Tribunus? - Page 3 - HeliFreak
Go Back   HeliFreak > R/C Electronics Support > Scorpion ESC and Motor Support
Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum
Old 12-26-2016, 12:50 PM   #41 (permalink)
I just ordered a third Tribunus 120A for my Diabolo 550.
Synergy 766, E7SE, E5SS, E5S, 516, V Control, Neo, Tribunus
Freeskiken is online now        Reply With Quote Quick reply to this message
Old 12-26-2016, 06:57 PM   #42 (permalink)
If this esc will give telemetry through Jeti then I'm in!!!!
Rob
Team pilot Lynx Heli Innovations.
Jeti DS-16, Oxy 3, Goblin 380, 500, 630, and 700 competition, Airwolf 600 scale heli, Brain/Ikon 2, Spartan VX1e, Sk 720, YGE and Hobbywing.
Shogun71 is offline        Reply With Quote Quick reply to this message
Old 12-28-2016, 09:56 AM   #43 (permalink)
Is a smaller and lighter version of the 120A Tribunus planned as well, say something with 60A?
Would love to have full ESC telemetry in my portable 360 bird…
OliP is offline        Reply With Quote Quick reply to this message
Old 12-29-2016, 04:51 AM   #44 (permalink)
any update on the 160?
NEO-VBC Kontronik JIVE,Following Jesus !!!!!
Helicrazy2 is offline        Reply With Quote Quick reply to this message
Old 12-29-2016, 05:49 PM   #45 (permalink)
I believe that only the 120 and the 200 have been announced. The 120 is shipping now, the 200 is about a month out.
Team Gaui USA/Empire Hobby | Team Optipower USA
Gaui NX7 - Gaui X7 - Gaui R5 - Gaui X5 - Gaui X4II - Gaui NX4 - Gaui X3L - Gaui X3 - Gaui X2 - Velos 880
AMA 267329
joelr is offline        Reply With Quote Quick reply to this message
Old 01-06-2017, 08:46 AM   #46 (permalink)
I received my Tribunus a couple weeks ago. I got it installed in my 550sx just in time for the -40C weather to roll in ....... so no test flights yet.
When I got it, I updated the firmware using the PC interface and while in the interface, changed two selections to the "Vbar" setting and set the BEC voltage. After finishing the heli installation and powering up the VControl and 550sx, there was literally NO further setup to do for the ESC! Even without blades on, the spool up on the bench was soooo smooth and it settled at each of my governor bank speeds when switched. I can't wait to try it in the air.
Also, I removed a YGE120HV w/heatsink, a VBar UI sensor, and a WR Bec.......totalling 340g for the Tribunus which weighed 110g. Nice!
KevinB
KevinB is offline        Reply With Quote Quick reply to this message
Old 01-06-2017, 01:41 PM   #47 (permalink)
Nice! Can't wait to hear how it performs and how accurate the current sensor is compared to what your charger puts back in.
Did you have any trouble getting it to fit under the 550SX canopy? Did you install a fan? Well, at -40C you probably don't need one. :-)
Logo 480, 550 SX V2, NEO, VBC
GregCA is online now        Reply With Quote Quick reply to this message
Old 01-07-2017, 08:04 AM   #48 (permalink)
Is anyone running fans on a 120 6s? If so how are you power them?
Also for a Neo gov are separating the signal for the rpm sensor out of the cable and using the power feeds into another port?
Diabolo 550 Vbar NEO : Diabolo 600 Vbar NEO : Diabolo 700 Vbar NEO: MSH Protos MAX V2 Vbar NEO : Logo 600SX V2 Vbar NEO : SAB G380 Vbar NEO : OXY3 TE : Vbar Control : Citizen 735
shadco is offline        Reply With Quote Quick reply to this message
Old 01-07-2017, 09:07 AM   #49 (permalink)
GregCA,
It looks like the cold weather will be here for a while so I may not have any results to post for some time.
I didn't use a fan. At the motor end of the ESC (top), there is very little clearance between the ESC's heatsink and the canopy. 1/8"-1/4" . So no room for a fan there. On the lower end of the ESC, there might be room for a fan, but you may need some extra ventilation in the canopy to make it worthwhile??? I'm trying mine without a fan and see how it goes.
KevinB
Old 01-07-2017, 12:49 PM   #50 (permalink)
You can plug the ESC's RPM lead, with its secondary BEC power feed, directly into the NEO's RPM port since it is on the NEO's power bus. This is what I do. On the old mini VBar, you did have to separate the RPM lead and BEC secondary power feed.
