Like Tree87Likes
Old 09-03-2018, 11:13 AM   #481 (permalink)
Wonder how the 477's would do on a 500 class.
Bill, my XL520 is 2.6kg all up, do you think they'd do well at 2400ish head speed?
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 09-06-2018, 01:02 PM   #482 (permalink)
We need some 517s!
GimpyGolden and mverhorst like this.
NX4|Tri-Chronos|Chronos|7NT|Specter700
*AccuRC Substance Guru*
Saje Marvin - Citizen 125
Raz0rSh4rp is offline        Reply With Quote Quick reply to this message
Old 09-07-2018, 05:44 AM   #483 (permalink)
I haven’t tried, but that wouldn’t be ideal. Inalready noticed a big difference between 500 (sab) and 516mm (rails). Going to 477 would be a big jump.
517 vtx would be great!
mr. mark is offline        Reply With Quote Quick reply to this message
Old 09-27-2018, 11:42 AM   #484 (permalink)
I don't know where to post this but...received 697's and they won't fit in my metal blade grips.
One fits very tight,other one won't.
Roots are 12.2mm and 12.4mm
Had to sand washers to fit them into the grips(and that's a pain in ...).
I had several brands of blades(RT,Switch,Align,Tarot,blades from HK) and never had that problem.
Very disappointed cause they expensivest blades i ever had.
Does anybody had same issue?
20180927_182116 by jorjik2002, on Flickr
20180927_182147 by jorjik2002, on Flickr
racer-g is offline        Reply With Quote Quick reply to this message
Old 10-04-2018, 06:44 PM   #485 (permalink)
Hi everyone - I'm trying to determine the amount of deflection with VTX717's one would measure during a 3D flight. I'm trying to make sure I have plenty of clearance between the main blades and tail blades on my Goblin 700 Comp. Any ideas?
https://www.helifreak.com/showthread...=2#post7630286
(2) Protos Max Leggero/VBarNeo/Tribunus/VTX717, Blade 550X/VBarNeo/Castle/Rail556, VBar Control Touch
Caeguy is offline        Reply With Quote Quick reply to this message
Old 10-04-2018, 10:46 PM   #486 (permalink)
Measure the distance from the tail grip to the main grip bolts when clocked as close as possible. It should add up to more than your blades add up to.
As far as I understand it to be.
Steve
smittylube is online now        Reply With Quote Quick reply to this message
Old 10-04-2018, 11:07 PM   #487 (permalink)
Has anyone ever had a main/tail blade strike on a Goblin 700? I remember hearing about boom strikes AGES ago on Goblins but I never really bothered to look into why that was happening.
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL -- Charge Case
prototype3a is online now        Reply With Quote Quick reply to this message
Old 10-05-2018, 03:10 AM   #488 (permalink)
I've heard about tail strikes with the 700 competition and rail 716 blades. But i've also read some stories where people have no problems. I guess it depends on your flying style
https://www.helifreak.com/showthread.php?t=734079
Old 10-05-2018, 08:29 AM   #489 (permalink)
According to my measurements, I would need to see a main blade deflection of 105mm for a tail blade strike. How feasible would this be using VTX blades? They appear to be fairly stiff.
Old 10-05-2018, 08:42 AM   #490 (permalink)
i just tested it, and i get ~5cm deflection with only little force (logo 700). 10 cm would certainly be possible under heavy load i would say. But there has to be someone with experience with this combination
Caeguy likes this.
Old 10-05-2018, 10:52 AM   #491 (permalink)
Having fun and went a little crazy with the math/simulation. Main blades deflecting in an arc yields approx 125mm before tail strike. Thats almost 5". Many assumptions still in the model..e.g, end loading the cantilever beam and the beam has a uniform cross section, tail blade in same plane as main shaft, etc.
Old 10-31-2018, 11:38 AM   #492 (permalink)
yup,
speak with mikadousa.
they will help you
d
deepak kirpalani
[email protected]
deepak is offline        Reply With Quote Quick reply to this message
Old 11-18-2018, 01:40 PM   #493 (permalink)
Should be fine. A little heavier than what the 477 was designed to support (design weight of ~ 2.2kg) but still the 477 blade has enough area to handle 2.6kg I think. Especially if you have more power than what a stock Logo480 has. Give it a try and let us know...
Cheers,
Bill.
VTX Designs is offline        Reply With Quote Quick reply to this message
Old 11-19-2018, 11:26 AM   #494 (permalink)
Thanks Bill,
I've been thinking on this a bit more and realize if I run my 3800 pack I can drop ~150g which gets me a lil closer.
Power wise it is running 4020 so lot's of HP for a 480 class
Old 11-19-2018, 11:27 AM   #495 (permalink)
Another thought was quit the opposite.... run 557 and get a lower Kv motor to shoot for 1600-1900rpm
Old 11-20-2018, 05:14 AM   #496 (permalink)
Or stretch the XLP520 to 550?.....
Diabolo 550BE
Synergy 516S
MSH P380 Evo
AndyO is online now        Reply With Quote Quick reply to this message
Old 11-21-2018, 10:04 AM   #497 (permalink)
Yes, that was Plan B...
Old 01-04-2019, 04:07 AM   #498 (permalink)
How goes with the 507, 517 or such in between 477 and 557?
I think we heard about a 507 in the works quite a while ago....
henke2 is offline        Reply With Quote Quick reply to this message
Old 01-04-2019, 03:07 PM   #499 (permalink)
I'm still hoping for some 607s or 617s and some bigger blades like 807s.
Old 01-04-2019, 07:31 PM   #500 (permalink)
607's are through final aero design as of last week. The blade is now being modeled up for production tooling.
We'll get prototypes done first, then a flight test program, then ramp-up to first lot. Oh, and don't forget we have Chinese New Year in there somewhere.
I wasn't going to say anything quite yet but since you asked...
Bill
