Hang in there!
Scott
Team Compass USA--Team Pilot
KBDD Team Pilot ):>
http://www.experiencerc.com : Making Helicopters Great Again!
Old 08-17-2016, 04:44 PM   #12 (permalink)
Seems I spend more time fixing instead of flying, thanks for the encouragement
Old 08-17-2016, 05:19 PM   #13 (permalink)
I think you need to step back and realize that learning about this stuff is paramount. Until you learn what stuff does on your transmitter and any other electronics component, ask. Read the manuals--Particularly for your FBL unit. Typically, you set your transmitter as stated in the manuals for the Beast X and leave the transmitter alone. So, for a BeastX, no trim, no subtrims, enpoints all set to 100 and -100 (except for your throttle, based on your ESC and whether or not you use a governor. Tail gain for a Beast X is the exception. You typically adjust tail gain on your transmitter's gyro channel. But if you don't have tail wag in flight, leave it alone--it's set.
I know Ah Clem helped you by setting up your helicopter, so you should post your transmitter settings and go from there.
Scott
KBDD Team Pilot ):>
Old 08-17-2016, 09:22 PM   #14 (permalink)
sing23,
I do not have your transmitter or FBL unit settings. I did not have a way to save either-my apologies.
Do you have a four cell nimh or nicad battery to do setup with (I would rather you did not do it with a live ESC for safety reasons).
Did you ever send your transmitter back in to Horizon as I recommended? As I recall, the throttle hold function was intermittent. I mentioned it to you in PM's and also publicly posted about it.
Old 08-18-2016, 01:18 PM   #15 (permalink)
off til Monday and I am going to get this I promise , I am studying the beastx manual right now, and I am going to re do the thing myself and I will keep you posted.
Old 08-18-2016, 03:49 PM   #16 (permalink)
There may not be a reason to redo the setup! Read the manual, go through the settings. In order to properly setup an FBL unit you need some tools. Post what your settings are here--radio included--and we'll tell you what you need to do and why. The "WHY" is the most important part of the process!
Scott
KBDD Team Pilot ):>
Old 08-18-2016, 05:01 PM   #17 (permalink)
my dx6 are as follows: reverse THR N ALI N ELE R RUD N GYR N
PIT R - DR NOR- 100 EXP 0 IDLE 1 85- O IDLE2- 100-0 THR CURVE-0 25 50 75 100 ST1- 65 65 65 65 ST2 100 100 100 100 HOLD- INH PITCH-N 37 41 50 75 100 ST1- O 25 50 75 100 ST SAME GYRO N32.0
ST1 30.5 ST2 30.5 HOLD34.0 CHAN GEAR
Old 08-18-2016, 05:21 PM   #18 (permalink)
Default 360
A= BLUE
B=BLUE
C=BLUE
D=RED,
E=TAIL END POINTS
F=BLUE
G= --------
H=RED
I=RED
J=----------
K-----------
L=BLUE
M=BLUE
N=BLUE
Old 08-18-2016, 05:23 PM   #19 (permalink)
Sing23,
The throttle curves are nowhere near how I set them. I had the Idle up curves in gentle "U" curves. You won't get the most out of it with flat throttle curves unless you have a governor (which you did not, when I had your machine).
Did someone else "adjust" if for you?
Old 08-18-2016, 05:34 PM   #20 (permalink)
YES AFTER A BLADE STRIKE A GUY AT THE FIELD SET IT BACK UP. That is why I wanted your settings, but it did fly.
Human Verification
