Old 10-08-2016, 04:39 PM   #1 (permalink)
Default Microbeast Spektrum Ar7700
I'm running ar7700 SRXL w/ microbeast.
Ar7700 says port gear/ch5 "throttle"??
I have the throttle lead in ch5 on the Beastx but want to use the gear/ch5 on the ar7700 but I'm getting no pwm/throttle signal....
Can I plug my throttle lead into the Ar7700 just link a normal Rx?
If any one has and in-site on this please comment...
Smk-A$$-3Dô is offline        Reply With Quote Quick reply to this message
Old 10-09-2016, 12:09 PM   #2 (permalink)
Nothing ??? Maybe I should go to a Spektrum forum ??
Old 10-10-2016, 05:23 AM   #3 (permalink)
Hi,
CH5 on the Microbeast does not refer to the Gear channel of the transmitter. On the Microbeast this is linked internally to throttle channel. But you can freely assign the function ordering on the Microbeast using the receiver menu setup if you like to have this linked to gear channel.
As far as I know yes, you can also use the pwm servo outputs of the Ar7700. These will work in parallel to the ppm sum signal and digital SRXL output. Note the here the channel designation directly refers to the channel ordering of the transmitter just as with any other Spektrum receiver.
best regards from Germany
Stefan
BEASTX r&d Team
freakware.com
Frenchdress is offline        Reply With Quote Quick reply to this message
Old 10-10-2016, 12:02 PM   #4 (permalink)
Great, thank you that's what I figured, I can assign all the channels in the Bx.
I just didn't want to go through the trouble and not have it work.
As I have it setup now, I believe I have the gear set for tail gain on one switch, and rescue on aux2 on another switch
If I assign the throttle to ch5/gear will I loose a switch function?
Using a Dx9, grey. Or activate the gyro channel in the Tx and assign the tail Gain. To that ?
Rescue on aux 2.
Throttle on ch5 assigned in bx...