Old 01-07-2017, 05:07 PM   #51 (permalink)
So easy even a cave man can do it.
Old 01-14-2017, 08:37 AM   #52 (permalink)
Well...hoping the weather tomorrow is nice enough to go try the Tribunus out.
Quick question....... After initially updating the firmware, I set the gov type to Vbar and the communication to vbar and the BEC voltage on the PC, then once the esc was connected on the heli, I powered up the VControl, powered up the heli, went to heli setup - governor and didn't change anything there. ( the main gov settings were also done because it was already flying with a YGE ).
Do I need to do the esc endpoint calibration still? or did the VControl and Tribunus just figure that out themselves when I entered the setup governor screen?
Thanks,
KevinB
Old 01-14-2017, 11:59 AM   #53 (permalink)
I set mine to VBar governor first and then it said in the VC that it was OK it didn't go through the the automatic setup. So I changed it to a different mode, saved it, powered the esc off and on. Shut the software down and started it again to make sure the new settings had saved. Then powered the esc off. Then powered the VC and the heli went to the governor screen and then it did its automatic setup. I wanted to make sure the VControl would perform the auto setup.
Old 01-14-2017, 12:22 PM   #54 (permalink)
Yes....mine just said it was ok as well. I'll try your method. Thanks.
KevinB
Old 01-15-2017, 04:38 PM   #55 (permalink)
Just to clarify....this method is to reprogram your NEO governor settings? Or the ESC's internal settings? ie: after the "auto setup" runs on the VControl, the governor settings looking at the VControl governor pages (gain, collective add, etc) should be changed?
I saved the mode to built in gov and then back to vbar, but it didn't do any reset of settings that I could notice. I may save the model and just try a completely fresh setup.
KevinB
Old 01-15-2017, 06:38 PM   #56 (permalink)
From my understanding it sets the esc. If you have been using the Vbar governor then the setting will be the same. For a new setup you will have to do the rpm setting and all.
I put one on a Goblin 420. I know it it over kill but I did not have to buy the U/I sensor so the price was about the same with less work.
Lynx Team Test Pilot
Heli's :mCX2, mSR X, Gaui X3, Logo 480, Goblin 420
Vbar Control
Lu523 is offline        Reply With Quote Quick reply to this message
Old 01-16-2017, 09:51 PM   #57 (permalink)
Quote: If you equip your heli with a Tribunus Regler from Scorpion , the model setup wizzard will automatically detect and program the Tribunus so it perfectly matches to the programmed model, and uses the VBar´s governor. Just a few clicks will do the whole programming work. It never was easier!
Old 01-16-2017, 09:53 PM   #58 (permalink)
http://www.vstabi.info/en/sc
Quote: If you have a fully NEO integrated Scorpion Tribunus ESC - please do the setup as following:
Load the Scorpion app on your VBar Control
Update ESC Firmware (PL must be 40 or higher)
Enable VBar communication protocol in ESC with Scorpion PC Software
Connect the ESC completely (Master to "ESC", Slave to "RPM",
Telemetry with adapter cable to "TELE") to NEO
Select "New Heli" or "Edit Heli" wizard - or the "Setup / Governor Mode" panel. The original one has been replaced by a Scorpion Auto Setup panel.
the setup is done fully automatic, just set the BEC voltage.
depending on changes the ESC may restart when leaving the panel once
afterwards check gear and headspeed settings
that's all! - Model and ESC are now set up for use with VBar Governor
For battery management we suggest using the Battery Logbook App as well as installing a Battery ID reader and the required App
Old 01-16-2017, 09:58 PM   #59 (permalink)
You MUST perform throttle range calibration before the first use
of the ESC, except if you are using external governor mode,
remove propeller/pinion from motor or back o pinion from
main gear while performing initial throttle range calibration.
You only perform throttle range calibration if you are using the internal governor.
Old 01-16-2017, 10:05 PM   #60 (permalink)
Quote: I saved the mode to built in gov and then back to vbar, but it didn't do any reset of settings that I could notice.
Make sure you have saved a non governor mode first. Confirm it in the Scorpion software. You will have to power down the esc and reset / restart the sorftware to see if you have saved the settings in the esc to a different mode. Then when you go to the governor setup you will see the Vcontrol with the dots scrolling (loading) as it is setting up the esc and VControl.
Human Verification
