Like Tree4Likes
Old 10-16-2016, 02:31 AM   #21 (permalink)
I've never had any issues with the swash geometry on mine. The tail on the other hand is a different story. Long story short I had to try just about everything I could think of and then some and finally a little at a time it's now all sorted out.
Of course even with the tail sorted out mine has just been cursed. When I got the tail fixed the very next flight the pinion came off the motor while inverted.
The biggest problem with the 250 is its really not a beginners heli even though it's so small. It takes about every trick in the book to get and keep one flying and can be a challenge. It can fly pretty sweet though when all the stars align.
As far as a 250x version goes I would like to see the motor up top, a better belted tail, and 300g AUW right out of the box.
I'm not sure I would go for another one though. Especially now that I have mine in the sweet spot. It's my only flying micro at the moment and will probably be the only one I keep flying.
Helis: Trex 250, Oxy3 +, 450 se v2, 450 pro, 470, 480N, 500 ESP, 600N, 700N
HeliLust is offline        Reply With Quote Quick reply to this message
Old 10-16-2016, 07:08 AM   #22 (permalink)
Maybe I have a different model 250 DCF, but mine is the most tame and docile of all my helicopters except the T-rex 100. I could never detect any problems with the tail, other than the day the tail servo stopped working (replaced with a Savox).
The 250 was my first 'real' heli that had a FBL unit and I flew it for about 45 hours before its first crash. It seemed like it was immune from crashing. My T-rex 150 crashed all the time when I was learning and the 450L crashed 4 times before the first 20 hours of flying.
An old friend from my airplane flying days e'mailed me to 'send it back and get a 450' when I indicated I had just ordered the 250. I went ahead with the 250 anyway and I'm glad I did. When I eventually got a 450L, I found the 450L to be quite a scary handful when first flying it. In fact I'm still getting used to the 450L's power and responsiveness.
Micros: Hisky HCP80, ESKY 150x,K110, Trex-150X x 2 Mid: Oxy 3 T New Version, Oxy 4 360 Big: Trex-500X, Trex-550X, Trex-700X Scale: MD500 TOW Defender (Trex 500 size) Vintage: Trex 450 SE V2
ic-racer is offline        Reply With Quote Quick reply to this message
Old 10-16-2016, 02:11 PM   #23 (permalink)
Keeping in mind that the Trex 250 is actually a 200 size heli, there is no way you are getting a 250 size heli even close to 300g (unless you use a waaay undersized battery).
I've kept my Gaui X2 very light and it is at 400g. I've kept my 300X very light and it is at 460g. The Oxy2 starts out at about 560g. (Flying weights).
I like this size and I like my Trex 250. I'd be very interested in a 250X, especially if it were available without electronics.
Murph_d is offline        Reply With Quote Quick reply to this message
Old 10-16-2016, 03:16 PM   #24 (permalink)
Trex 250 isn't easy to get under 300g AUW but it is possible. For a while I had mine at 267g AUW with a 800 mah battery and no canopy. I have since changed servos from ds 76's to spektrum 3050's and a 3060 and also went with a canopy again and it's sitting at 312.5g and flies really nice. That is with a align 850 mah battery installed.
I could get it down to 225g area if I went crazy with it changing out the motor, smaller battery, 180 servos, plastic canopy, and shortened up the wiring.
Someday I may just go crazy with it and make an indoor version of the heli, but less than 300g it's not so much of an outdoor flier with the wind I get out in the desert.
Old 10-17-2016, 07:45 AM   #25 (permalink)
Originally Posted by Toocool4 View Post
That is just crap, if you look at my pic below you will see I am using hole 4 on the servo horn and everything aligns perfectly to give me the correct FBL range.
thanyou this is the info i have been failing to find!!! IM on the same holes as you, i was counting from the outside not the inside.
But im still just outside the ideal control loop range, which means i must need the DFC swashplate.
with the original FBL head and swash ive came acros quite alot of people being outside the range and some dfc people had the issue aswell but theproblem is so many threads just stop, either the problem got fixed and didnt report back or they gave up
bazsound is offline        Reply With Quote Quick reply to this message
Old 10-17-2016, 09:31 AM   #26 (permalink)
Sorry, I didn't emphasize the point, which is, the Trex 250 is not a 250 size heli. It's a 200 size heli. Stock main blades are 205mm. Mine is under 300g with a 950 mah battery and yeah, the wind does push it around a bit.
