Tribunus? - Page 17 - HeliFreak
Go Back   HeliFreak > R/C Electronics Support > Scorpion ESC and Motor Support
Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum
Old 08-20-2017, 03:44 AM   #321 (permalink)
Originally Posted by Vinger View Post
Standard servo wire and plugs are rated for 3A continuous and 5A max so with two wires it is sufficient for the BEC output.
I do not understand.
The specifications of the Tribunus 120 are the following:
Max Continuous BEC Output: 10 Amps @ 8.3 V
Peak BEC Output: 20 Amps/1s
How can it handle a continuos output of 10Amps if you say, the standard servo wire are rated 3A continuos?
Any idea?
dcaccount is offline        Reply With Quote Quick reply to this message
Old 08-20-2017, 04:26 AM   #322 (permalink)
Those are the plug specifications and we have to live with those limitations, fitting thicker wires will not change the plug specs.
We all use these and it works as luckily for us there are never that amount of continuous current flowing with servos, unless a servo jamms or shorts out.
An example is the Kosmik range of controllers which have the same two BEC lines and their BEC are rated for 20A continuous and 30A burst, but never a burnt plug or melted wire unless something goes wrong. Even dedicated BEC's run the same two wire system. If you really want peace of mind fit a power bus solution and run it off two battery packs.
Gaui R5, Henseleit TDR, TDR2, TDF, Banshee
Kontronik, Scorpion ESC, iChargers, VBar, VControl, JR XG11
Old hand at Planks
Old 08-20-2017, 06:27 AM   #323 (permalink)
Yes, I understand but the wires are much longer than the plugs and if I am not mistaking the resistance of a wire and therefore the voltage drop, depend on the length and on the thickness (indirectly).
Therefore in my poor opinion a thicker wire would not have hurt.
Human Verification