The OP says that the (rumoured) 250X will swing 250mm blades, which would make it a 250 size heli, about the same size as a Gaui X2, Blade 300X, or Oxy2, a fair bit larger (and heavier) than a Trex 250. Highly unlikely that (out of the box) it would be less than 400g AUW.
Old 10-17-2016, 09:54 AM   #27 (permalink)
I see where there was some confusion now. With 250 size mains it would be difficult to get under 400g. Especially considering it would need a beefed up head.
Keep in mind the things in the thread are all wishful thinking. It's hard to say what align will redesign after the 150x.
Old 10-17-2016, 01:49 PM   #28 (permalink)
Just one point--the Oxy2 is said to be sized between a Blade 180CFX and the Trex 250. Unless there's something new that I have not heard about.
Here's a prototype pic from the thread, "Any Oxy 2 Updates":
navigator2011
Oxy2 190 FE / Oxy2 190 Sport / Fusion 180 / Blade 150S / Trex 150X / Blade mCPX BL2 / Brushless Nano S2 / Spektrum DX9.
navigator2011 is offline        Reply With Quote Quick reply to this message
Old 10-18-2016, 02:31 PM   #29 (permalink)
Sorry for the typo, I meant Oxy3 (255mm blades)
Old 10-27-2016, 01:09 PM   #30 (permalink)
thigns are really quiet here.
Do i hafve to create more drama!!!!
Old 10-27-2016, 01:11 PM   #31 (permalink)
navigator2011
Old 11-01-2016, 06:58 AM   #32 (permalink)
Standard version 190mm blades
Stretched version 210mm blades
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl
mahbouni is offline        Reply With Quote Quick reply to this message
Old 11-08-2016, 07:49 PM   #33 (permalink)
No, but you should learn how to spell or at least proof read what you are writing before you post it.
Align 450 Pro DFC•Hausler 450 sev2• HK 250gt• Blade SR• (2)Blade nCPX• (2)Blade mCPX•Blade mCPX bl•Turnigy 9XR Pro
Victory Motorcycles: 2007 Victory Vegas Jackpot•1999 Victory V92c Classic
kla912000 is offline        Reply With Quote Quick reply to this message
Old 11-08-2016, 10:12 PM   #34 (permalink)
I thought he was posting about quiet thighs.
Many helis from the 70s to 2000s.
Align,Blade,GMP,Hirobo,Kyosho,Schluter.Flybars cool,FBL too. Currently flying the little ones.
Heliwhisperer is offline        Reply With Quote Quick reply to this message
Old 11-09-2016, 04:23 AM   #35 (permalink)
If you go and read some of his posts you'll see how hard they are to read cause of all of the misspellings and typos.
Oh, and by the way, what are quiet thighs? Lol!!!!!!
Old 11-09-2016, 07:37 AM   #36 (permalink)
No swish from rubbing while walking.
Thighs Chaffing? - Skin Chafing? Quick Remedy! (0 min 45 sec)
Just poking a little fun.
Old 11-09-2016, 07:55 AM   #37 (permalink)
Thighs Chaffing? - Skin Chafing? Quick Remedy! - YouTube
Same here. Just trying to make light of the situation.
Old 11-11-2016, 07:12 PM   #38 (permalink)
you have to be light-hearted to fly a 250......
KDS Agile 6.4 Proto-Type 750MX 12s with an Ikon / KDS Agile 7.2 / Tarot-Align 600CF-FBL Robird G31 12S / The First X3-385
FROM AUTO-CAD to DIRT NAP in 10 SECONDS !
MGPTWEGB is offline        Reply With Quote Quick reply to this message
Old 11-12-2016, 07:07 PM   #39 (permalink)
Originally Posted by MGPTWEGB View Post
you have be light-hearted to fly a 250......
200 :p
Old 11-25-2016, 03:00 AM   #40 (permalink)
Have the Oxy2 come out yet?
The Goblin team also has something in the works. Looks like all these helis are slightly delayed on their release???
The Little Big Goblin (0 min 38 sec)
Surely Align Has to respond to these heli companies
gimbleguy is offline        Reply With Quote Quick reply to this message
